Question about ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard
Audio deosn't work on mobo
The audio jack on my mobo (m2n-e sli) doesn't work at all, however the audio jack on the front of the case does work. any way to fix this so i don't have the wires running to the front of my machine? thanks, chris
  • dakota19762 Jun 08, 2008
    thanks map9966, but i guess i should have said that i connected the jumper pin leading from the case to connect to the mobo. the manual said that this would act as the correct jumpers. the case is a Rosewill R5601. i did what it said to do. should i disconnect the clip and reinstall the jumpers? if so, how will i be able to use the jack on the front of the case? thanks ahead for any help!!! chris
    President:
  • 2,351 Answers
Hi Chris, the problem can be one of two issues. If the sound jack located at the back of the PC did function at the same time as the front case sound jack. Than the problem is the jack it's self is bad. (Back of PC). Someone had to hook up the front mic & sound jack to the motherboard. So disconnecting the front sound & mic may give you rear sound & mic.
Turn to page 2-29 in you're user manual for the Asus M2N-SLI. The pic shown is the default setting for the front case audio & mic. (What you do see are the two jumpers connected). So disconnect any connector & place a jumper over pins 9 & 10, (last two pins at the right of the two rows of pins). Place another jumper over pins 5 & 6.
Pin 1 is the first pin on the left bottom row (MIC2). Pin 2 is the first pin, left edge top row (AGND). Pin 8 is not installed but you still count its spot as if there was a pin. (This is how the board was setup from factory). Once you fix this you should regain sound & mic function at the rear of the PC. To fine tune the audio run the Asus sound effect manager. If you installed this software, (Recommended). If it’s not by you're clock than it’s in control panel.
Link to all for M2N-E SLI
http://support.asus.com/download/download.aspx?modelname=M2N-E%20SLI&SLanguage=en-us
Good Luck!
m
Posted on Jun 08, 2008
  • Mike Peluso
    Mike Peluso Jun 08, 2008
    Good point! I did have that in mind. Normally I would ask you to send me you're s/n & I would call Asus myself. It should function in HD mode for both, rear & front. It's the weekend on my end & I'll have to wait untill Monday to call Asus. If you wish to do so you're self this is their number: 1-812-282-2787 M-F 8:00AM to 5:00PM EST. You will need the S/N of the board. It's located on the LPT port, as seen only from the inside of the case. These call's are free for me. I still need the s/n to make the call.
    I'm pretty sure there is another adjustment that can be made but I'm getting too old & should type this stuff down more often.
    Sorry Chris!
    Mike
Need audio installer asus m2n-sli deluxe
If it is: M2N - SLI Deluxe:
http://www.asus.com/product.aspx?P_ID=szSFtrap7crpBaQE
if: M2N - SLI Deluxe/Wireless Edition
http://www.asus.com/product.aspx?P_ID=0jMy2X8lKstYRvev
select your OS
Aug 06, 2010 | ASUS M2N-SLI Deluxe Motherboard
Asus M2N-E SLI
In my experience, there are some fans that are loud. It could be bad bushings or possibly a fan that is out of balance. The Cool and Quiet utility will not solve that problem.
Are you sure it's the CPU fan?
If the computer (or it's parts) are less than a year old, they should be under warranty.
If it's the case fan, I'd replace it with either a new single-speed fan or one that has a variable speed adjustment.
Apr 06, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Soundmax microphone error
Check your front panel connectors are wired correctly :)
Nov 14, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS M2N-SLI DELUXE 2 hr "warm up"
Try changing the Motherboard battery it could be flat
Oct 31, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
NO video @ bootup
Are you sure that the memory you have installed is compatible with your motherboard.
It is weired but some memory do not work with certain motherboards, irespective of speed or voltage rating.
Aug 05, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
On board audio problem
Hi, do you have you're manual? The answer to you're questions are there.
There are three femal plugs on the back side of the motherboard for sound out-put/mic-output & sound in-put. There ia also the option (For most cases), front plugs. Sound = out & mic=out.
See page 2-22/2-23, for rear connectors (What goes where).
Goto to page 2-29 to see Front panel audio connector (10-1 pin FP_Audio).
If you do not have you're user manual you can download it from Asus. Click on the link below.
Have more questions? Please feel free to ask.
Good Luck!
Mike
May 02, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Video card
This may sound weird, but remove ram to make it 2 gigs and try it again, some mobo's have issues with 4 gigs. 3 gigs usually works too.
Apr 03, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Ethernet controller
1. Remove network card and see if restarts go away.
2. Remove all but one RAM stick and try it, swap that ram with one of the others and try again.
3. Try another power supply.
4. If windows was installed previously with old mobo, you may need to do a repair install of windows or wipe it and start over.
Mar 30, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Serious problems with an Asus M2N E SLI motherboard.
try the board with out memory and hard drive.
Do fans run?
Anything?
Nov 21, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Asus m2n E Sli board audio
I had the same problem, and it went away when I connected the the front speakers via the 'ac97' connector from the case, instead of the HD audio connector. It seems using the HD audio connector, as well as using no connector and forgetting to put back the jumpers originally set over 2 of the front audio connectors pins, will cause no audio from the back ports.
Oct 09, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Logo
386 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
