When powered on it makes breaking noise. No Display.
  • 36 Answers
Inspect your fans for clutter.
Posted on Oct 24, 2010
SOURCE:
Starter make bad noise and break the starter
Seems you might have got a starter with the wrong gear or the fly wheel gear is worn.
Mar 26, 2016 | 2003 Kia Sorento
Grinding noise lowering power window on 2002 m3
most likely the regulator. they use a cable, and once that cable gets kinked or frayed it will make those noises, and eventually break Removing BMW Door Panel Replacing Window Regulator
May 26, 2014 | 2002 BMW M3
Display panel not powering
Is there any noise when you switching on the machine similar to its ready mode noise,
Check machine by pressing Copy button to make copies if it copying and working means your display only faulty or...
If it is not copying or not working means it has problem in Main board check RAM and Boot Flash Rom
Check Boot Rom correctly may be boot ROM faulty
Feb 08, 2013 | Canon imageRUNNER C3200 Color Printer
Breaks grab and make noise and stop on a dime when you are barely touching the break
what kind of rig is it and does it have power brakes year make and model thank you
Sep 16, 2011 | Pontiac Sunfire Cars & Trucks
When i plug in my card and boot my pc, it makes a high pitch squeeling noise and ive added another power cable but it continues to make the noise, how do i remove the noise?
From my experiance it sounds like the power supply is still not providing enough amps for the card or that the power plug on the card may be bad and not allowing it to recieve the power it requires
Dec 29, 2010 | ASUS EAH5850 DIRECTCU2DI RADEON HD5850...
I have a 42" LCD Westinghouse Model# TX42F810G, it is less than 8 months old. I turned it on and it made a popping noise, now the screen has vertical red lines and it looks as though it was hit with a...
Sounds like the Display Cracked. This is not the first time I heard of a display breaking on Westinghouse and Poleroid LCD TV's as they are made in the same plant in China. Sorry to say a new display will cost more than a new TV.
Oct 09, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Noise coming from power steering
i don't think the brake pads would cause the problem have you checked the power steering fluid ??
Mar 17, 2009 | 2002 Ford Ranger Regular Cab
VW T4 2.5 TDI engine makes rattling noise no loss of power or smoke though, is it the tapetts the noise comes and goes
hi. that noise is the vacuum pump knocking. it should stop if you press the break pedal a few times or pull the pipe of the break servo. £120 on ebay half hour job to change
Mar 10, 2009 | 2005 Volkswagen Microbus
No picture or sound - TV makes chirping noise
The chirping sound is the power supply coming up then breaking down because there is a short somwhere in the high voltage. The most common fail in this area is the horizontal output is shorted ( 237470 ) but what cause this short could be simple cold solder joints or the High voltage transformer ( 239111 ) If you have noway to "ring" the flyback change both parts
Feb 13, 2008 | RCA Scenium D40W20 40" Rear Projection...
Blank infoglobe
Noise? Louder than normal motor noise? The display is created by the revolving LED board that is connected to a motor. It should be quiet unless you pick it up and give a good listen. Let me assume that you mean that it is normal noise, indicating that the unit is turning. Unplug the power as well as the phone lines from the unit. First, remove the plastic globe. There are 4 points that the globe is connected, two towards the rear and two in front on either side of the control buttons. Press the globe at the front ones and lift towards the rear. After you have removed the globe, remove the three screws that hold the rotor (looks like an "L") to the motor shaft. The LED display is soldered to the rotor. These solder joints break and need to be re-soldered. By adding a small amount of heat as you are bending the display slightly inward, you can repair the connections. Only use low watt solder gun! Re-attach the rotor and globe (unit will not spin with globe off) re-connect the power, press the select button and check out the display. If all connections were made, you will have succeeded. If a line or two are missing, try again!
Jan 26, 2007 | Wave Industries OLY-OL3000 Globe Phone
Open Questions:
Computers & Internet Logo
16 people viewed this question
Ekse
Alun Cox
