Question about Nikon D90 Digital Camera with 18-105mm lens
Assistance in using the P for taking pictures How do you use the dials to determine a good picture.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
The settings depend on what you're trying to say with the picture. You probably wouldn't want the same settings for a portrait as you would for a landscape. Two photographers at the same place and time with identical cameras probably wouldn't use the same settings, as each photographer has his/her personal style.
In the Program mode the camera select the shutter speed and aperture it deems optimal. You can turn the command dial to adjust the exposure, increasing the shutter speed and opening up the aperture, or decreasing the shutter speed and closing down the aperture by turning it the other way. Either way, the exposure itself remains the same.
If you're taking a landscape picture, you'd probably want a small aperture to get the maximum depth of field. If you're taking a portrait, you'd probably want a large aperture to blur the background. If you're taking an action picture, you'd probably want a fast shutter speed to capture the action. Of course, those are just guidelines. Sometimes you want to blur the action, or throw some portion of the picture out of focus. It's up to you. You use the settings to take YOUR picture.
Posted on Jan 09, 2012
SOURCE:
Very dark video output and view through the view screen, no matter where the ISO dial is set. The Auto, C1 and C2 mode for Photos is just as dark. I can take good pictures only in P (Program) mode, al
This is most often a problem with the imaging sensor and no reset is going to repair the part. Also, if replacing it, it needs to be properly calibrated after installed. If you need help with this, this is the place we recommend for the Canons: www.CamerasAndParts.com They are the best for these models, they only work on Canons and they are excellent for repairs. They have a service package for about $90 which takes care of an image problem as you have or you can try emailing them first. As far as service and the quality of work, I wouldn't go anywhere else but them for a Powershot. They are the best for these cameras. Good luck
Dec 20, 2014 | Canon PowerShot G10 Digital Camera
SONY DIGTIAL
You never should use the picture you see on the monitor of the camera. Not one camera has a calibrated screen. And the brightness is changed very easy in the setup menu.
To test if your camera shoots good pictures, select AUTO on the mode dial. Shoot some pictures and look on the PC or just print them.
Your camera has so many settings, that over rule the brightness when you switch to it, like + and - 2 EV setting. But when you chose for A, P, S, or M, the pictures can be to dark or to bright, if you dial in the wrong settings. So don't evaluate the pictures on the monitor. Only use the histogram on your camera to see if you have a correct, to dark or to light picture.
Jan 06, 2014 | Panasonic Lumix DMC-TZ3 Digital Camera
I can take a picture but its blurry
Set your camera to auto and try again. The setting you are using determines what your picture will look like. If you want to use other settings you should know how they work so you can get what you want. Otherwise set your camera to auto. You will find this on the small dial with the different settings indicated on it. If you do this and your picture is still blurry, then when snapping your shot, press the button slightly down (not completely at first) wait a few seconds and then press it down completely to take your shot.
Sep 13, 2009 | Sanyo VPC-S500 Digital Camera
Sony Cybershot DSC W70 Will not take picture it will only take video on still picture mode? How do I reset the settings
Did you ever remove the dial and put it back on?
Turn the dial to a different location and try to take pictures. try all the settings untill you get the correct one. Good luck
Jun 09, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Can't take good pictures with new Canon Rebel xsi
You will need to read the manual. I f you have a basic understanding of how ISO, shutterspeed & Aperture width combine to determine the 'right exposure.
Try this:
Set the camera to Av (aperture priority mode). Half press the shutter button and see the light meter indicator to see how well exposed your shot will be. For most cases you would be aiming for a value of 0 (properly exposed). The metering mode determines what part of the frame is used to compute the correct amount of light. For starters begin with pattern metering. Try and aim for a shutter speed of 1/125 or more if you are using the 17-55 mm EF-S f3/5-f5.6. Try and shoot at 40 mm F/5.6 (in Av mode this can be set by rotating the dial near the shutter button.
All the best
Mar 29, 2009 | Canon EOS Rebel XSi Digital Camera
Best settings for a concert w/Canon Powershot Pro1?
A few settings:
Set the ISO to 400. Set the light balance to TUNGSTEN... that will make the colors accurate.
and then set the dial to P and turn your flash OFF.
then when taking photos, be sure to hold the camera VERY STILL. movements are magnified while zooming so be patient.
Also take alot of pictures ... it's better to take alot and then be able to pick the real good ones and toss out the lousy ones..
Also, be nice to those nearby by turning the MUTE to ON in the menu...this turns off the beeps and clicks... You can also turn off REVIEW... and keep the display closed. This will make taking pictures quicker because you're not waiting for the display to review each shot.
Have fun...
Mar 13, 2009 | Canon PowerShot Pro1 Digital Camera
No Picture
1. If you are using TIFF mode for uncompressed images, the camera takes much longer to process the image because of the very large file size. It takes longer between shots and longer to play back a TIFF image. The TIFF setting on the camera Top LCD Display is 'No Stars' (One Star = Basic, Two Stars = Normal, Three Stars = High Resolution, No Stars = be patient for TIFF). Unless you are doing professional images, we suggest that you use the normal or high resolution JPG settings (Two or Three Stars / FULL) for good results. 2. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 3. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. 4. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Sep 15, 2005 | Toshiba PDR-M11 Digital Camera
No Picture
Sep 15, 2005 | Toshiba PDR-M21 Digital Camera
Review the pictures
Using the Quick View Button Press the QUICK VIEW button. The last picture taken is displayed. Use the arrow pad to display other pictures. Press the QUICK VIEW button again when you are ready to take another picture. Using the Mode Dial Turn the mode dial to the playback option (the green arrow). Use the arrow pad to navigate to your picture of choice.
Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
Review the pictures
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
Nikon D90 Digital Camera with 18-105mm lens Logo
44 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
