Question about Dell 3100MP Multimedia Projector
Dell 3100MP Projector : Showing a green image
When running either computer or SVideo signal thru my 3100MP projector, I get an image projected but it is green. I can sometimes get the image to return to normal by gently squeezing the external project case.
Thanks in advance,
Rod Dreyer
rdreyer@pogolaw.com
  • keeper79 Nov 19, 2008
    Having the same issue.
  • Anonymous Feb 11, 2009
    exactly the same - either cable but its green
pgh_pa_guy
  • 2992 Answers
SOURCE: Dell 3100MP Projector - No Signal Check Cable
Make sure you have the right input source selected. It may be looking for a signal from some input other than the one you're connected to. Beyond that, if it truly isn't seeing the input then you'll need to have the projector serviced.
Posted on Dec 17, 2008
SOURCE: how to connect projector to sky plus box using RGB
i have same problem as above can you advise please
Posted on Jan 02, 2009
SOURCE: I have a second- hand
sir
the lamp is not at problem, but the dlp engine is at fault, u may have to replace it.since u bought it 2nd hand,it is not worth changing the same as it will cost u more than ur buying price.when u plan to buy ur next projector, make sure u buy a new one as it will come with a fresh lamp & manufaturers warranty on the unit & at 4000 / 5000 hours of projector usage is guaranteed!
Posted on Feb 09, 2009
sherlyn c
  • 134 Answers
SOURCE: Projects pink display
change the settings.
go to the signal menu and change computer input to rgb.
Posted on May 21, 2009
timothypeacy
  • 23 Answers
SOURCE: Projector displaying yellow tint in center of screen.
The yellow tint is probably coming from the lens. It could be that the glass is tempered or possibly just needs to be cleaned.
Posted on Jul 24, 2009
Hi, is Dell 3100MP Projector is compatible with windows 7 laptop. I am Having message " NO SIGNAL, CHECK VIDEO CABLE" with Windows 7 but with Windows xp, the same projector works fine. Can anyone...
In most cases this problem is cured by enabling the external VGA (or monitor) ouput on the laptop. The quickest way is to reboot the laptop with the projector turned on and connected. Usually the laptop will detect an external display is attached and enable the port.
It is also possible to manually enable the external display port. It varies from laptop to laptop but look for the "Fn" key at the bottom left of the keyboard, usually coloured green or blue. You should see a row of icons on the top row of "F" keys which is in the same colour. Look for the one which is either a monitor, or possibly says LCD or CRT.
Hold down the Fn key and press the key you located in the last step. There is usually a delay of a few seconds and then you'll find something may happen. Usually the external output will be turned on alongside the local (laptop) display. Repeatedly following the last step cycles through all available configuration options, including both on, local on, local off, external on, and external off.
This should fix it. Make sure that the correct input is selected on the projector whilst doing this. It will be labelled on the projector and it should display the same input message on screen.
Feb 21, 2011 | Dell 3100MP Multimedia Projector
Dell 4100MP Image Not Centered Thru Lens
No to your question. The lens is fixed it cannot shift horizontally only although there are projectors that can do this. I am sure you have the front foot retracted? I have had to do the same as you are doing or find a lower table.
Jun 02, 2010 | Dell 4100MP Multimedia Projector
Why does my projection look green if the colors are right on the computer?
I'm going to guess that you are using an RGB cable to connect to the projector and the projector is expecting a composite signal. The composite signal would be what uses a yellow connector when you use hte red/whjite/yellow type of cable. All of the video is carried by the yellow. If the projector is expecting this and you send out component (RBG in this case), then the only video signal processed is the green. Since the green also contains the sync signal, the picture will be seen but green.
Check the menus on the projector. You should find a video selection area that will allow you to change to component input.
Please update this if you have any more questions.
Dan
Feb 03, 2010 | Dell 2400MP DLP Projector
I have a second- hand dell 3100MP projector which I use during church services to project songs and other material. Recently it has been showing a predominalty green image , particularly when showing...
sir
Jan 05, 2009 | Dell 3100MP Multimedia Projector
Dec 17, 2008 | Dell 3100MP Multimedia Projector
Won't project; can't find signal
Make sure that your computer was turned on first (don't ask me why). Then hold down the Fn key while pressing F8. Hope that helps.
Aug 28, 2008 | Dell 3200MP Multimedia Projector
NEC LT35 color problem
If you're trying to project video, then the unit needs professional service. If you're trying to project from a computer, you may have a loose display cable, broken pins in one or both ends of the display cable, or broken conductors (wires) within the display cable. The computer sends its image information as a template of RED image components, GREEN image components and BLUE image components with the projector overlays to create the complete image with blended color values. (The computer also sends HORIZONTAL and VERTICAL synchronization signals, but those don'e affect the color content of the projected image.) That's why I'm suspicious of the display cable, conductors or pins.
Jul 02, 2008 | NEC LT35 Multimedia Projector
Can't get computer images to project
Hi, I have found out that you must have the laptop set to an external monitor, in the control panel, display area, click on 2, then you must have the projector turned on before you start the laptop so it can recognize that the projector is there. Also make certain that you allow the unit to cool off by turning the lamp off, leaving the fan on and open the door where the projection lens is located.
Jun 29, 2008 | Lightware VP 800 Plus Multimedia Projector
VT45 Projector: Blue pixels throughout screen
If the problem is what I describe as a blue haze over the entire image projected, I was told this is a defect in the cable - we have a Dell Video Projector 2300 - and it takes only a dell VGA cable.
So, the problem is in the cable - solution is replace cable.
Feb 28, 2007 | NEC VT45LPK Projector Lamp for VT45
Dell 3100MP Multimedia Projector Logo
827 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
