Question about Kenmore 88752 Top Load Stacked Washer / Dryer
Kenmore dryer rotates but does not get hot is this a costly repair problem?
  • Kenmore Master
  • 8,220 Answers
What you need to do is check the heating element. It is mounted on the back wall. Kenmore dryer rotates but does not get hot is this - 0706c6a.jpg Remove the top first then you can remove the front. Get the belt loose from the idler and lift out the drum. Then you can check the heater element. More here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Oct 24, 2010
SOURCE:
Kenmore Heavy Duty dryer model # 86873100
The drum belt is lopped through a idler wheel that has a power cut off switch that cuts the power when the belt breaks.
So I don't know why the dryer would heat up if the belt is broken?
Is the top of the dryer very hot. Check the dryer vent tube is not clogged.
Feb 22, 2014 | Frigidaire Kenmore Washer Tub to Pump Hose...
The dryer drum does not rotate. I have a Kenmore electric model number 110.62622101. It blows hot air but drum does not rotate
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 15, 2011 | Kenmore 62622 Electric Dryer
I have a kenmore gas dryer does not rotate believe the delt is the proublem. model #87870100
note Kenmore/Whirlpool same belt configuration:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
how to open dryer:
http://www.applianceaid.com/wpdryer_how-to.html
Mar 19, 2011 | Kenmore Dryers
Dryer quits rotating after it runs for a while.I just replaced the belt same result.
Hi, The motor is getting hot and kicking the overload off... you will need to replace the motor...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Sep 15, 2010 | Kenmore 63942 Dryer
Kenmore 86874800 electric dryer. It doesn't spin (rotate).
Can you hear the motor running? If so, you need to replace the drive belt. If you can't hear the motor running, you will need to get a schematic from the Sears/Kenmore website and check for voltage inside the cabinet. You could also buy another used dryer for $100. This route is certainly cheaper than paying for a service call and repair.
Jan 19, 2010 | Kenmore Dryers
About how much do new belts and capacitators cost
Sounds like the belt is broken...or the motor is faulty.
If the belt is broken and you repair it yourself the cost is reasonable.
If the motor is burned out, then you looking at a higher cost...maybe $100-150 if a repair man fixes...could be more depending on your area
Sep 29, 2009 | Kenmore Dryers
Drum does not rotate
The drum rotates due to a belt that goes around the drum and is driven by a small motor. The most likely answer is that the belt broke. This a common problem on an older dryer. It is relatively easy to replace the belt.
Feb 01, 2009 | Kenmore 62602 Electric Dryer
Kenmore 88752 Top Load Stacked Washer / Dryer Logo
127 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
