Question about Panasonic Workio DP-2330 Printer
My Panasonic Workio DP-2330 was stored in a clean environment for 6 to 8 months(it was working great prior to storage). We move it to a new office, it turns on, but the touch screen is frozen, it does not work. We can not input any info into the machine.
  • 3,083 Answers
The most likely thing that has happened to the unit is that some oxidation has occurred on some of the contacts (most likely ribbon connectors). Make sure you shake the toner cartridge in the machine, and if that gets the machine to respond, diagnose the machine, if further needed. In the following .pdf document, there is a function of the printer called "Check and Call", which is part of Panasonic's support, to aid in diagnosing the printer. I would suggest if, after assuring the toner cartridge is good, contacting support and check if there's anyway to remotely troubleshoot the unit. Here's the .pdf:
http://panasonic.net/pcc/mfp/dp-3030_2330/pdf/2330EUstd.pdf
If you're warranty is still in effect, have it serviced (at least remotely). If the machine is out of warranty, you might try getting to the touch screen's connector (either ribbon or multi-plug), and reconnect it, to ensure it's making good contact.
I have a philosophy that bad connectors in hard-to-get-at places can be made to work with a precision physical "jolt". I don't recommend it to anyone except lazy people like me, who want to save hours of learning to take something apart and reconnecting the various wiring. Just a thought, but don't jostle it enough to cause damage.
Of course, a connector could have come loose in the move, and it might be necessary to dissassemble it to reseat the connector.
Good luck, and hope this helps.
Posted on Oct 24, 2010
SOURCE:
2330 drum repair
Drums are cheap. Replace it along with cleaning blade cleaning roller and charge roller. Perform F8-14 and F8-20.
Jul 28, 2014 | Panasonic Workio DP-2330 Printer
I am trying to use the workio 2330 to print labels and can not get it to manual feed.
I gather that you are trying to feed through the bypass tray? if so does it feed normal A4 paper?.If it feeds normal paper then it sounds as if the feed tyre is slipping and requires cleaning.I would suggest that it is cleaned anyway and also check that there is no obstructions in the feed path.
Sep 21, 2011 | Panasonic Workio DP-2330 Printer
Need Panasonic WORKiO® DP-2330 driver
Hello , this is the link for the most up to date driver. Just choose your language and operating system
Thank you.
http://www.panasonic.net/pcc/support/mfp/dp-3030/gdi/download.html#01-2
Feb 09, 2010 | Panasonic Workio DP-2330 Printer
How to scan
My dp 2330 copier prints dark shades(0.5 thick dark lines) even though the text you want to print is seen in the back ground. pls what should i do or whats the problem? Thank you .
Sep 11, 2009 | Panasonic Workio DP-2330 Printer
How to print envelope on Panasonic DP-2330 printer
You can download a user's manual from here.
It's a pretty large file, so I'm guessing there's something there about paper feeding or envelopes that will help you.
Good luck.
Aug 31, 2009 | Panasonic Workio DP-2330 Printer
Need IP address of Workio dp-2330
"share" it on your server, then on each PC go to "add printer", select "network Printer", browse your network, and select the printer.
Mar 20, 2009 | Panasonic Workio DP-2330 Printer
Panasonic 2330 servicecode
Try 0000. That´s the original operator code of my Panasonic DP-2330 office machine.
Feb 06, 2009 | Panasonic Workio DP-2330 Printer
Need drivers for panasonic dp 2330 printer
You can download your driver here: http://catalog2.panasonic.com/webapp/wcs/stores/servlet/ModelDetail?storeId=11201&catalogId=13051&itemId=88287&catGroupId=13843&surfModel=DP-2330&displayTab=R
Just click on the driver download & select the driver for vista. Hope this helps & please remember to rate my answer. Thanks.
Jan 09, 2009 | Panasonic Workio DP-2330 Printer
Booklet printing
You're right, most do offer that option from the print driver. I would check Panasonic's web site to see if they offer a postscript driver, that may have booklet printing.
Jun 12, 2008 | Panasonic Workio DP-2330 Printer
Panasonic Workio DP-2330 Printer Logo
80 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
