Question about Brother MFC 7420 All-In-One Laser Printer
Bad copies and prints after changing the drum and toner cartridge
We recently replaced the drum and toner cartridge and everything that prints has lines and blotches on it. I don't know what caused this. It didn't happen immediately after replacing the drum and cartridge, several weeks later. Any help would be appreciated. Thanks Jeff
  • a_windisch Jan 05, 2009
    i have the same problem and yes I have cleaned the wire. I feel like I wasted as much as it would have cost to get a new all in one. Is there anything that can be done without buying another drum?
    Novelist:
  • 105 Answers
Did you clean the corona wire when you replaced them? Even with the Drum being brand new, you still need to run the little piece of blue plastic back and forth across the wire that is called the corona wire. If you don't know where that is, and do not have the complete software for your printer - you can find that at the link I have provided below. The short version is that it is just in front of the toner cartridge on the drum housing. If you do have the software, open the user manual and look for the table of contents listing that refers to replacing toner and drum cartridges. This will show you a picture of where the corona wire is.
http://welcome.solutions.brother.com/BSC/Public/Templates/DownloadTop.aspx?NRMODE=Published&NRNODEGUID=%7b2C7B4D65-D5B3-47BF-958E-322BE5EFDCA8%7d&NRORIGINALURL=%2fbsc%2fpublic%2fus%2fus%2fen%2fdlf%2fdownload_top%2ehtml%3freg%3dus%26c%3dus%26lang%3den%26prod%3dmfc7420_all&NRCACHEHINT=NoModifyGuest&prod=mfc7420_all&reg=us&c=us&lang=en
Posted on Jun 18, 2008
Printer wants toner cartridge replaced, though not empty
unfortunately the drum within the cartridge has reached end of life so changing to a new drum cartridge would resolve this issue.
Mar 25, 2010 | Panasonic KX-FLB801 All-In-One Laser...
Brother MFC-7420 just started printing a shadow image
Sounds like a bad drum cartridge. Pull the toner/drum cartridge out of the machine and set it down. Press down on a (blue?) tab to release the toner cartridge, and you can lift the toner cartridge out of the drum cartridge. There is a cleaning blade in there - a soft plastic blade that rides against the drum and scrapes off toner that didn't get transferred to the paper. If it gets stuck off the drum surface, images repeat a few inches (one drum circumference) down the page.
A new DR-350 drum unit should fix it. have the machine's power on when replacing it. While the door is open, touch the CLEAR key. The display will read "REPLACE DRUM?" or something like that. Press 1 for Yes.
Jan 05, 2010 | Brother MFC 7420 All-In-One Laser Printer
Brother MCF-7340 first time toner replacement
If this model comes with the drum separately of the cartridge, only replace the cartridge. There's no need to change it every time. until prints start to get lines or dots. Don't expose the drum to light too much.
Jul 30, 2009 | Brother MFC-7340 All-In-One Laser Printer
Lines in printed copy on Ricoh CL3500N
Depending on the age of the model, it could be a couple of things. ***Never touch the drum or expose it to bright light*** The drum unit is bad. It's the shiny brightly-colored large roller in the center of the machine. On most recent smaller machines like this on it's integrated into the toner cartridge. Check it out. If it has toner build up on the ends, it's bad. or The corona wires need cleaning. Some machines have a small slide that moves from one side of the printer to the other which cleans the hidden corona wires. It's usually brightly colored. The corona wires are also integrated into the toner cartridge in many smaller machines
Jun 05, 2009 | Ricoh Aficio CL3500N Laser Printer
Recently changed the black toner cartridge in the Dell 3110cn printer. This past week when I print the entire page is being printed with a shade of gray. I think the toner cartridge has leaked toner and...
This could be a drum problem, the drum is part of the toner cartridge in this printer.
If the toner has leaked it will be all over the inside of the printer - you'll see it. I don't think that's the problem.
If the toner cartridge is an original Dell item, then it's likely to be replacable under warranty.
If the cartridge is a remanufactured item, it may be that the wrong toner has been used. Toner is NOT all the same, and this cartridge is one whe the wrong toner really will not work properly for long.
The chances are the changing the toner cartidge will cure the problem, provided you use an original Dell item, or a remanufactured item from a reputable manufacturer.
Apr 19, 2009 | Dell 3110cn Laser Printer
HP 2600N PRINTS A BLACK LINE VERTICALLY ACROSS THE PAGE (FROM TOP TO BOTTOM) RIGHT IN THE MIDDLE EVERYTIME YOU PRINT SOMETHING . WHAT COULD THIS BE? I HAVE CLEANED EVERY DRUM, THE FILM ETC AND IT KEEPS...
You either have a defective black toner, a bad fuser or transfer belt. From my experence it is usually a bad toner cartridge. After you print a couple of pages, pull the black toner and see if there is anything on the drum. If there is try shaking the toner, sometimes toner does like dirt and clogs up. If you still have problem you will have to try another toner. I know that is not cheep, but I don't know any other way.
Mar 02, 2009 | HP Color LaserJet 2600n Printer
Bad photo quality after changing drum
your laser printer
1) print color quality is now distorted that means print skew (technician called)
2) print tint means the print color not enough density,
3) print mottle means print dirty
you may try
1) print distorted--- find out the skew adjustment from your printer manu, it is adjust the image before transfer to the drum.
2) print skew could be happened when the drum replace install not very accurate, so install it more carefully.
3) print tint---you may increase print density from the manu, not fix,
4) print tint---the toner caridge near life cycle or using the less compatible toner. so you have change the quality toner or cartridge (if near life cycle) to improve quality photo print
5)print mottle---toner quality ? or cartridge near life cycle also cause print dirty paper,
Feb 08, 2009 | Konica Minolta magicolor 2300DL Laser...
Prints completely black page when copying.
hello! are you usinga brother oen toner and drum cartrdige? that is the first thing to try, you are welcome to post back to me for additional help good luck brother tech
Jan 22, 2009 | Brother IntelliFax-2820 Laser Fax
Not printing
if the paper is coming out blank then there is a problem with the Primary transfer.
this is located on top of the drum, it is a thin wire that charges up to make the copies, it may be broken not sitting correctly or bad.
take out the drum and look for a thin wire that is on the top of the drum,if you cannot find it replace the drum
Dec 02, 2008 | Sharp AL-1655CS Copier
Large grey streak down center of page
It is the fuser at rear giving you grief! The upper heat roller has a teflon coating that wears away allowing toner to stick to roller and smudgin prints as they pass threw it. The fix is to replace fuser assembly, take to brother dealer to fix.
You can prove it to yourself by timing the print to stop mid way threw machine then remove print cartridge and look at paper, you should see a image is good untill it hits the fuser,( pre fused image "rubs off" paper.) If you have changed drum and toner thats all it can be. They all do it in time.
Fuser is hot bit at rear, pull out drum and look in the back with a small torch you will see upper heat roller is worn, guestimation $90 for fuser plus labour to fit.
Nov 16, 2007 | Brother IntelliFax-2820 Laser Fax
Brother MFC 7420 All-In-One Laser Printer Logo
250 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
