The scan utilities cd only contains driver. If your scan button is working, u can select scan to twain. Install file downloader, and u can download your scanned files.
yes it is possible. connect the copier to the computer via parallel port because it does not support USB
port.it think it ran only on XP. Go to the website: http://www.nodevice.com/driver/e-STUDIO20/get14238.htmlType the security code onto the screen and click download.You can then install the driver.It is a compressed file and you will need to unzip it first. Use
Winzip or any other utility for compressed files.
CA1 indicates the polygon motor abnormality in laser unit. Well, u can take out the laser unit by removing the paper tray, toner, power supply and u will see the laser unit. Normally, if no connectors issue, then then only choice u have is to replace the laser unit.
first you need to choose which version of linux you want to use, i personally prefer unbuntu got to http://www.ubuntu.com/ to download a free copy, then burn it to a cd, you can run it from the cd if you want so you dont have to wipe your hard drive just yet to try it out, if you like it its worth installing it as it will run faster, to install it just follow the instructions from the boot menu it is really easy to install
try this: start, printers and faxes right click on the print driver , go down to properties click click on ports click configure port click lpr in protocol Lpr queue name PRINT LPR byte counting enable SNMP enabled
