Ok so i want to put a dual-core processor in to my compaq presario sr1620nx 2005... but i dont know if this is possible.... anyone knows if i can or cannot. i need a 2.5 ghz to play SC2 so im desperate haha
    President:
  • 2,992 Answers
The specs for the motherboard used in this computer are here. It's a socket 939 board, which is outdated now and there aren't a lot of processors available. Here's one, but it doesn't get the 2.5 GHz speed you want. So the answer is yes, you can install a dual-core processor, but you probably shouldn't.
You would be better off to replace both the motherboard and processor together so you can pick from current processors. Here is a typical combo offer with a 3.0 GHz dual-core that is only about $20 more than the processor linked to above.
The downside to upgrading this way is that you normally can't stop with just the motherboard and processor. Your current memory won't fit on the new board, so that'll need to be replaced. Then you'll need to replace the power supply as well. The supplies used in machines like this Presario don't offer the capacity the new board and processor need for stable operation. And finally, if you're an avid gamer, the built-in video is usually inadequate. You'll be looking at a new video card too.
At least the case and peripherals would still be useable, so you can put all your new parts into your current box. Unless you want something flashier to go with all the new innards. You'll also need to reinstall Windows, since the current installation probably won't run on the new system. A fresh installation would be the fastest way to get up and running. This means hunting up a Windows CD for the version currently running; at least you can reuse your product key, although you'll almost certainly wind up activating Windows over the phone. (My experience has been that when using the OEM key with such a new system, the Internet activation usually fails. The automated phone system asks you how many computers you're running this copy on, so you can just answer "one", which is the truth.)
Maybe not what you wanted to hear, but this is the way to get a machine that will do what you are looking for. Thanks for using Fixya!
Posted on Oct 24, 2010
  • 2,571 Answers
You CPU should be powerfull enough, it is a 3400+ running at 2.2ghz (this is equivalent to a 3.4ghz intel cpu). Your problem will be your onboard graphics, you will need far better graphics to play modern games. Your board has a PCI express slot to fit a graphics card. About £40 to £50 will get a card that will play most games.
SOURCE:
When cleaning my compaq presario sr1620nx,I removed the cpu fan& everthing behind it. Now that's the only thing that works. What the heck!!?
A) Did you FOLLOW Anti-Static Procedures?
If you are not aware of Anti-Static Procedures post back in a Comment.
B) Did you bump a Ram Memory module ('Stick') loose, or more than one?
Following Anti-Static Procedures, remove all Ram Memory modules, and clean the gold plated contact pins with a pencil eraser.
There is a procedure for this; if interested post back in a Comment.
To KNOW that the Ram Memory module/s are seated correctly, and tightly; is to remove it/them, and reinstall.
This way you are Assured. Visual inspection alone will NOT do.
Plus you have cleaned the contact pins at the same time.
C) Power Supply's are evil..........
They wait until that ONE unsuspecting moment, and when your back is turned they shoot [email protected]
At least that is the way I'm sure it appears to some people
LED's light, and fans spin?
I don't care
A) If ALL of the LED's were lit up at once, they would use less than 1 Watt of power
B) EACH fan uses 2 to 3 Watts of power
C) A typical Processor (CPU) can use Up To 130 Watts of power.
Just depends on what Processor it is.
HP Support > Compaq Presario SR1620NX Desktop PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=1127351
Product information > Product specifications > Compaq Presario SR1620NX Desktop PC Product Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00472092&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=1127351
Processor (Base Processor):
AMD Sempron 3400+
(2.0GigaHertz)
Motherboard uses the Socket 939 processor socket.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00378480&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=1127351
http://en.wikipedia.org/wiki/Socket_939
Cuts the list down to one..........
Palermo Core technology, and the 90NanoMeter architecture,
http://en.wikipedia.org/wiki/List_of_AMD_Sempron_microprocessors#.22Palermo.22_.28Socket_939.2C_E3_.26_E6.2C_90_nm.29
Up To 65 Watts
Static shocked?
Not much to say
Ram Memory procedure didn't do the trick?
Then suggest checking Power Supply,
Or using a temporary Power Supply.
To check is to test the 3 main voltage power rails, with a multimeter set to DC Voltage;
OR,
See if there is a KNOWN to be good, Compatible power supply you can use for a temporary test unit.
NOT stating rush out, and buy a replacement unit.
Stating test first.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 04, 2013 | Computers & Internet
Driver audio HP compaq presario SR5350F pc Intel pentium dual core
You can download the audio and device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Feb 25, 2013 | HP Compaq Presario SR5350F Desktop PC...
I have a persario sr1620nx, the on board video went out, i need to install a video card, but i do not know what type to buy? looking for assistance. please help
Go to this website for specs.
http://reviews.cnet.com/desktops/hp-compaq-presario-sr1620nx/1707-3118_7-31589079.html
There's also an x16 PCI Express slot for users who want more graphics horsepower than the onboard ATI Radeon Xpress 200 chip affords.
Feb 08, 2011 | HP Compaq Presario SR1620NX...
Ok so i want to put a dual-core processor in to my compaq presario sr1620nx 2005... but i dont know if this is possible.... anyone knows if i can or cannot. i need a 2.5 ghz to play SC2 so im desperate...
OK, if your laptop is the one on this web page
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00472092&lc=en&dlc=en&cc=uk&destPage=document
then it has a 939 Socket and an explanation of which processors that will fit your motherboard are detailed at this web page
http://www.socket939.co.uk/socket939_amd64.htm
without knowing whether you bios supports a dual core processor looks like the Athlon 64 FX at up to 2.8GHz will suit your needs
If this helps please rate me
Oct 24, 2010 | Compaq Computers & Internet
Pentium 4 upgrade
The Compaq Presario SR2011WM supports following processors:
CPU/Processor
  • Socket: 775
  • Supports the following processors:
    • Pentium D 900 series Dual Core (Pressler, 65nm)
    • Pentium D 800 series Dual Core (Smithfield, 90nm)
    • Pentium 4 601 series (Cedar Mill, 65nm)
    • Pentium 4 600 series (Prescott, 90nm)
    • Pentium 4 500 and 501 series (Prescott, 90nm)
    • Celeron D series (Prescott, 90nm)
Hope it helped.
Nov 19, 2009 | HP Compaq Presario SR2011WM PC Desktop
Pentium 1.80 or pentium 2.8..I just recently got hired and I was told I need Pentium (4) 2.8 GHz or equivalent. I have Pentium 1.80 GHz (the numbers are confusing me once again)...thank you!
The Compaq Presario SR5410F has a dual core processor running at 1.80 GHZ
Dual core means that it is actually two processors running at that speed so you easily pass the Pentium 4 2.8 benchmark as shown in this table. the E2160 processor is not shown but the E2180 is close enough for you to get the idea compared with the lowly P4 2.8
Nov 02, 2009 | HP COMPAQ Presario SR5410F Pentium...
I would like to dual boot linux on my xp with sp2 i dont know wut bios i have or mother board but i have a compaq presario SR5310F processor intel pentium Dual-Core E2140 i need to figure out if my bios is...
yeah it should be okay, just get a linux cd like susie or ubunto and makesure you have another partition to run it on , however you can run it without installing it just playing it from a CD. I suggest you go to this link for more info:
http://www.linux.org/docs/beginner/install.html
Mar 02, 2009 | HP Compaq Presario SR5350F Desktop PC...
Want to up grade my cpu and ram to improve speed and program use.
Question#1 is my current processor duel core or single core , how can I know?
Intel Celerons are Single Core. You can also download and run CPUID (free) from http://www.cpuid.com/ No installation needed either , just run it!
Question#2 What kind of duel core processor in combination with new ram should I install?
I dont think your computer supports dual core. I cannot be sure without you giving me the make and model of the motherboard. Besides , a 3.33ghz Celeron D is a great processor!!!!
Memory - See http://www.crucial.com/store/listparts.aspx?model=Presario%20SR2150NX you can have a max of 2gb. You have 2 slots on the motherboard so its 1 gb per slot and the board takes DDR2 PC2-5300.
Here , you can expand to your max of DDR2 PC2-5300 2gb (2x1gb) for $24 and theres free shipping too!!!
http://www.crucial.com/store/mpartspecs.aspx?mtbpoid=03AC4AE5A5CA7304
Jan 07, 2009 | HP Compaq Presario SR2150NX PC Desktop
Computers & Internet Logo
Ekse
Alun Cox
