Question about Swintec 7040 Typewriter
Swintec 1146 ink ribbon has come loose. Can it be fixed or do I need a new cartridge? If so, how do I install it?
  • Swintec Master
  • 3,594 Answers
You may be able to get a manual @ Nakajima 800-809-7138 they made the sintecs.
DickyO
Posted on Oct 25, 2010
SOURCE:
How do i change the ribbon on Swintec 1146?
Swing the lever located below the ribbon carrier to the right to release the ribbon then lift up
Mar 03, 2015 | Swintec Office Equipment & Supplies
How do you make corrections on the swintec 1146 cm
Type a letter, press the key with the large X on it, if it dosen't correct but makes all the motions you probably have old supplies.
DickyO
Aug 07, 2014 | Swintec Refurb 1146 Cmp Typewriter...
How do I install the ribbon in the swintec 8014-S PLEASE HELP
Move the red lever to the front, lift out old ribbon, put in new ribbon putting it thru the 2 lifter arms, move the lever back.
DickyO
Sep 03, 2010 | Swintec Office Equipment & Supplies
Office jet 5510 keeps saying wrong black cartridge.
Look on the right side where the cartridge goes, if the spring on the right is hanging loose it might have poked a hole in the ribbon cable at the rear near the contacts. If so it's time for a new printer, if OK, check the exp. date on the ink cartridge and if it's been refilled or a generic ink you may just need another one.
Jan 30, 2010 | Office Equipment & Supplies
Bought used HP 2410 from Amazon. Unit is displaying print cartridge problem on far right cartridge. Unit came with ink cartridges installed and I notice ink has spilled. I performed a detailed cleanup but...
Remove the right cartridge and check if the spring on the right came loose. When it pops out of position it tears a hole in the ribbon cable at the back of the holder and then you need a new printer. If you can find a carriage assembly it's over $200.00.
Nov 25, 2009 | HP Photosmart 2410 All-In-One InkJet...
Change a swintec 1186 typewriter ribbon
Move the red lever to the front of the ribbon, remove it, drop the ribbon in place, be sure it goes thru the feed roller on the left, move the lever back, done.
DickyO
Oct 26, 2009 | Swintec Office Equipment & Supplies
Typewriter - Swintech 2640
Sounds like you need a new ribbon or you are using non-Swintec compatible ribbons that are not properly aligned to your ribbon feed. Try using Swintec brand ribbons and see if this still occurs. Worst case scenario, you need to have your ribbon feed adjusted at your local dealer.
Jay @ www.granadahillsbusinessmachines.com
Aug 08, 2008 | Swintec 7040 Typewriter
Ribbon retainer clip installation??
Possibly came from the ribbon cartridge. Try another ribbon.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Mar 27, 2008 | Swintec 7040 Typewriter
Brother intellifax 770
Winding technique:
To wind a new ribbon, take the cartridge housing apart and remove the old ribbon and two cardboard cores. The new ribbon is fitted with the larger roll (the ink ribbon supply spool) at the rear side of the cartridge (as the housing is viewed when it is normally installed into the machine). The ribbon winds over the topside of the rear spool (the supply side) and feeds into the underside of the front spool (the take-up side). Make sure the ribbon is wound neatly, evenly and is tight. If the ink film has become detached or is too loose on the front spool it will not wind on and cause a machine error. If required, use a small amount of sticky tape to secure the ink film to the front cardboard spool and then neatly wind it on to the take-up spool a minimum of five turns, making sure the film does not overhang at the edges. Now reassemble the housing and refit into the machine.
If it’s still not fixed:
If problems persist after fitting a new ribbon, try replacing the entire ink ribbon unit (cartridge housing + a new ink ribbon) using a new, genuine Brother unit before requesting a service; this will be less expensive as the actual housing may have been damaged and is causing the problem and this unit is readily available as a consumable item through sales outlets. If the machine still has problems, book your machine in to be repaired with an authorised Brother Service Centre.
Feb 25, 2008 | Office Equipment & Supplies
Ribbon empty
Winding technique:
Feb 17, 2008 | Brother FAX-575 Plain Paper Thermal
Swintec 7040 Typewriter Logo
108 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Adorjani Laszlo
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
