Question about Whirlpool Dryers
I have a whirlpool dryer, and it stopped saying EI or E1 what is it? No lint on the lint screen, no clothes stuck in the dryer door Thanks
    New Friend:
  • 85 Answers
Check vent
Posted on Oct 25, 2010
SOURCE:
Lint is stuck in door seal and clothes are not drying
sounds like the lint filter is clogged up, replace it with a new one if possible or give the old filter a good wash, let it dry and try again
Jun 03, 2012 | LG DLE5977 Electric Dryer
Dryer stops running and displays E1
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
redarrow.gif Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
Aug 11, 2008 | Whirlpool GEW9200L Electric Dryer
My Whirlpool Dryer (model no. LGR4634EQO) is no longer heating, or getting hot at all. How can I troubleshoot it??
Hello.
suggestions about things they can do to troubleshoot commonproblems.
Instructions
    • 1 Open the dryer door and remove the lint screen ifthe clothes are not dry after a drying cycle completes. Remove the lint fromthe lint screen and replace the screen. The dryer ought to dry more efficientlyafter the lint screen is cleaned.
    • 2 Open your home's breaker box if the dryer is notturning on or no indicator lights are visible on the front panel. If theswitches for the dryer in the breaker box are flipped to "Off," flipthe switches over to the "On" position.
    • 3 Remove some of the clothing in the dryer or drysmaller loads if you notice that the clothing is wrinkled when you finishdrying a load. Larger loads cause the clothing to wrap around one another whendrying, increasing the likelihood of wrinkles.
    • 4
Pull the dryer unit away from the wall and checkon the position and arrangement of the exhaust vent. An exhaust vent that ispinched between the wall and the appliance or an exhaust vent that is kinkedcan't allow air to flow through it properly, making it difficult for theappliance to dry properly.
    • 5
Make sure the door is closed if the dryerdoes notrun. Also check to make sure that you hold in the "Start" button forat least a second. Pressing the button for less than a second may not give thethe dryer enough time to recognize the button has been pressed and that itshould start.
Thanks for using fixya.
Jul 31, 2011 | Dryers
I clean my lint trap from the dryer after every use, but i still get lint particles on all my clothes when I take them out! Its been happening every time and when i clean the lint trap its full. How do I...
Hi and welcome to fixya,
This problem can be caused by poor air circulation inside. In order to efficiently remove lint from clothes, load the dryer 1/2 of its drum capacity. It also helps putting fabric conditioner sheets to prevent clothes from charging static electricity which can attract lint..
Hope this helps,
levibit
Jan 05, 2011 | Whirlpool Clothes Dryer Lint Screen Left...
EI or E1 appearing
E1 is an open thermistor. The thermistor lives on top of the blower housing. Get to it by removing the bottom quarter panel. Get to it by removing the bottom quarter panel.
http://fixitnow.com/2005/03/appliance-repair-revelation-peek.htm
http://www.repairclinic.com/referral.asp?R=154&N=548392
part link above.
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208558723.pdf
tech link above, circuit diagram.
May 23, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Clothes seem to take longer to dry and I keep getting an E1 error code on my Whirlpool duet dryer. Model #GGW9209LW0. Dryer is about 8 years old. Lint is not an issue.
The error code E1 indicates the control senses an open thermistor either due to a loose connection or a failed thermistor. Check the thermistor connection to the control and replace the thermistor (part number 8577274) if the connections are good and snug fit.
Remove the two screws securing the toe panel to the cabinet then pull the panel down and out. Remove the hex-head screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the lint duct.
Facing the rear of the dryer, the thermistor, usually black, is located on the blower housing to the right of the thermal fuse. Remove the two screws securing it to the blower housing and secure the new thermistor in place.
Connect the wires then reinstall the lint duct and the lint duct bracket. Slide the toe panel up into position to the cabinet and secure it.
Apr 27, 2010 | Whirlpool GGW9200L Gas Dryer
I have a whirlpool super capacity dryer that is very slow drying the clothes. It takes three or four cycles to dry a load of clothes. I've cleaned the lint screen.the exhaust tube and the clothes aren't...
hi .your air duct in the dryer is probably clogged . To repair. remove lint filter 2 screws on the top, remove . lay dryer on floor, front down. remove back panel . remove the air duct, clean all lint thanks the appliance doc
Oct 02, 2008 | Whirlpool Dryers
Lint screen filter FELT seal fits in screen recessed channel (Approx. 20”x1/2” rectangle) This is the lint screen located inside the dryer, just as you open the dryer door. It says "Clean Before Each...
well what kind of dryer do you have and you need the model number to order any parts.open the door,look around the opening where you put the clothes in,google the model number or go here to the sears site and put your model number in and look it up,
https://www.searspartsdirect.com/model-number/MSD2651HEW/3048/0165000.html
Jan 02, 2018 | Whirlpool Dryers
Dryer starts runs for 4min flashes e1 turns off
The E-1 error code is a thermistor error, some problem with the variable resistance.....this can be caused by over use of fabric softener sheets, which can cause lint to become tacky and coat the thermistor, or it just simply failed. Try replacing the thermistor.
Jan 17, 2008 | Whirlpool GEW9200L Electric Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Smitty
Level 1 Expert
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
