Question about Soyo Dymond DYLT032A Television
I have problem with my Soyo 32" (DYL T032A). Fuse in the power board has blown. I tried to replace the fuse with a new 6.3A/250V (same that was in before) but it keeps blowing as soon as I press the power button. Any suggestions? Would it be better to use a 7A fuse?
2 Suggested Answers
SOURCE:
budmrtn
  • 11361 Answers
SOURCE: Need code for a comcast remote to control a Soyo
You can download the user manual for your remote here: you may have to use search your code function if your TV is lot listed. http://www.comcast.com/corporate/customers/customer_support/remotes.html
Posted on Nov 18, 2009
Do i have a blown fuse if I am checking 2 small fuses that are on a circuit board. one is 1.6 amp 250v and the other is 160ma 250v and the 160ma fuse is the one testing 1.4 and the 1.6 amp fuse is tes
They have a restorside, a bit , that's why you have fast and slow fuses. But if they were dead, then the resistant would be infinite, so
no problems with both fuses.
gr. Richard
Sep 12, 2014 | Roland Cube Street - Battery Powered...
Can power on
Check the fuses.Blown fuse conditions
FU1 - 6,3A Doors/covers open is displayed.
FU2 - 6,3A Doors/covers open for the finisher is displayed.
FU3 - 4A paper end condition.
FU4 - 6,3A SC 121 is displayed.
FU5 - 6,3A one of SC302 or SC403 or SC405 is displayed.
FU101 - 15A no response.
Fu 102 - 8A no response.
FU103 - 1A normal operation,optional heaters do not work.
If FU or 102 is the problem,verify the main motor and the fusing unit heater lamps and thermofuses.After change the problematic fuse removal the fusing unit and turn ON the copier.
Apr 18, 2013 | Ricoh Aficio 450 Copier
Crest audio ca4 blowing fuse
There is two possibillities to fuse blown off due to hi current flowing through fuse more than 3amp.because power supply componant like rectifying diode, filter capacitor or regulator ic ,regulator transistor shall be short circuited.
if you are tech......just remove amp. supply.from main power supply...try with another fuse........if fuse ok, fault is amp side, or if fuse blow off ...power side problem just....maximum fault comming on varistor ,diode, filter capacitor, .........
if you are not tech......... give to local authorised tech.......
Feb 04, 2018 | Crest Audio CA4 Amplifier Amplifier
Fuse blown on incoming power replaced fuse but no luck
replaced the t8ah 250v fuse and it still blow when i turned on the tv
Oct 19, 2010 | Panasonic Viera TH-50PX80U Plasma TV
I ahve a SOYO LCD model DYLT032c, the set will not power on and the power led does not light
1. This may be a fuse blown in the start up circuit or a rectifier diode at the AC input ( the primary side ) side of the main board.
2. In any case this will require a testing of components at the power supply of the main board by a qualified tech. A schematic is require to trace all defective components and replace them about 1 to 2 hours to isolate and repair.
Apr 29, 2010 | Soyo DYLT032C 32 in. LCD Television
My soyo shut off and won't come turn back on
It seems like the fuse has blown on the power board inside the tv, to get at it you will have to remove the back cover, the power board should have a fuse on it somwhere have a route around and you will find it, pop it out of the fuse holder and take it to your local electrical appliance store and they should be able to get one for you, they are only cheap.
Feb 05, 2010 | Soyo DYLT032D 32 in. LCD Television
Need code for a comcast remote to control a Soyo DYL T032A
Nov 18, 2009 | Soyo DYLT032D 32 in. LCD Television
Fuse Blowing in Power Supply SOYO MT-GW-DYLM24D6 24
If you can solder connectors you can build your own power supply for SOYO. Try the following link or google "gbyer external power supply".
http://slickdeals.net/forums/showthread.php?t=1655449&page=5
Replacement power supplies were avilable recently but it seems they are all depleted.
Nov 06, 2009 | Computers & Internet
Electrolux oxygen 3 fuse
The fuse on my ELECTROLUX Oxygen3's sumo board did have clear markings: F5AL250V - this is a 5A/250V 20mm fuse made by BEL FUSE, however, any other such fuse should work. The fuse on my board was blown (luckily, what caused it seems to be a glitch as replacing the fuse was all that I had to do). I got 5A/250V 20mm fuse from RadioShack and, expecting that this could happen again, I also installed a simple (5A/250V-rated) automotive fuse holder (also from RadioShack) (the only fuse holder that was available at a local store) and it works wonderfully now. Should the fuse blow on me again, I should be able to replace it in less than 3 minutes.
Feb 03, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Soyo Dymond DYLT032A Television Logo
59 people viewed this question
Top Soyo Televison & Video Experts
Marvin
Marvin
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
