Question about Taylor Dgtl Body Fat Scale
Black Taylor home floor scale bearing numbers on bck 7014B & 3909 & VO427 which uses two nickel-size batteries WILL NOT FUNCTION. No Light, No reading, no reaction, even when new batteries are installed at $10 cost.
SOURCE:
  • 74 Answers
SOURCE: Taylor Scale 7532s - not working
This link allows you to trouble shoot directly with the company....I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
SOURCE: Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Posted on Jun 24, 2009
SOURCE: We have a Taylor 7542 Bathroom Scale. I need to
I called Taylor; the Model 7542 take a 3v CR2032 battery available at Walgreen's, CVS, WalMart, etc.
Posted on Jun 29, 2009
  • 60 Answers
SOURCE: taylor scales model 7314 lithium scale
Have you tried to email Taylor Customer Help and Support?
They are very useful. They can guide you through problems, provide you with instructions and might send the user manual via email.
I hope you get this fixed. Scales are very tricky!
Posted on Oct 25, 2009
skaterkid307
  • 86 Answers
SOURCE: How can I fix the Taylor LIthium Scale?
take it to were you got it or instuctions show u
Posted on Feb 20, 2010
My scale is a taylor 5751 bc how do i reset all memories?
Easy way is to remove the battery. Or individually;
Press and hold the "Power" button in the center of the scale. Your scale will then list the information you have saved for each memory number.
Hold both the "Up" and "Down" buttons for about three seconds. This will clear the information for that memory number.
Repeat the process for each memory number that has information stored on it.
Remove the battery from the scale. Leave it out for five minutes. Reinsert the battery to finish resetting your scale.
https://healthfully.com/reset-taylor-scale-5033705.html
Oct 05, 2017 | Taylor Health & Beauty
How do you calibrate, it's a body fat scale, can't find model #?
It's important to find the model number to be able to find the correct manual. Below is a link to FAQ's about Taylor body fat scales.
If you do a google search for "taylor body fat scale" you will see a list of a few models. Examine each to see if one of them is the same as yours.
Taylor USA FAQs Scales
Searches related to Taylor body fat scale model number location
taylor body fat scale model 5741 manual
taylor body fat scale model 5761bf
taylor body fat scale model 5731f reviews
taylor body fat scale accuracy
taylor body fat scale 5731 review
taylor body fat scale athlete mode
taylor body fat scale readings
taylor body fat scale5758f manual
Aug 01, 2014 | Taylor Health & Beauty
Hello: my digital food scale (taylor digital biggest loser brand) goes on but it does not weigh anything. its stays at zero. i've had it a year but only used it once or twice, so its almost never been...
Hello, Maclay55 -
I hope you checked the owner's manual first, the troubleshooting / problem solving section.
It wouldn't hurt to put new batteries in the scale (2 AAA batteries).
Note: From the instructions for the scales:
6. Do not store scale where you store cleaning chemicals. The vapors from some household products may affect the electronic components of your scale. Do not store scale on its side.
7. This scale is an extremely sensitive weighing device. In order to prevent run down of the battery, do not store anything on the scale.
8. Do not dispose of batteries in fire. Batteries may explode or leak. Do not mix old and new batteries. Do not mix Alkaline, carbon-zinc (standard) or Nickel-Cadmium (rechargeable) batteries. Remove the batteries if the scale will not be used for a long period of time.
Source:
1037BL The Biggest Loser by Taylor Stainless Steel Platform Scale Instruction Manual, pages 4-5
http://taylor-enviro.com/media/IBs/1037BL_ib.pdf
If installing fresh batteries does not work, then I suggest you call the Taylor USA Consumer Help & Support department. This is the link to the web page with the US and Canadian telephone numbers:
http://taylor-enviro.com/taylor-support/
Best wishes.
Feb 11, 2018 | Taylor Precision Products Taylor Precision...
Taylor 7532S, battery replaced, error message 0-Ld
Try to reset the unit. Use the following steps
- Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
- Remove the battery from the compartment. Close the battery compartment door.
- Sit the scale right side up on a hard surface floor.
- Step on the scale and stand still on it for five to ten seconds. Step off the scale.
- Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
- Place the scale right side up on the hard surface floor.
- Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
- Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
Hope this solution has been helpful?
Jan 26, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
I can't find the battery number to replace my battery in my taylor 7321 bathroom scale. Is there a way to find out what battery to buy?
yes call the manufacutere or go to the store where you purchased it from and they can supply you with a the proper company and phone number
Jan 05, 2010 | Taylor 7321 400 Pound Lithium Scale
How to calibrate a taylor scale 5571
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight,to calibrate, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department.You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jun 13, 2009 | Taylor Body Fat Analyzer & Scale, Model...
Feb 23, 2009 | Taylor & Digital Scale Lithium Scale
display the Error.
REMOVE YOUR FOOT.
Regards,
Linda DLT
Consumer Relations
& Salter Housewares
866-843-3905
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
Taylor Dgtl Body Fat Scale Logo
60 people viewed this question
Top Taylor Health & Beauty Experts
Lynnette Kinsman
rebecca curry
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
