Question about GE Adora (DSF25KGTBG) Side by Side Refrigerator
Aurora side by side frigerator fan runs but comressor does not come on.
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101 .
Posted on Oct 25, 2010
SOURCE:
Fridge isn't staying cold, the freezer works OK.
if your freezer is working fine and you hear your compressor running you could have a frozen drain tube or more than likely the evaperator motor fan has failed.this is the fan that circulates the cold air from freezer throughout frigerator.what kind of unit is it?side by side or top mount freezer or what?let me know
Dec 25, 2012 | Refrigerators
The strip between the freezer door and frigerator door gets very, hot -- it could burn your hand. What is causing this?
hi make sure the condenser is clean and the fan is running the condenser in in lower back of refrig jim
Oct 11, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Not cold and freezer is not frozen, but fan is running
dear sir/madam
i think your freezer,s compressor is not working so try to hear comressor working sound if it,s working then there is low gas problem, try to contect your service technician for refill freon .
hope answer the question
thank you
please vote!
Jul 18, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezeor r works fine but frigerator not working
check that your fan is working inside your freezer also check that u do not have an ice blockage problem if your fan is working and also check your t-stat and heater start with the fan if its not blowing the air into the fridge side then thats your problem you can order a new fan from marcone or allbrandsappliance hope this helps
May 16, 2010 | Maytag MSD2756G Side by Side Refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
Frigerator is freezing.
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is too much cold air getting over to the Ref side?
1. The little door is open too much.
check your control setting. You should be able to feel air coming through the channel on the Ref side
2. The cold control is bad causing the compressor to run too much.
Nov 13, 2008 | Frigidaire FRS26R4A Side by Side...
My frigerator
This will get warm. If very hot check and clean coils in front, underneath. Also check fan behind rear panel. It should be turning when the unit is running. Also check for door not closing properly.
Nov 12, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerator will not get cold, but freezer works
Do you know if the compressor in the back is running? If you can check that out get back to me and we can go from there. Most times if the fan in the freezer is running the defrost timer is ok.
Jul 09, 2007 | Amana ARSE66MB Side by Side Refrigerator
GE Adora (DSF25KGTBG) Side by Side Refrigerator Logo
76 people viewed this question
Top Refrigerators Experts
Brad Goodale
Jeff sanchez
Level 1 Expert
Peter Taylor
