Question about Frigidaire FDF70S Dehumidifier
Ices up right away (Frigidaire FDL70S1 Dehumidifier) 18mo's old.
I have a FDL70S1 Frigidaire 70 pint dehumidifier and need to clean the filter. I've lost my manual. So how I get at the filter? Thanks Glenn
First, I'm not a Frigidaire tech.
* Check your warranty. Call for service.
* Contact (note Live Chat link); https://www.frigidaire.com/Search-Results/?q=dehumidifier
*** The following is for information only ***
* Note that this filter is a "wash - Reuse" and is probably considered a "Part" and not a consumable.
* Filter (check if this will fit); https://www.amazon.com/Frigidaire-5304487154-Dehumidifier-Filter-Unit/dp/B00PU1V4M2/ref=sr_1_1?s=home-garden&ie=UTF8&qid=1531339454&sr=1-1&keywords=frigidaire+fad704dwd+filter&dpID=61e1c6OA6UL&preST=_SX300_QL70_&dpSrc=srch
* Review; https://www.youtube.com/watch?v=BbwIEU3zlG8
* Correcting "Bucket Full" Error; https://www.youtube.com/watch?v=UzGnUG3r8dU
* Review (includes using a hose drain); https://www.youtube.com/watch?v=aAKN--TgQRI
* If your missing this filter then contact the local Frigidare or Appliance store for a replacement.
* Final; check your warranty. The filter may be covered.
Aloha, ukeboy57
Jul 11, 2018 | Frigidaire Dehumidifiers
I have a Frigidaire dehumidifer model FDL70S1 that wont stay running for more than 3 minutes and then it shuts the fan off, but still has power to the unit.
Hi lynn crisp, thanks for your post!
From my understanding you are having a challenging time with your Frigidaire dehumidifier shutting too quickly. It sounds like a possible problem with your sensor or control panel. Are you currently under warranty? I would contact your manufacturer for assistance to a proper resolution. -Matt
Oct 20, 2014 | Frigidaire Dehumidifiers
I have a FDL70S1 Frigidaire 70 pint dehumiifer that runs for 3 minutes then shuts off. I have tried to set the timer for it to run longer but it wont. Do you know what is wrong with it?
Hello lynn crisp, thank you for your post!
From what you have explained regarding your Frigidaire dehumidifier it sounds like the sensor or control panel has become faulty. I would recommend resetting your dehumidifier and you can do that by unplugging the power cord for ten minutes. Is your dehumidifier under warranty? If so, you may want to reach out to the manufacturer for a resolution to the problem. I hope this information is helpful. -Matt
I have a fdl70s1 and will only work in continuous mode.. Collects water fine but turns off when I adjust humidity setting
I appreciate your post, Lee Silvey!
I understand that your Frigidaire dehumidifier, FDL70S1, will only work in continuous mode. Sounds like you could have a possible issue with the sensor or control panel. Are you under warranty? I would advise you to speak with your manufacturer to see if any further resolution can be provided. -Matt
Oct 15, 2014 | Frigidaire 70-Pint Dehumidifier -...
Frigidaire is spitting water out of the side vents
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Aug 30, 2011 | Frigidaire FDL50R1 Dehumidifier
I have a FDL70S1 Dehumidifier. Unit runs for just a couple minutes and shuts off-blinking bucket full even though no water in bucket. Unit won't stay on
Dont spend to much time trying to repair dehumidifier they are very cheap to replace. Most dehumidifiers have lots of problems because they are made so cheap. Just replace the dehumidifier you will tank me in the end.
May 17, 2011 | Frigidaire FDL50R1 Dehumidifier
I have a FDL70S1 dehumidifier that runs and runs but doesn't take out any moisture from the air. I have cleaned out the filter and front screens thoroughly but it still doesn't work. The unit...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 10, 2011 | Frigidaire FDL50R1 Dehumidifier
My dehumidifier started to make occasional popping, cracking noises. Sometimes several per minute. What's wrong?
heatman101
Feb 26, 2011 | Frigidaire FDF50S Dehumidifier
I purchased a new Frigidaire dehumidifier and the coils are freezing up. The basement temp is 64 degrees. Any Ideas? Frank
Here is a tip that I wrote that will help you understand why and what you can do with a dehumidifier that ices up.
heatman101
Feb 24, 2011 | Frigidaire FDF70S Dehumidifier
Oil in my water reservoir for my Frigidaire FDL70S1 Dehumidifier
could be oil from a fan motor or compressor, either way thats not good
Apr 10, 2010 | Maytag M7DH45B2A Dehumidifier
Frigidaire FDF70S Dehumidifier Logo
224 people viewed this question
Top Frigidaire Dehumidifiers Experts
Nestor Dede
Level 1 Expert
Your Consultant
Gil Shultz
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
