Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Sony rear projector KDF-E50A12U Reset
Hi got optical block bought new bulb as well some one has been in service mode is there a master reset or does any one have the service menu settings so i can re correct before tacker ling the optical block Need to set back to default as picture grainy and yellow Thank you
    Problem Solver:
  • 6 Answers
Http://www.avforums.com/forums/showthread.php?t=384717&page=8
this will bring up sony bos menu try it m8
Posted on May 30, 2009
Sony kdf e50a12u New bulb but until tv has warmed up (10 min.) it intermittenly loses sound but not picture
The lamp of course will or should not affect the sound---next time it is cold try it on a rear input---a DVD player etc to see if same issue--this could narrow down where the problem is.
Nov 04, 2012 | Sony KDF-E50A12U 50" LCD HDTV
Reset the lamp hours on KDF-E50A12U rear projection HD
A quick call to Sony customer service with the model number will answer this and I looked but it is not in the owner manual for this set.
Apr 17, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hi i have a sony lcd projection kdf-e50a12u and as i turn it on the green light flashes for a few minutes untill it turns to red along with the light next to it and stays red?
Sir check the lamp of your projection if already damage, if damage replace the lamp and reset also the lamp hour meter. Remove the screws to open the panel labeled "lamp" on the back of the Sony TV. Remove the screws that hold the lamp in place inside the TV. Pull the lamp out. Let me know what is your observation to the lamp so I can guide you. Good day and best regards.
Sep 15, 2011 | Sony KDF-E50A12U 50" LCD HDTV
How many projection bulbs does a sony kdf-50e3000 have
Sony KDF-50E3000 is LCD Rear Projection tv that has one lamp as back light source and optical unit (light engine) generates image that projects on front screen of tv, it is similar to multimedia projector technolog.
Lamp part number is F93089000 XL-2500 utilized in this model.
Thanks.
Feb 17, 2011 | Sony KDF-50E3000 Television
I have a KDF-E42A10 - with a bad optical block. I also have the red light on the front indicating a failing lamp. So, in order to get the replacement deal from Sony - I need to take a picture of my...
Like any projector, enclosed in a cabinet or not, it has a lamp and/or filter hour counter. Did you reset these when you put in the new lamp? Also, did you replace/clean filter. VERY IMPORTANT.
Nov 24, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
How do I reset the self check mode on a KDF-E50A10
once your in the self check mode hit the number 8 and then enter on the remote to clear
Dec 11, 2009 | Televison & Video
Replaced bulb and still have red line at top of TV any advice
see sony website - extended warranty for this problem. It needs repair service to replace the optical block. I just had the same problem - they come to your house to repair free of charge.
Mar 02, 2009 | Sony (XL-2400) Projector Lamp for...
OUr Sony Grand Wega KDF-60XS955 has a blue corner
I had the same problem with my 4 yr old Sony KDF60WF655 rear projection set, and I was fortunate to buy a 4 year extended warranty - because it was the $1300. (not incl labor), Optic Block that was replaced to fix the problem. That part contains all new LCDs, & Lens & some electronics. I had already got a new bulb (under warranty) a few weeks earlier, that I had not yet installed so the service guy did replace that as well. (This happened 3 weeks before my warranty ended)
He told me that he replaces hundreds of Sony Optic Blocks every year and that many Sony Rear Projection sets have FACTORY extended warranties because of some known problems with the blue LCD panels.
The tech checked my Service Codes & showed me the TV had been running for 10051 hours in about 4 years - on the Original bulb! He was quite surprised because he said the bulbs usually last about 5000 - 7000 hours. He also said it's good to replace them BEFORE they go bad, because they can sometimes burn out the amplifier that powers the bulb, (which is a seperate piece that attaches to the outside of the Optic Block). My TV is like new now.
Dec 23, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Red and Green Lines in TV
The optics block has failed and it will have to be replaced. Contact Sony for an auth. service center in your area as the optics block in this unit has a 2 year mnfg. warranty.
Feb 16, 2008 | Sony KDF-E42A10 42 in. LCD Television
Panasonic PTAE 700U optical block
Are you referring to the bulb? If so it depends on total hours used...a common bulb use is 3000 hrs. That is if it has not had rough usage....which was the case with our projector at The Salvation Army Citadel / church. If the projector is turned off before properly cooling is allowed...the life span of the bulb diminishes quickly......God bless, Capt. Hannu
Dec 29, 2007 | Sony XL-2100U Projector Lamp for...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
498 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
