Question about Panasonic Lumix DMC-FX3 Digital Camera
My camera doesnt work.
My battery is fully charged for my camera, but when i put it in my camera wont turn on at all. it was working fine before my battery went dead. i've had this camera for a while and this is the first time i've ever had problems. i know nothing is wrong with the battery, because my sister has the same camera and i put my battery in her camera and it worked fine. but my camera wont trun on at all when i put my battery in it. i cant figure out whats wrong.
  • lumix_user Jun 28, 2008
    I have the same problem with my camera. My battery's fully charged but the camera wont turn ON.
    How do i get the fuse fixed? or is there something wrong with the battery?
  • 95 Answers
I suggest that there is likely a motherboard fault or a board fuse has blown. the fuse needs to be replaced by a qualified technician, this will prevent any further damage to motherboard.
Posted on Jun 25, 2008
Sony Optical Zoom Steady Shot DSC-W530 wont turn on
Try another fully charged battery first of all. It might be a poor or damaged connection.
If another battery doesnt work, then its the camera.
If the camera doesnt come on the mother board is damaged. You will have to have the manufacturer change it out. Might be expensive
Mar 05, 2014 | Sony Cameras
Camera does not turn on
Rosa, I think the only thing you did was get out the batteries and tried to charge them and then jut put them back in the camera.
Only a few things could have gone wrong.
One or more cells could have died, during charging. It can happen, special with batteries that have a uneven use. Like once or twice a year the camera comes out the box and then the batteries are charged. Even when you don't use he camera, make it a habit to charge the batteries every few months.
Then it could be your batteries are still in good shape and fully charged, but you put in one or more calls the wrong way around.
Please check carefully if all the cells are inserted correct.
If nothing works, and you can't check the voltage of your batteries, try another set of batteries.
Dec 30, 2013 | GE Cameras
Samsung sl605 wont turn on
A charging battery's light is red. If it turns green then it means it is fully charged. Since you had stored your battery for a while, try to charge it by using a battery charger to kickstart it. It should work. Whatever transpires let me know. thanks and rate this answer.
Dec 24, 2011 | Samsung SL605 Digital Camera
I didn't turn off the camera before taking out the battery. Now it wont turn on after reinserting the component. What can I do? The camera is the stylus 7010
Try to plug it into your computer using the usb cable and turn it on from there. If it doesnt work, fully charge the battery and try inserting it again after an hour.
Oct 15, 2010 | Olympus Stylus 7010 Digital Camera
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
I own a Sony DCR-HC47E Handycam.It will not turn on
i have a problem with my sony dcr-sr47 camcorder it wont charge the battery camera works fine with power supply any solutions.
Dec 15, 2009 | Sony DCR-SR47 Camcorder
Camera won't work. Only shows Change Batteries,even with new ones
akaline batteries wont work
only rechargable FULLY CHARGED
if that doesnt work clean battery terminal
Apr 28, 2009 | Canon PowerShot A470 Digital Camera
Camera won't turn on.
Make sure the battery contacts are clean. The rechargable batteries looses their charge even when they are not in use. It is important to fully charge the first time the rechargable batteries.
Dec 14, 2008 | HP Photosmart R707 Digital Camera
It wont work!
if it said fully charge its probably not yet.
could it be that you damage your camera in the first time that it was jammed?
Jun 22, 2008 | Fuji FinePix Z100fd Digital Camera
Wont turn on
Possible failed battery showing fully charged but actually not -or even charger.No reset] Disconnect from the wall socket- re connect and tell us if the battery is now charging. If show full- replace battery. Also tell Sony customer support
Jul 31, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
Panasonic Lumix  DMC-FX3 Digital Camera Logo
133 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
