Question about Compaq Presario M2000 Notebook
Add a processor.
How do I remove the back of my laptop to add a processor?  I have already unscrewed all the screws.
Manual at http://h10032.www1.hp.com/ctg/Manual/c00444840.pdf
Posted on Sep 20, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Need to also unscrew screen and then take of key board then remove hard drive then remove caseing on top make sure all screws are removed the top and bottom of caseing and you should see your cpu it looks like a long coppery pice with fan connection then remove three or four screws and threr you have it
( make sure when reconnecting cpu you add some cpu paste for connection) put all back in and it should work good luck and take it slow ! put your little screws ina samll bowl or contaner so you don't loose them ok if you have trouble get back with me ok lala linda
Posted on Jun 07, 2008
My computer just went belly up! It is a reconditioned IBM ThinkCenter, a little over 2 years old. It was running normally and then all hell broke lose, cooling fan went berserk sounding like a hair dryer...
you need to clean the heatsink of the processor remove it from the motherboard by turning the lock to counter clockwise to 90 degree only all four lock then pull it up gently check for the thermal paste if it is dry you need to add a new thermal paste before you add make sure that you clean the back of the processor or remove the old paste that already dried out, just a small amount you need to apply, then before placing back the heatsink to the processor make sure you already turn the lock to lock position by turning it clockwise 90 degree then make insert it correctly to the four holes in the motherboard then press the lock down slowly to lock one by one,
Aug 04, 2011 | IBM Computers & Internet
Add more ram
hi-
To add ram - look on the back of the lap top. You will see some screws that are holding down a little door. There may be two of these. Remove the screws on the ram cover and remove ram cover
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ram slots are stacked. you have to remove the top one first.
1- press the buttons on the sides of the ram chip, and then it will pop up and towards you.
2- 2- pull this ram upwards and out
3- from there, you can take out the other chip, if there is one, or you can start installing.
4- installing the new ram chips is just as easy
5- line up the slots in the chip, then push it in as far as you can without breaking it.
6- then push it down so that you hear it click on both sides, and doesn't budge.
7- Repeat using the top chip.
This should do it –
I hope it helps- please rate me – thanks
G
Mar 18, 2010 | Acer Aspire 9500 Notebook
How to open Toshiba R25 Series Keyboard
t isn't that bad... The top strip comes right off if you pull up per the M400 manual. Unscrew the two keyboard screws and pull the keyboard (slowly) toward the monitor to give you some slack in the ribbon cable. Then fold the keyboard back over the touchpad. Unscrew the two screws holding down the metal panel in the middle where the keyboard is (be careful - they were very tight for me and I stripped one of the screws).
Put in your DDR2 4200 memory and be off and away...
Aug 02, 2009 | Toshiba Satellite U305-S5097 Notebook
Need to add oil to the steering wheel system
1st of all, it's not oil, you need power steering fluid. Don't put anything else in it or you'll mess it up. 2nd, how do you know you need fluid? If you found the power steering pump and unscrewed the cap and looked inside, you've done 90% of the work already. Now just add POWER STEERING FLUID a little at a time and then screw the cap back on. Then take the cap back out and look at the stick that's on the cap. There is a line on the stick that tells you the correct fluid level. DO NOT OVERFILL is probably stamped on the cap as well. Heed this warning or you have a mess.
May 27, 2009 | 2006 Volkswagen Passat
How to install additional toshiba a65 s1762 memory
Yes, you need to flip your laptop over and look for a removable compartment that requires you to unscrew a screw. Once you get the cover removed, you will see slots with either one or two memory modules installed. If one is installed, then you can add the additional memory module in the empty slot. If you have 2 already installed, then you will need to remove one and install your new module, which would only give you a total of 768 megs. Just slip the new memory in and press it down towards the motherboard and start your laptop..
May 16, 2009 | Toshiba Satellite A60 Notebook
I was about to install a PCI sound card TM P1018 in my cpu. How will i do it?
Shut down the computer. Unplug machine Disconnect all peripherals from the computer. Remove the cover of the chassis and lay computer on its side if it is a tower. Remove the back panel, if necessary. Locate the existing sound card if there is one already installed. If it is screwed in on the side of the slot hole, unscrew it and pull the card out firmly. 8If the computer doesn't already have a sound card, find an open slot. 9Knock out or unscrew the metal plate on the card's slot holder on the back panel. Step10Insert the sound card gently but firmly into the slot. Rock it into position if necessary, but don't force it. Don't touch any connectors on the card. Step11Connect cables from the CD-ROM drive to the sound card. Step12Replace the back panel and any removed screws. Screw sound card into slot holder if it has a screw hole. Step13Reconnect monitor, keyboard, and mouse. Connect speakers to the sound card's ports. Step14Turn on the speakers and restart the computer. Step15If Windows detects the sound card upon startup, follow instructions to install the card's driver and additional software. If Windows doesn't detect sound card, manually complete the installation using the Add New Hardware control panel. Step16Play music CD to test sound card. Step17Shut down computer. Step18Replace cover of computer. Reboot computer.
Apr 24, 2009 | Computers & Internet
How to install additional memory for Sony laptop
Here is how to add or replace memory for Vaio T300 series laptop.
Scroll to page 122 for slot on the bottom of the laptop,
Scroll to page 125 for slot underneath the keyboard.
Mar 28, 2009 | Sony VAIO VGN-T350P/T Notebook
How to put new shaft on cuisinart food processor model DLC-7E
Initial disclaimer: I am not recommending this course of action - my recommendation is to buy a new food processor. These units weren't designed for DIY repair, so this is going to be a difficult task. The final product probably isn't even going to be pretty. You are well out-of-warranty, or I wouldn't even consider posting this. First, make sure you have a DLC-7E shaft - the only way to get one at this point would be to buy a DLC-7E base from eBay or an after-market seller, as all of these were manufactured well over 20 years ago. I don't currently see any eBay listings for one, but they do crop up from time-to-time. Make sure the DLC-7E you are repairing and the old one from which you are wrenching the old shaft are unplugged and have been unplugged for an hour or longer just to be on the safe side. Unscrew the four screws on the bottom of the base on both units. If the bottom base does not come off after this, carefully pry out the four feet and unscrew any hidden screws that might be hidden underneath the feet (Careful - original feet cannot be ordered by normal means, and damage will only add to your total repair cost). Take note of the guts on the inside of both food processor bases - if you have to unscrew the motor body (4 screws that sit just underneath the top of the base), take note of everything that you are taking out so that you can put it back in its proper place when done. Wear leather gloves for safety. Please be aware that even an unplugged unit still has the potential to send several volts of electricity through your body - this is a potentially hazardous task. Once the motor body has been unscrewed and removed slightly (don't disconnect any wires or cables - just get the motor body out of your way), you will notice the old shaft that you intend on replacing. Look for any damage to the gears/bearing that surround this shaft. Try dabbing a small amount of USP-grade mineral oil on any bearings - clear away any dust or debris that may be obstructing the shaft from turning. Don't overapply the oil, or the wetness will seep into other electronic components in the motor and cause them to fail. Put your food processor back together, turn it on, and press the button/buttons on top of the base of the food processor with a pen with the food processor plugged in. If the shaft still won't turn, you definitely need to replace the old shaft (you can disregard some of these previous steps if your problem is that the spindle on the old shaft is worn).
Remove the screws and disassemble the processor base as described above. Since there is a layer of paint/coating surrounding the old motor shaft, removing the old shaft may cause paint flecking. Take the shaft from the one food processor base and insert it in the food processor you are trying to repair. Strip away any excess paint/coating from the new shaft. Make sure no paint flakes remain in the body of the food processor, or they will later cause more serious problems that will permanently damage your food processor - potential fire hazard as well. You will probably notice that the new shaft does not look as pretty as your original shaft, since the paint/coating will almost invariably get damaged in this process. Reassemble the base of the food processor, making sure no wires, etc. were knocked out of place in the process. This paint flecking will add to the cost of the repair - you may need to buy appliance body paint that dries to almost a rubbery consistency to make the final project look nice. All of the materials listed above could cost you $40 or more.
Like I said, I don't reccomend this course of action, but there's your answer.
Mar 11, 2009 | Cuisinart Food Processors
Cooling fan and heatsink.
use t6 star bit take it all apart add new greese to it also to cool it down
Jan 25, 2008 | HP Pavilion Ze4805us Notebook
DDR2 upgrade
should be easy on bootem under one of them panels in middle usally do u wann add 1 gb more
Jan 07, 2008 | Medion md40298 Notebook
Compaq Presario M2000 Notebook Logo
50 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
