Question about Mitsubishi WD65737 65" DLP TV
Mitsubishi WD-65737 DLP TV. TV powers on, green light starts blinking and blue screen shows up. TV then shuts down. I retrieved the error code and it shows "1-2". Any ideas? TV is less than a year old and the lamp is not the issue.
    New Friend:
I had exactly the same thing happen..I contacted Mitsubishi and they said the software needs to be updated..they are going to send me the link to download the software.
Posted on Dec 29, 2010
    New Friend:
Thanks for the solution. I downloaded software from the Mitsubishi website to a USB thumb drive and then uploaded to the TV to correct the problem. Detailed download instructions are also available on the site. I had ordered a lamp and was waiting for it to be delivered - I guess I'll keep it for when my lamp actually does go bad, since that seems to be an issue. Does anyone know about how many hours you typically get out of a lamp?
Posted on Sep 22, 2011
  • bigj316 May 27, 2012
    Tv lamps last about 6000-8000 hours depending on use found infohttp://www.justanswer.com/tv-repair/61bs... a little bit down
SOURCE:
All I get is a blue welcome screen on my Mitsu WD-65C9 DLP TV. After several seconds of blue screen, it always just shuts down. I downloaded the Mitsubishi software upgrade, but it did NOT solve...
Hi Mike,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Kind Regards,
Mjsazon
Nov 25, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
Mitsubishi 73" DLP powers on, through welcome
If you are getting at turn on source and back ground is all blue the set will shut down rather quickly;
I have a suggestion, if it works fine, and if not it will not hurt anything.
with original Mitsubishi remote turn set on and then Menu, 1,2,3, enter.
This is the soft reset that most of these sets have (cannot be sure since Model number above is correct?)
The reset button on the front (if it has it) just shuts the set down and reboots the DM unit inside.
Most of these sets when it is pressed the green light will blink for about 70 seconds and go out; that is the DM unit rebooting and the soft restart is something else.
Let me know what you find before you rate this information.
SD TECH
Oct 05, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
When you turn the TV on it stops at the blue Mitsubishi screen and the power button just blinks. You have to then unplug the TV to power down. Pushing the power button on the TV or remote will not power...
There is a software update that is available for some Mitsubishi dlp models. The wd-65c9 is one of them. When I experienced your problem, I went to the website, downloaded the update, and installed it on my tv and boom, its fixed. It's super easy, free, and takes a few minutes.
Jan 31, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
When i press power button green light comes on and then red light blinks 2 but the tv does not turn on
Question title shows it is Mitsubishi WD-65737 tv.
When did you replaced lamp in tv?
If lamp has not been replaced in last 2-3 years, please check lamp as it seems dead, that is why tv does not turn On.
Aug 26, 2010 | Mitsubishi WD65737 65" DLP TV
Problems with mitsubishi WD 65737 tv is locked. what do we do?
problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture then the tv turns off the light on the front is now steady red. resetting the sytem worked yesterday but not today.
Oct 20, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi WD65737 65" DLP TV Logo
2,369 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
