Question about LG LWHD1800R Wall/Window Air Conditioner
Lg lwhd1800 turning itself on when powered down - which PCB assembly: main or timer board to replace?
SOURCE:
SOURCE: I have a LG LDF6810ST dishwasher with a tE error
Follow up to previous post.I replaced my sum seal and other nec. gaskets and reassembled.The TE code is gone and dishwasher performs as designed.I hope this helps someone with one of these POS dishwashers.Thanks
Posted on May 29, 2009
SOURCE: My LG Tromm WM2277HB washer shut down during a
Well I for one would go along with your prognosis, it seems logical to me.. this IS a common occurance when this type of thing, a power surge happens.. Remember Occam's razor.
Posted on Feb 05, 2010
  • 401 Answers
SOURCE: I have a LG electric range (LRE30453ST) that is
f-1 meens stuck key pad. if you are holding down this is normal. touch it once then cook
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Posted on Mar 06, 2010
  • 10865 Answers
SOURCE: LG WASHER WON'T Power on
Hello. If the lid switch is defective, your washer may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Posted on May 24, 2010
SOURCE: LG LH2000 turns off everyday at 10am.
I called LG and I have a technician coming over for this exact issue. Model 55LD650. But my unit is mounted pretty high up on a wall, do I need to take it down for the technician to work his magic on the "engineering settings". Any tips on what exactly I should tell him to save both of us time? Thanks!
Posted on Sep 27, 2010
I have an LG RU-42PX11 plasma tv. A couple weeks ago we heard a pop and the picture went blank. I can still change channels via cable box and I have sound but no picture.
6871QCH034A PCB ASSEMBLY,DISPLAY CTRL ASSY 42V6 NEW MCM(1222) LVDS
202 6871QDH066A PCB ASSEMBLY,DISPLAY YDRV ASSY 42V6 YDRV TOP ASSY
203 6871QDH067A PCB ASSEMBLY,DISPLAY YDRV ASSY 42V6 YDRV BTM ASSY
204 6871QLH034A PCB ASSEMBLY,DISPLAY XRLT ASSY 42V6_XL(4LAYER)
205 6871QRH037A PCB ASSEMBLY,DISPLAY XRRT ASSY 42V6_XR(4LAYER)
206 6871QYH029A PCB ASSEMBLY,DISPLAY YSUS ASSY 42V6
207 6871QZH033A PCB ASSEMBLY,DISPLAY ZSUS ASSY 42V6
These are the part numbers for all the boards that deal with the display. Im leaning towards the sustains as well and you need to do both at the same time cause if one is bad and you replace just one, a bad one can fry the new one.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jan 20, 2017 | LG Televison & Video
DE error code on LG washing machine
Beyond that could just be the door latch itself.
Nov 23, 2013 | LG WM-2277HW Front Load Washer
Lg network 3d blu ray home theather model# lhb336 problem/boot and please wait
Check working condition hardware. May be malfunction Main Boar or AMP. Unplug cable (wires) attached from Power PCB Board and main board to AMP PCB Board. Turn ON, if again comes message " Please wait" and unit sot down itself- Malfunction main board. If unit booted UP -OK -replace AMP board. Parts are available on our web
Dec 12, 2012 | LG LHB336 3D Wi-Fi Ready Bray Home Theater...
LED LCD. Is the Main PCB bad?
I'd try the main, its about all that is left if the rails are all good on the power board.
Feb 04, 2018 | LG 55LX9500 55 in. 3D HD-Ready LCD TV
Replacing main total assembly LG HGTV
Replacing the main PCB is actually very easy just a few screws and a few wires and the circuit board pops right out. If you need a replacement main board I am sure you can get one from www.tvrepairworld.com with free installation assistance if you require it
Jan 28, 2012 | LG 42LC2D 42 in. LCD HDTV
LG dryer DLE 3733S control panel inop but light on in drum. 3 years old intermittent problem, is this electronics panel going bad? if so, do we replace PCB Main or PCB Assembly? Thanks!
Check the power to the display panel after you have it removed. If there is no power check the lines to the control, If the power is present with no action on the panel then you will have to replace the board. It may be as simple as cleaning the board off, since it has been a intermittent problem in the past. hopes this helps Tim
Nov 25, 2010 | LG DLE3733 Electric Dryer
LG Electric Dryer DLE2515S - dryer timer is stuck on 6 minutes and continues drying until I manually switch off - sensor dryer does not appear to be working either.
OK, test the dryness sensor for its operational value. if the test confirms sensor function, you will need to replace the main PCB board in this case.
Now, if the sensor test reveals a faulty sensor device, simply replace the sensor. In most cases, this iwll be a fualty PCB main and, replacing it will usually fix this issue.
Jun 01, 2009 | LG DLE2515S Gas Dryer
Hi shawnn,i'd like to know the if it's only power supply faulty and i need the board #?thanks man.
have the same problem and already replace ps from fleabay and still dead , looks llike the problems is on the main board.
Apr 09, 2008 | LG 37LC7D 37 in. LCD HDTV
Heating & Cooling Logo
90 people viewed this question
Top LG Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Steve F
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
