Question about Dryers
The dryer is making a terrible squealing sound. Believe it to be a belt. Do I get to it through the back of the dryer?
    New Friend:
  • 85 Answers
No take top off
Posted on Oct 25, 2010
SOURCE:
Dryer runs for a short period then starts to sqeal from the back and when you stop it and open the door you can smell a burning smell .
sounds like a bad belt and or pulley. If you take the top of the dryer off you can use a piece of candle wax to lube the belt and see if that makes the squealing stop to verify the belt/pulley as the source of the squeal. If so, you can but a new belt and pulley kit for about $30 and replace yours. Good Luck!
Oct 11, 2014 | Kenmore Dryers
Makes a terrible noise and sounds like it need greased. How do I get it apart to grease it.
Hello & Welcome to FixYa
Though I believe the issue is bad/worn out/broken belt and needs replacement however, you can check this video on how to replace the belt & how to take it apart for greasing:
Please get back to me if you have any other questions.
Kevin
Jan 20, 2011 | Maytag Neptune MCE8000AY Electric Dryer
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
My dryer makes a squealing sound when running. I believe it's the belt on the tensioner pulley, but I have no idea how to get to the darn thing.
There is no easy way, but its more time consuming really. I'm not familiar with your particular dryer, but you''ll need to remove the top and front casing of your dryer and remove the drum to get to the pulley. Sometimes you can get to it via a compartment on the rear of the dryer as well. Also listen to make sure the squealing isn't coming from the drum bearings on the rear of the drum.
Apr 27, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Sqeals terribly, stops squealing occasionally, but is very loud and high pitched.
Squealing comes from the belt. I replaced my belt and it went away. Good luck in trying it.
Apr 18, 2010 | Dryers
My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Apr 01, 2010 | Frigidaire Electric Dryer
Dryer squeals terribly awful from back of dryer, seemingly somewhere between the rubber rollers. ( drum)
there are bearings or a bearing behind the tub, need too make sure you unplug power cord first . then open the top and front so you can get a look at it. bearing is in the center back behind tub. this should get you started !!! sounds like a little grease will take care of it . good luck !!!!!!
Jan 20, 2010 | Amana NDG7800AW Gas Dryer
Frigidaire dryer model # FDEB34RGS2 Squeaking
There is a tension pulley that holds pressure on the belt, as well as wheels that the drum sits on. A drop of oil on the bearing of each one should solve the problem, unless the wear has gotten too far, and need replacing.
Jan 01, 2010 | Frigidaire GLER642A Electric Dryer
Maytag dyer was squealing now smells like burnt rubber
Sounds like you may have a belt slipping.Take the back off &see what the belt looks like.
Aug 28, 2009 | Whirlpool LER4634J Electric Dryer
Squeeky noise
I own a Frigidaire Heavy Duty Dryer The Model # is FDE436RES1. It is 10 years old. When running the dryer it makes a very loud squealing noise although the heat and the dryer still work. Is this a belt or roller problem or does it sound like something else. It is very high pitched and can be heard throughout the entire home. I do not know much about dryer troubleshooting so your help would be greatly appreciated. Thank You.
Oct 17, 2007 | Frigidaire GLER642A Electric Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
paul
paul
