Question about LG Computers & Internet
I have an LG L1952HQ LCD monitor that shuts off every 5-10 sec. it's not the PC going into power saver or srceen saver mode
  • 732 Answers
Greatatuin1, Tell me the "date of manufacture" from rear of unit!! You may need to inspect the units power supply printed circuit board or black-brick switchmode power supply. Is power supply "lay on floor" type or internal to monitor case? Is your pc working ok with "differerent" monitor?? Have you been to youtube to watch "refurbishment" DIY videos of cold cathode-fluorescent-lamp back-lit lcd monitors??? If unit is really old and has lots and lots of "on" hours, you may even need to replace the CCFL lamps also. Tell me more info, so I can advise you. Symptom seems to be "black screen of death" !! Have you performed or even know the "flashlight test" that every ccfl lcd monitor owner should know??? Do additional comment back to me. 12fixlouie
Posted on Oct 25, 2010
SOURCE:
Problem for LG 22" FLATRON Widescreen LCD Monitor LCD Monitor My monitor says analog power save and shuts off. Day before Yesterday I bought a new computer. I got the above mention problem on by...
The monitor is going itself to the Power Saver mode.It is not a problem of the monitor.This happens when there is no signal on the monitor.The monitor will display properly when there is an output signal on it.Please connect it to the computer and check that the output signals from the motherboard are proper.Also check both DVI (Digital Visual Interface) and VGA (Video Graphics Array)cables on the monitor.
Feb 23, 2010 | LG 22" FLATRON LCD Monitor
LG 1750s monitor goes into power saver mode in 5-10 min
change the setting in the screen saver option (Power)
or look in Power in control panel...also check the hybernation time
Dec 18, 2009 | LG Flatron L1750S 17" LCD Monitor
Monitor goes into power saving mode. How do I
Go to desktop properties>screen saver option>power option & select the turn off monitor never.
Oct 15, 2009 | LG Flatron L1718S LCD Monitor
Out of the blue one day, monitor started displaying "anaolog power saving mode." This is a stand-alone computer which has never been hooked up to internet.Took tower unit to PC World to see if it was a...
you go to control panel starting your pc ,, then display settings,, from there,, screen saver tab, then make screen saver to none, and click on button power,, there you make everything to never,, and then see. it should work good
Sep 27, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Brand New LG Computer Monitor Flickers/Goes Into Power Save Mode
well right click on your desktop and goto properties and then goto screen saver and then goto power and then on the monitor setting goto never.
Sep 20, 2009 | LG Flatron L2320A 23" LCD Monitor
LG W1952T LCD monitor power save mode during bootup?
called customer service - see other post for details
May 11, 2009 | LG L1915S 19" LCD Monitor
MY LG F1 WONT GET OUT OF SLEEP MODE WHAT DO I DO?
If your laptop won't respond to the wake up keypress you can hold the power button down for five seconds and your laptop will shut down. Then you can reboot it. You might want to go to the screen saver power options and prevent it from going to sleep if the problem persists.
May 05, 2009 | HP Pavilion F1703 17" LCD Monitor
Stuck in power saver mode
Go the desktop, right click with mouse and select properties (if it XP) then it will open Display properties --> there you need to go to Screen saver and then to power option
Disable any power off mode on/ Sleep mode. It will solve your problem.
Please rate the solution. Otherwise let me know for further assistance.
Nov 03, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
My LCD monitor is going into power saving mode
Hi...there,
Your monitor enter to power saving mode to prevent further damaged. It's seems you got a busted backlight inverter... Need to replaced a new one or repaired it...
Oct 13, 2008 | Computers & Internet
Won't come out of "power saver mode"!! PLS HELP
before anything else... just try to check or diagnose if your video card is not defective..and you try also to use another computer to connect to identify the problem...
Jan 28, 2008 | LG Flatron L1710M 17" LCD Monitor
Computers & Internet Logo
207 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
