Question about Dayton Gas Furnace Heater
How to make the fan run only.
I have an intertherm gas furnace and would like to make the fan run constantly. I currently have an old thermostat that only allows for the control of the temperature and there are no other adjustments on it. Any suggestions besides buying a new thermostat.
  • 32 Answers
Inside the furnace there should be a switch that says on/auto to run the blower constantly flip it to on.
Posted on Sep 04, 2009
Intertherm MGHA-070ABFC-05 will not run/cool
Multiple problems. Eliminate thermostat first. Remove face from wall and turn on breaker. If fan still runs you have a bad board or bad relay. If fan outside is running compressor should be too. These operate on same contactor. Verify you are getting 24 volts to coil side of contactor. If odf stops working and contactor remains pulled in you have a bad motor. If odf motor stops working the compressor will shut off due to overheating.
Jun 07, 2016 | Intertherm Heating & Cooling
Intertherm gas furnace in mobile home..igniter comes on then nothing tries to fire byrners but nothing
by igniter I assume you mean the thermocoupler. are you turning the control button to run after you light the pilot light? Normally when those furnaces quit it is the thermocoupler that has quit. Get a new one and leave it in the furnace compartment as a spare.
Jan 06, 2015 | Intertherm Heating & Cooling
Intertherm furnace M1BG wont fire
Make sure the gas valve is turned to the ON position after you had it in PILOT position. Also check the thermostat low voltage wiring @ furnace...jumper the Red & White wires to bypass the thermostat temporarily. Make sure there is 24 volts on you low voltage circuit.
Dec 16, 2013 | Intertherm P3RA-048K Air Conditioner
Module doesnt blink
Generally a control module won't diagnose that it is bad. The fan switching in heat mode occurs via timer in the board. So either run the fan on all the time from the thermostat, or replace the control module.
Nov 30, 2013 | Intertherm 56000 Btu Gas Furnace
Intertherm furnace burner comes on, but blower does not. If I turn thermostat off then back on until it clicks the fan will then come on. It does not do this all of the time, just now and then.
Furnace burner and heat element are not the same. I think the fan time delay, a sensor that turns the fan on when this sensor senses heat, is shot and needs replacing, for a furnace type heat ( gas heat)
Aug 08, 2017 | Intertherm E3EB010H Electric Furnac
Elec. intertherm FURNACE
It would help if I knew what type of system you have, lets start with the thermostat. If you disconnect the wires to it, does the heat turn off? I have seen thermostat wires pinched inside the wall, thus bypassing the thermostat controls altogether and it would run constantly. If you send a reply, tell the type. Wall furnace, central unit, heat & cool, gas, electric or heat pump. If you dont know tell me how many wires you have at the thermostat and the colors. You should know this, as you have changed it.
Jan 05, 2008 | Heating & Cooling
Intertherm gas furnace model number m6bb070abfc01
Check for a open limit switch caused by a dirty filter or poor air flow
Dec 24, 2007 | Intertherm P3RA-048K Air Conditioner
Furnace fan running off and on blowing cold air
Need a little more info. Does the fan never stop? Is this a gas furnace? Is your thermostat in the fan auto not fan on position?
Dec 08, 2007 | Heating & Cooling
Intertherm furnace problem?'s
the blower on my furnace keeps going on and off when i turn the furnace on .ichanged the snapdiscs no change changed thermocoupler and therostat still no change whats my problem
Oct 27, 2007 | Intertherm P3RA-048K Air Conditioner
Dayton Gas Furnace Heater Logo
162 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
