Question about Microwave Ovens
My beertender will not turn on at all no matter what. Plug is good
  • Microwave Ovens Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Oct 26, 2010
SOURCE:
Why is turntable skipping after motor replacement?
It doesnt matter which way it is plugged in. If the microwave has a guide roller (ring with 3 wheels), check the wheels to see it they are all intact and roll smoothly.
Jul 15, 2014 | Microwave Ovens
Pem31sm3ss does not turnoff
All the units that's mounted for this model have problem closing the door. After you closed the door, press down on the door.
Feb 10, 2014 | GE Profile 1.1 Cu. Ft. Mid-Size Microwave...
Dear Sirs We have a emerson microwave model MW8778W manufactured in 2002. The problem we have is that it doesn't power up any more. We have tried using another plug outlet but are still experiencing the...
The main fuse in the microwave oven has blown, sometimes you can change it without a problem, but normally I find the door switch becomes defective causing the fuse to open. If you decide to service it yourself be very careful of dangerous high voltages that are present.
Feb 07, 2011 | Emerson Microwave Ovens
My microwave oven turntable will not rotate. How should I solve the problem? Also if I just leave it and carry on using it does it matter? Model MICROMAT 21T-W
It is rather important having a turntable that revolves. Just as a matter of interest, place a refridgerated jelly in the microwave and watch as heat is only applied at one point!
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Jan 01, 2011 | Microwave Ovens
Danby mini fridge model dcr054w has stopped working the thing in the back is extremly hot and the fridge no longer gets cold, i turn the knob and i hear a click but the fridge doesnt actually turn on. the...
This is a problem with the 'Motor Run Capacitor'
What you suggest is exactly what happens when this part fails.
Unplug - and look carefully around the connections to the compressor - there should be a cylinder with 2 connections on it. Read what value it says (like 250V 50pf) - and order a replacement from a parts store.
Fit it any way round - it doesnt matter.
plug back in and should work 100%
Cost about - $5
Dec 27, 2010 | Microwave Ovens
Wires to magnetron
It matters!
The wire from the high voltage transformer high voltage tap goes only to one side of the high voltage capacitor. No other wire is connected to that terminal of the high voltage capacitor.
The other side of the high voltage capacitor connects to the anode (A) of the high voltage diode and to the "FA" terminal of the magnetron.
The cathode (K) of the high voltage diode is connected to chassis ground.
The pair of wires connected to the secondary (thinner) winding of the high voltage transformer are the filament wires and are connected to the "F" and "FA" terminals of the magnetron.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
It has the overall wiring diagram and schematic.
For further free help, e-mail me at http://www.microwavecontrol.com
Jul 10, 2009 | GE JVM3670 Microwave Oven
Question re: installation of turntable motor
If its an AC motor, the wiring will not matter. Look at the numbers on the motor. You will see a voltage rating, RPM rating and if you see the text "50/60 Hz" it is an AC motor and the wiring will not matter.
If its a DC motor, you will see a voltage rating, RPM rating and a + & - for the wiring. If you reverse the wiring, the turntable will turn in the opposite direction.
I'm not sure about all microwave ovens, but the ones I have worked on, the turntable turns in the clockwise direction.
Most likely, its an AC motor. Look for the "50/60" text. If its an AC motor, the wiring will not matter.
Please let me know if I can be of further assistance to you,
- Jim
Feb 20, 2008 | GE JVM1640 Microwave Oven
Microwave Ovens Logo
385 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
