Question about Garmin Edge 305 GPS Receiver
Will not start or turn on - Garmin Edge 305 GPS Receiver
  • 2 more comments
  • Anonymous Jun 08, 2008
    Same exact problem. Worked fine last night, this morning, dead, and won't charge. May have left it on last night and drained the battery, still, the cable seems a little jiggly in the connector and now it won't charge.....
  • Anonymous Aug 04, 2008
    Worked for my edge 305. Followed the instructions above and worked first time. You don't get anyfeed back when pressing both bottom (left hand) buttons at the SAME TIME but when you press the on button things should be back to normal.
  • Anonymous Aug 05, 2008
    asdf
  • cnigri Aug 05, 2008
    will not turn on
I came in early to work so I could get in a 3-4 mile run and my Garmin did not power up. I was pissed! This solution worked perfectly, wish I had found it about 6 hours ago. Thanks to whoever thought of this wesite!
Posted on Sep 02, 2008
Thanks, you are my hero. I thought the thing was broken, and I threw out the receipt. I was about to shell out 300 bucks more for another one....
Posted on Aug 23, 2008
Not to spam or anything, but thank you Steve - worked for me.
Posted on Jul 12, 2008
Steve my hero. it worked a treat
Posted on Jul 08, 2008
On a similar note, has anyone experienced a situation where the Edge 305 will not take a charge? When plugged in, the screen will read "battery charging in progress" for only a couple minutes, then the screen will either go blank or the unit turns itself on. In either case, the unit is no longer taking a charge. This is frustrating and sometimes it takes days to recharge since it only charges a couple minutes at at time.
Any ideas?
Posted on Jun 24, 2008
Thanks! This worked for me, too
Posted on Jun 22, 2008
Thanks Steve922... This worked for me..
Posted on Jun 15, 2008
Thanks. Worked like a charm.
Posted on Jun 14, 2008
I have had the same problem several times (as well have some friends).
This resolves it EVERYTIME though... at the SAME TIME, hold the BOTTOM LEFT front button AND the Bottom LEFT SIDE button (this reboots it). Then just hit the power button... I am sure you will see that it powers right up.
Posted on Jun 11, 2008
  • Steve922 Jun 13, 2008
    Has anyone having this issue tried my suggestion? Just curious... I would be surprised if it did NOT work.
I'm 19 95 Chevy Caprice wont start I don't know but won't start
Won't start how ? Does the engine turn (crank) when the key is turned to the start position ? Not start an run but turn or spin ! A crank - no start Or doesn't turn or spin this is A no crank - no start . These two different conditions would need different diagnostic steps .
May 10, 2016 | Cars & Trucks
Truck will not start, wait to start warning light is out?
Please provide more information.
"I put the key in the ignition, turn it and the warning light goes out, I turn the key to start but there is nothing..." or
"I put the key in the ignition, turn it and the warning light goes out, I turn the key to start but there only a ticking/clicking sound..." or
"I put the key in the ignition, turn it and the warning light goes out, I turn the key to start but the engine only turns over and doesn't catch."
Jan 06, 2015 | Cars & Trucks
HOW DO YOU ADJUST CARB ON STHIL CHAIN SAW
start by turning adjustment screws in. turn low speed out one turn and the high side 3/4 turn. start engine and adjust accordingly. the one turn and 3/4 turn are the starting point. saw should start at these settings and then you can fine tune. without knowing your elevation I can't give you the number of turns .
Oct 13, 2014 | Garden
Wont start sometimes
GM cars have bad problem with security system. If you key turn light and will start other time will stick and need shaking to turn over and won't start just replace the key. Security system need some times to refresh the memory.
1.turn key ON for 10min.
2.turn key OFF 10sec.
3.turn ON 10min.
4.turn OFF 10sec.
5.turn ON 10min.
turn OFF ON and start
total of 30 min. to refresh the memory
the next step is more expensive and need some skills.
on top of the ignition switch is a sensor go bad
replace ignition switch with the sensor and do the learning process from step 1 to 5
Apr 15, 2014 | 2004 Pontiac Grand Prix
Triumph trophy 900 carb 1997 starting problem. sometimes the ****** just will not start it turns over back fires turns over and starts, sometimes starts second turn. has had new coils fitted tappets a
Hmm sounds to me your Carburetor needs cleaning, check your intake might be just a bad air filter, also change you spark plugs and make sure they are on proper adjustment. that what i did when i have that problem... hope it help
Dec 23, 2012 | 1997 Triumph Trident 900
Have Error Code E20 - won't drain. How do I approach?
The diagnostic test is used to check individual component function only. TO START THE TEST: • Turn the Program Knob to the start position, Spin Only. • Press Start/Pause to start the cycle and save it. • Press Cancel to stop the cycle and turn off the LEDs. • Press Cancel again to turn on the LEDs. • Within 5 seconds, press and hold the Options and Start/Pause buttons until LEDs start sequentially chasing, then release buttons. 1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality. 2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment. 3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment. 4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment. 5. Turn the program knob (4) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened.When the door is opened, the drum light should turn on. 6. Turn the program knob (5) clicks from the start position. The washer will fill and tumble. Once tumbling has started, the Boost Heater (if so equipped) will turn on. 7. Turn the program knob (6) clicks from the start position. The drain pump & door lock solenoid will activate and the washer will operate in high spin. 8. Turn the program knob (7) clicks from the start position. The control will signal the last error code. Exiting Diagnostic Mode There are two options for exiting theDiagnosticTestmode and returning the washer to normal operation: a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR b) Turn the program knob clockwise 2 or 3 clicks after the start position. Press Options and Start/Pause buttons together for a few seconds until wash cycle LEDs appear.
Dec 26, 2010 | Frigidaire Affinity ATF7000E Front Load...
Dryer will not start. When I turn the start knob,
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 11, 2010 | Dryers
Difficult to start -- bad kill switch?
You have 3 safety switches located on the tractor, any one of which can cause the tractor to not crank over.
I assume the deck lever is not engaged, you are sitting in the seat and you push the clutch down when trying to start?
Start by lifting the seat and disconnecting the seat switch, push the clutch in and try to start.
Start there and we'll go from there.
Regards,
Aug 21, 2009 | Craftsman Garden
Dryer turns on, but does not run
Try to turn the drum inside with no clothes in it, does it turn freely both ways?
Then as someone is holding the start button, hold the door switch button, then try to turn the drum counter-clock wise, and see if it will start turning on its own.
If it does start turning, then the motor is more than likely the problem.
If it dosen't then the timer is more than likely the problem.
Feb 05, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Garmin Edge 305 GPS Receiver Logo
411 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
