Question about Harman Kardon CDR2 2-Disc CD Recorder
How do you get the tray out?
The front will not come off easy. I have the tray loose but cannot get it loose front the front. Can you help?
  • 112 Answers
Unclip the face of the tray(the silver / gold bit) off the black plastic.
Posted on Jun 24, 2008
RCA Truflat ate my DVD
This is a mechanical fault. Check the loading belt for loose. Replace it. In rare cases, loading motor too might need replacement.
Feb 24, 2013 | RCA Televison & Video
LENOVO K410 CD TRAY WONT EJECT MANUALY
Using a paper clip one can eject the drive tray.
Bend a paper clip into a straight length of around 2"(inches).
Push the end into the little hole found on the front of the drive, below the tray.
Your tray will now unlock, pull the tray to side it out.
Easy and you are done.
Take care!
damnor01
Sep 12, 2012 | Dell Vostro 220 Desktop Computer
My 4x4 feels like it is in but the front wheels arent spinning whem im stuck what going on?
I have a1996 Jimmy and I had the same problem, It turned out to be a vacuum hose had come loose from the actuator that engages the front axle. The actuator is located under the battery tray. You will have to remove the battery and the tray to gain access to it. You could also have loose or bad vacuum hoses at the top rear of the engine. Be sure to check all of them.
Jan 26, 2011 | 1998 GMC Jimmy
I need to remove the evaporator tray from underneath.
Don't know what frig you have, but many slid out the front and a few slid out the back. The front grill is clipped in place. So you can just pull up on it and then tray will be easy to find.
Sep 22, 2010 | Refrigerators
Samsung ice maker tray won't reset
I had the same problem and would "temporarily" fix it by opening the front plastic cover (remove the 4 screws) and CAREFULLY remove the front - sometimes all the plastic gears will fly off but you can get them back because they only fit one way. Once the gears are off, you can reset the tray back to its fill position. Fit the gears back into place. Replace the front cover and it worked like a champ for a couple of weeks when I'd have to do it all over again. I finally got tired of it and ordered a new unit through ebay. Easy to replace BUT now the water won't come on to fill the tray!!!! UGH Hope this helps
Sep 21, 2009 | Samsung RB215LASH
Rubbing noise when driving audi a4
Check under the front wheels for plastic inner wheel arches that have come loose and rubbing on the tyers also the under tray under the bottom of the engine may be also loose and rubbing on the road.hope this helps
May 30, 2009 | 2001 Audi A4
Laserjet 4700 Tray 2 stuck will not pull out.
You possiblely have something loose in the tray or something broke. Find something metal and thin, like a hack saw blade, and stick it through the slot between the drawer and printer and see if you can feel the obstruction, and if so try to move it out of the way. Something is catching on the printer frame and drawer.
Feb 27, 2009 | HP LaserJet 4700 Printer
Copy Orientation
Is it cutting off on all of the paper trays on the same side of the page? Lead edge or Trail or front to back side of the copier? You can adjust the front to back in the paper tray and the lead and trail are adjusted in service mode. Do the amout of the cutting off change at all? You may have a reg. clutch problem. Also you can adjust the X & Y amouts in service mode as well.... It could just be as easy as making sure the paper tray guide's are tight against the paper in the trays...
Jun 10, 2008 | Canon imageRUNNER 5020 Copier
ML1710P
you may need to 'select' the printer in your control panel. Or the printer driver may be blown.
Feb 06, 2008 | Samsung ML 1710 Laser Printer
Xbox Disc Tray Loose
Check the CD tray motor belt for loosing as shown in following image with yellow colour marking.
Aug 30, 2007 | Microsoft Xbox Console
Harman Kardon CDR2 2-Disc CD Recorder Logo
171 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
