Question about Moen Monticello Single-Handle Kitchen Faucet with Cathedral Spout ....
When you lift the handle on the 7730 Monticello, there is a "thunk" sound every time now. Faucet is one year old, this noise started a couple of weeks ago. No leaks that I can see. I need to make that sound stop, ideas please?
  • destewy Oct 25, 2010
    does your spout continue to drip for minute or two after you shut it off
  • carscaddenho Oct 25, 2010
    The spout does not drip. But I found that there were a couple of drips on the hose under the counter that feeds the sprayer. I took the sprayer apart and put it back together tight. Now I get no drips on the hose and no thunk noise from the tap when I open it. So all fixed..!
    New Friend:
  • 70 Answers
The pipes are banging in the wall from water hammering and need to be straped. or a hammer aressetor needs to be installed.
Posted on Oct 27, 2010
SOURCE:
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    My classmate
    Moen Monticello 4-inch centerset bath faucets can be repair easily with only a screwdriver and adjustable wrench. Turn the water off to the both sides of the faucets under the sink. Open both the hot and cold-water valves to alleviate any remaining pressure. Remove the handles by grasping the base of the handle and turning it counterclockwise.( This works for both lever and cross handles). Loosen the Moen faucet cartridge bonnet nut with an adjustable wrench by turning it counterclockwise to the left. Pull the stem from the faucet by hand and replace. Reinstall the bonnet nuts and handles. Turn the water back on and test the faucet for leaks. The Moen Monticello faucet comes with a limited lifetime warranty. Try calling Moen to get your replacement parts free.
    Dec 09, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    Turn hot handle on - water does not come out of faucet
    is the feed on the bottom of the sink open . if it is shut the water off from the bottom and take apart the handle to see if something is stuck in there
    Sep 26, 2009 | Moen 4551___ Monticello Popular Two Handle...
    Two handle Moen kitchen faucet. Hot side handle
    loctite is an excellent product,but you have to have a couple of threads for it to 'lock'! be sure handle is seated[pushed all the way on] or shop a hardware or home improvement store for a replacement screw or a 'self tapping'' screw of the proper size.
    Sep 26, 2009 | Moen & Monticello& Two Handle Lavatory...
    Need to replace handle adapter kit on a Moen monticello two handle lavatory faucet
    Lowes might carry them but i know a plumbing supply house does for sure. Take center caps off hot and cold handls, then screws everything else should pull right off.
    Sep 10, 2009 | Moen & Monticello& Two Handle Lavatory...
    Moen Monticello Single-Handle Kitchen Faucet with Cathedral Spout .... Logo
    220 people viewed this question
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Thomas F. Schneider
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
