Question about LaCie 1 TB 2big Spare Drive 301307 SATA Hard Drive
Lacie 2big Triple 2T - Raid 1 LED's blinking
Just purchased the above external drive, switched to SAFE mode (Raid 1), all was fine so I copied a file onto it to test. All good so far ... then I switched it off, removed one drive, switched it back again to test whether the Raid system was working before copying all my files over ... in theory the data should have been there with the one drive. It was, and I was able to open it. I then again ejected/switched off and replaced the 2nd drive but now the front and back LED's are continuously flashing red/blue which according to the Lacie manual indicates a drive failure. I reinserted it to make sure it was plugged in properly and it is still flashing ... any help would be much appreciated.
  • 1 more comment
  • llprong Jun 11, 2008
    I have the same issue, same scenario just testing that it was working and bang red and blue lights flashing front and back. the device is still working fine though.
  • gt13013 Jun 29, 2008
    Since I have exactly the same problem, I am interested by any solution.
  • klhimagines Aug 25, 2008
    cannot get mac to recognize external harddrives. there 4 link together. I tried all of them individually. still didn't work. Then I bought disk warrior. still did not work. What am I doing wrong?
Solved! After 17 hours of blinking, the status of the 3 leds is now to fixed blue. You just have to be patient...
Note that I had only put 1GB of data on the drive. I expect that the resynchronization time is not proportionnal to the amount of data on the disk!
Posted on Jun 29, 2008
  • Data365
    Data365 Dec 12, 2013
    Better get your data off this disk while it is still alive
Lacie 2big 2tb drive LED flashing red what do I do?
You didn't provide details on what mode you were running or if this worked before and this is a sudden event. The manual doesn't appear to cover this situation of one blinking red light:
but I found a YouTube video that may be helpful to you:
Sep 15, 2014 | LaCie "2BIG Quadra External Hard Drive - 2...
LaCie 2big Triple - I replaced one drive, but capacity is wrong
Most likely the problem you are encountering is due to the RAID mode the device is set in. Most RAID arrays utilize multiple drives of the same size, or with drives of differing size, they just use a portion of the largest that matches the smallest drive. When the device rebuilt the array it partitioned off a portion of the 4tb drive of the same size as the existing 500gb drive. If you want to use full capacity of both drives you would need to use JBOD mode, which just strings the disks together into a storage pool using all available space. This won't offer the data redundancy of RAID1 or speed boost of RAID0, but should allow using full space.
Backup any vital data before doing anything, then look for a switch on the back. Rather than RAID0 or 1 the options may be labelled Safe or Fast, but JBOD is usually still labelled JBOD, or sometimes Big. You can try just flipping the switch to JBOD and seeing if it rebuilds to use all space. If that doesn't work you may need to remove the 4tb drive, connect it to a different system and erase it to get rid of the 500gb partition, then with the Lacie set to JBOD reinstall the 4tb drive so it will add its full size to the array.
The safest option though would be to buy another 4tb drive, backup all data and install both 4tb drives with the device set to RAID1/Safe. You would only get 4tb of total storage, but it would mirror the data on both drives so if one fails the other will still have your data. With JBOD you won't have any auto-backup. If a drive fails the data on it will be lost.
Jan 21, 2014 | LaCie 2big Network (2-disk RAID) (301257U)...
Lacie raid drive failure
You have a failed RAID array. These guys do raid recovery remotely over the net...
Sep 09, 2012 | LaCie 2Big Quadra 6TB 2Disc RAID External...
I have a 1TB LaCie 2Big Quadra. It has 2 500GB and runs on RAID 1. I replaced both 500 GB LaCie drives with 1.5 TB LaCie drives, but my computer only recognizes the original 500 GB. I formatted both...
I have the same problem too on my 2big form lacie . If I use 2x 1,5 tera disk in "fast mode" or in "big mode" my disk manager only shows 746 gigs available (it should be at least 2,5 terra).
If I use "safe mode" so my system can see 1,3 tera available, wich is normal for a raid mirror configuration.
I hope to find a solution quickly.
Dec 13, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Product: LaCie 2big quadra ((Professional 2-Disk RAID. I have no back-up with the 2 disks, and this soon after purchase (August 2010). Serial number: 5102001839. Disk 2 does not work. At the front, light...
If the failed hard disk drive is replaced with the exact same capacity, RPM and make of hard drive, then the array can be rebuilt. Raid 0 cannot be rebuilt as each drive contains half of the data, If RAID 1 then can be rebuilt as data on each drive is an exact copy. However if combination of RAID 0 and RAID 1 then can be rebuilt. It's best really to handel this hands on, I recommend taking it to a computer technician especially if the information on it is important.
Thanking you
Nov 13, 2010 | LaCie 2TB 2BIG QUADRA RAID EXT ESATA FW800...
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
Backup slow
You don't specify whether previously on your USB it was the same lacie external or whether it was a different external drive. It sounds like you were using a different external drive, most likely a single drive.
You've specified that you've got your lacie setup in raid 5. Raid 5 gives a very good read spead and a good redundancy for incase a drive fails, however it's write speed is very very slow.
It will be much slower than a single drive on USB for writing to it (i.e. backups), but you should see a huge performance boost in reading from the drive than your previous usb.
If you need it to be faster, you would be better suited looking at configuring it for one of the following raid setups:
Raid 0: striping (not recommended for backups) - data is split over all drives, however if 1 drive fails you lose all data.
Raid 10: striping + mirror . half the drives are striped (like above), but the other half mirror the striping half so if one drive fails there's a backup of it. You only get half the disk space though, so if you have 4 x 1Tb drives, then you'll only get 2Tb of space.
Apr 06, 2010 | LaCie 2500 GB Network Storage Server
Lacie 2 big does,nt boot
Hmmm, reseting worked on mine. Identical symptoms except light stayed blue, not red. Unable to power down.
Before trying to get the drive working I got the data off using the procedure in the second post of this thread:
You need a linux system running. Maybe a live cd will do. I installed on an old IDE drive I had.
I then rest the decive using this procedure from Lacie and my drive is working again. Worthless though, because I can't trust it.
The procedure below will reset the 2Big Network to factory settings:
IMPORTANT NOTE: Following the procedure below can ERASE ALL DATA on the drive. Prior to following these directions, verify important data is stored securely on a different storage device.
Switch the drive OFF. Once it has shut down, ensure the power switch remains in the OFF position.
If the drive is in the SAFE mode, move the RAID switch to the BIG mode.
PRESS AND HOLD the button on the front. MOVE the power switch to the ON position. The light on the front of the drive will start blinking.
Once the light stops blinking, RELEASE the front button.
When released, it will begin BLINKING AGAIN. When it stops, PRESS AND HOLD the front button. The light will begin to blink again.
When the light stops blinking, RELEASE the button. The drive is now resetting itself. Switch the RAID selector back to SAFE if desired.
To restore data if it was lost during the process, recreate the shares and users on the unit prior to the reset. Any firmware updates applied will need to be applied again.
Sep 02, 2009 | LaCie 2big Network (2-disk RAID) (301257U)...
Exactly same problem
check your network for conflicts, check power supply, fan and nic card, if your sure it's not the the drives inside the drive case, I have had 4 of these fail on me @work with different issues power supply nic card and both drives 4 units did the same thing and they were under warranty so when I got it back, I sold them and bought The Seagate BlackArmor NAS 420. no problems with them as of yet. Lacie get hot and components get hot and fail because there is not enough air flow I think.
Aug 13, 2009 | LaCie 2big Network (2-disk RAID) (301257U)...
LaCie 1 TB 2big Spare Drive 301307 SATA Hard Drive Logo
2,247 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
