Question about Jenn-Air JMC7000 Microwave Oven
I have a jenn-air JMC9158BAS mircorwave. After a few seconds of cooking, it starts to make a loud buzzing sound. I removed the microwave from the cabinet and starting taking it appart. When the electronics were exposed I baked a potato to see if I could figure out what was making the noise. Using a wood "listening stick" the noise seems to be coming from the high voltage xfmr. Is this common? The turntable is also somewhat noisy. Is there a bearing to replace?
  • vwranosky Oct 24, 2010
    Microwave still cooks well. Would a bad magnetron or hv diode result in poor cooking performance? I am aware that the capacitor would need to be discharged prior to any electrical servicing.
    Thanks
Usually a bad magnetron or bad high voltage diode will cause the microwave to have loud buzz noise. If you still have a warranty, send it in for repair. If your microwave is no longer in warranty then it will be cheaper and safer to buy a brand new one because repairing microwaves can get expensive and you could get electrocuted if you don't know what you are doing
Posted on Oct 24, 2010
SOURCE:
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
My Jenn-aire microwave says locked and has a picture of a padlock. I was microwaving bacon and had just put it some to cook ( my second batch per se) and everything was locked up. I tried pushing options...
Most likely you set a child lock (front panel lock) by holding a button too long (3 seconds). Without a model number, I can't be absolutely sure of the keypad lock for your Jenn-Aire microwave. Usually, the key will have a small padlock icon on it. Press and hold this key. On my microwave you press and hold Start to toggle the lock off.
On a Jenn-Aire JMW2430 and similar models, the Button Lock is activated by a several step process (More and Button Lock). However, pressing and holding the Start button will deactivate it.
I hope this helps.
Apr 19, 2011 | Jenn-Air Microwave Ovens
My microwave makes a loud buzzing sound
Magnitron is going out. Suggest discarding microwave it will possibly go completely out in the near future. Good luck hope this helped
Dave
Nov 02, 2009 | Jenn-Air JMV8208AAS Microwave Oven
Odd buzzing after timer stopped, food was still being heated
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
r6uw
Aug 20, 2009 | Whirlpool MH1150XM Convection/Microwave...
Microwave in Jenn Air Microwave/oven combo is not heating at all
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Aug 07, 2009 | Jenn-Air M170 Microwave Oven
Unit makes a loud buzzing sound whenever the unit has power.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
[email protected]
http://www.microwavedisplay.com
Nov 23, 2008 | GE JVM1860 Microwave Oven
Microwave makes loud buzzing sound when on and no heat
Have you tried putting a cup of water in it and cooking on a low power level? If it buzzes only when it is on the cook cycle, that would narrow it down. More detals might help us help you, including the model number.
Mar 20, 2007 | Kenmore 62622 Microwave Oven
Constant Humm / Buzz but Works OK
I was going to suggest the low voltage transformer, but when you said it sounded like it was coming from the left side, that seemed odd. I have a stock transformer here I keep for test that is loud, but it works. Odd, eh?
Dec 21, 2006 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Jenn-Air JMC7000 Microwave Oven Logo
137 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
