Question about Rival CZF630 Deep Fryer
Fryer cord gets really hot
I bought this in March of 2008.. The first few times I used it, it was fine, now, When I use it, the cord gets so hot I can't touch it to get it out of the plugin.. IS there a fix for this or do I have to just get a new one?
    Champion:
  • 254 Answers
This would be caused by an over current problem or in other words you have a device trying to use more power than its designed for. I can think of 2 things that might cause this one would be an element bleeding to ground the other may be an insulation breakdown in a wire or fitting. If you feel comfortable taking it apart you could look the wire and connections over very well and look for discolored areas which would indicate a hot spot or if you have a ohm meter you could also read resistance to ground through each lead, and through the element or elements.
Thanks hope this helps you.
Posted on Jun 14, 2008
Cord gets very hot on the outlet side, prongs will cause 2nd degree burns if touched, made outlet very hot as well.am certain it will cause fire inside wall if left on to cook with.
flyindawgs -
The unit is pulling more current than the outlet can handle. The unit runs at 1500Watts, or uses 12.5 Amps of current. Most outlets are rated for 15 Amps. It's likely that you have other outlets that also have devices plugged in to the same circuit. For example, having two or three outlets in a kitchen that are all on the same circuit, you might have more than one device running, and exceed the 15 Amps the circuit is made for. So, even though each outlet might handle 15 Amps on it's own before burning up, it's the total amount of current on the circuit that is the limiting factor (3 kitchen outlets wired together on a 15 Amp circuit can have any combination of devices plugged in and running at the same time, as long as the total is less than 15 Amps).
Having a cord turn warm or hot when in use is always BAD. You should try running the unit without running anything else on outlets in the kitchen. See if it still heats up the cord. Do not leave the unit unattended, and do not let it heat very far. Just turn it on and see if it starts to heat up. If it doesn't, you just have to make sure not to use other devices while frying, and you'll be fine (Running a 12.5 Amp device on a 15 Amp circuit normally would not be a problem).
If it does, there is a problem with the fryer or your household wiring. One of these two is compromised in some way (like a partial short or loose wire connection). Do you know anyone who can measure the current use on the fryer for you? Someone familiar with electricity should be able to help. Hopefully, the fryer is bad (using more than 12.5 Amps means it's got a problem), and not your wiring. If the fryer checks out okay, then your wiring is to blame, and you can't use the fryer on that set of outlets. That kind of leaves you out of luck, as I suspect that you don't want to deep-fry in the living room or the garage.
If the wiring is at fault, an electrician can fix the problem by re-wiring or adding more capacity to the circuit, or adding another separate circuit that you can safely use the fryer on. These are expensive solutions, so you may choose to simply do without the fryer. With luck, the fryer itself is malfunctioning, and replacing it will solve your problem.
Thanks,
videoman7
Aug 14, 2009 | Hamilton Beach 35030 Deep Fryer
Karaoke microphone and wireless mic
Cord rolling might generally cause damage to the internal wiring.the only possible repair option is change the wire inside.A suggestion is to try not to wrap the cord tightly with the microphone.fold it separately and use a band to hold it.
Dec 10, 2008 | LeadSinger LS-3222 Consumer Microphone
Replacement cord
It's probably dirty. Try saturating a cotton swab with rubbing alcohol, then swab the female end of the cord and immediatly push on and off the fryer pins a few times, then let dry and test. This should do the trick.
Jun 18, 2008 | Rival CF153-WM Deep Fryer
Quit working no power
IT could be a blown fuse , if your handy w/ tools or know someone who can fix anything , you need to open it and locate a fuse (a small glass tube) and replce it, hope it works , AJ
May 26, 2008 | Rival CZF630 Deep Fryer
Need replacement cord for rival CF153-WM
Check with your local service center to install new cord ( generic ).
Nov 02, 2007 | Rival CF153-WM Deep Fryer
Fryer problem
The problem is with your cordset if it is a DP16, Here's how to fix it.
Solution for fixing DP16 Cordset for GE deep fryers: To begin with, you willl need to clean the electrical contacts on both the fryer and the cordset. They will be burnt from electricity arcing between the two when the cord is plugged into an outlet before connecting to the deep fryer. I used a dremel tool attachement grinder used for sharpening chain saw chains. It is cylindrical and fits in the holes in the cordset perfectly. You could use sandpaper rolled into a small cylinder, or whatever is available that will do the job. To open the flaps that cover the holes, insert a toothpick in the center hole of the cordset while you work. Make sure that both sets of contacts are completely clean before proceeding with the next step. Next, using needle nose plyers, make two tight coils of fine or extra fine (.032") resin core solder the same size as the holes in the cordeset. Press into place in each of the holes in the cordset against the electrical contacts. Spread the coils a little so they cannot fall out when the cordset is not attached to the fryer because the flaps will likely not close properly or at all. You can work the coils down so the flaps will close if you use the .032 solder, but they will still be a little loose, so they might jam the flaps open or partially open. This definitly isn't a UL approved method, but it will fix the problem completely. Happy frying!
Oct 26, 2007 | GE 168952 Deep Fryer
Replacment cords
On 11/17/07 I posted my problem with this fryer. I did not get a solution so today I called the customer service number 1-877-207-0923 and Virginia (customer service rep) suggested that I order a new cord ($5.95 plus shipping of $5.95). I should receive it in 7-10 days by UPS ground shipping. My model # is #168997 cord # PL1215. I hope this helps.
Sep 15, 2007 | GE 168997 Deep Fryer
Cleaning
From http://www.rivalproducts.com/help.aspx?helpNav=1: How can I clean my fryer? - Unplug from outlet and allow unit to cool. Always turn control to OFF then disconnect plug from wall outlet BEFORE disconnecting BREAK-AWAY CORD. - Clean the outside of the fryer and lid with a damp cloth. CAUTION: Do not use abrasive pads or alcohol to clean the fryer. - Remove basket handle, if one is included. Frying basket can be washed in hot soapy water. - Rinse and towel dry carefully. - Pour out oil and discard properly. - Wipe the inside with paper towels to absorb excess grease. Wash interior of fryer with hot soapy water. Rinse and dry thoroughly. CAUTION: Never immerse the fryer in water or wash in running water. If you own a fryer with a removable bowl or other removable parts, refer to the Owner?s Guide for your specific fryer to determine which parts can be cleaned in the dishwasher.
Mar 08, 2007 | Rival CZF630 Deep Fryer
Rival CZF630 Deep Fryer Logo
117 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Henry  Thomas
Henry Thomas
Ric Shull
Ric Shull
Level 1 Expert
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
