Question about Shoprider 889XLSN-BGRD-Enclosed Cabin Scooter - Red
DRIVEMEDICAL PHOENIX 3 WHEEL Just bought it and charged it for 10hours. When I put battery into scooter, all the battery lights come on- 2red 1yellow 2green.....so is it charged? are the connections loose? is that normal?
    Novelist:
  • 232 Answers
Check this site to locate the controller for your scooter to determine what the lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Did you buy it new or secondhand? If it is new, it may be covered by warranty to have service done at no charge. Check your owner's manual for fault codes; contact the manufacturer if you are still having issues.
Posted on Oct 27, 2010
2 Suggested Answers
SOURCE:
  • 692 Answers
SOURCE: DRIVEMEDICAL PHOENIX 3 WHEEL Just bought it and
Wez Thats a normal indication of a full charge. The battery level indicator will go down as you use the scooter. Always charge the scooter overnite if you use it a good bit during the day. With new batteries it will take 8-10 charging to break them in and operating at 100%. Always store fully charged and if not used alot charge once a week after you have charged the batteries 8-10 times
Hope this helps
Testimonial: "Thank you for taking the time to answer my question."
How to fix scooter when red light flashes 5 times
hi, i need you tell me what controller type is fitted to that scooter before i can be more precise with fault info ,, the controller is a black, or blue or silver box located under the rear cover of the scooter ,, the wires lead to this unit...
Regards
Rob
www.gewizrepairs.co.uk
Apr 10, 2014 | Drive Medical Phoenix 3 Wheel Compact...
The red light flashes 5 times scooter will not move
I would look at the freewheel lever. Disengage and then engage the freewheel and see if this corrects the problem. If not, you may have a bad freewheel switch.
Phoenix 3 battery charge idicator
Hi, is it possible for a picture of this ??? the reason being they used two diif versions so I want to be sure...
By the way you say you changed the batteries but what about the charger, are you 100% sure that working okay as in charging the batteries to a ideal voltage level around 27.5 DC ,max voltage should no more than 28.2 volts DC, this will give you a 100% usage of the batteries in question...
Regards
Rob
Feb 01, 2014 | Drive Medical Phoenix 3 Wheel Compact...
My Phoenix scooter is two years old and looses the charge in about 5 min. I changed the batterys and got a new charger but it still does this?
hi, there must be a short, first of all is it possible you got another set of bad batteries, are they new ? and how long are you charging them for , and it the charging showing that it , if for some reason the connection is bad depending on the charger can show fully charged when it fact they are not !!! check the charger socket to the batteries...
Regards
GeWiz.
Feb 02, 2013 | Drive Medical Phoenix 3 Wheel Compact...
Just bought this from an individual who knew nothing about it. Scooter is in excellent condition however it has been sitting for a bit. The problem is the scooter only goes forward when in the High speed...
Jade
This model Drive Phoenix 3 wheel is found for sale at pharmacies and is subject to floor model abuse.
Most common abuse is not recharging batterys and letting them sulfate thus
reducing life of of charge.
I have found that the foward and back-up levers have been bent
by people sitting and squeezing both levers at the same time. the resulting misshaping of the levers results in a very slow speed comand to the controller because of limitted movment of speed control. The result is that main control (turtle/hare) must be advanced to fast (hare) position to get scooter to move.
I have had success straightening levers by carefully bending them in opposite direction on my Phoenix 3W ( which was a clearence item with no warranty.)
The real (legal)solution is ordering a new lever having a technician
replace it so as not to void warranty.
Hope this helps....jth1939
Apr 02, 2011 | Drive Medical Phoenix 3 Wheel Compact...
DRIVEMEDICAL PHOENIX 3 WHEEL Just bought it and charged it for 10hours. When I put battery into scooter, all the battery lights come on- 2red 1yellow 2green.....so is it charged? are the connections loose?...
Hope this helps
Oct 27, 2010 | Drive Medical Phoenix 3 Wheel Compact...
Shoprider 889XLSN-BGRD-Enclosed Cabin Scooter - Red Logo
153 people viewed this question
Top Shoprider Health & Beauty Experts
Rob Hill
Rob Hill
Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
