Question about Sony Handycam HDR-HC5 Camcorder
The touchscreen keeps flipping, rolling, and wont stop. it appears that i can record thru he eyepiece . can i fix this today? did i misuse it? is it likely to do this again ( if it gets fixed)?
    Genius:
  • 1,812 Answers
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Oct 25, 2010
SOURCE:
Just got a Meade ETX 90 and cannot see anything thru the eyepiece. I've tried the focus screw, lens covers are off, and flip switch is in correct position. Anyone know the answer?
Put the eyepiece with the largest number written on it into the TOP of the scope eyepiece holder.
Practice focusing on a distant object during the daytime. It may take several turns of the focuser know.
Also check the TINY setscrew on the side of the focuser knob. It may be loose and need tightening so it will GRIP the focuser shaft.
Aug 19, 2010 | Meade ETX90AT Maksutov Telescope with UHTC...
Leupold Windriver Cascade 10x42 eyepiece jammed
Sounds like one of the eyepiece screws underneath the eyecup has come loose. The rotating eyecup is threaded underneath so it can rotate into up or down position on the eyepiece. If this is the case your Cascades are under warranty and it sounds like you should send them to Leupold to examine them. They are a very reputable company and I doubt they would put it down to user misuse if that isn't the case. Bear in mind that if you have been using them in the field and have had muck on them a small foreign object may have worked its way into the eyecup thread.
May 16, 2009 | Leupold CASCADES 10X42 CAMO
My flip video camera froze.it wont turn on....
Have you tried resetting the camera? Hold down the power button and the red button simultaneously until the camera shuts off (takes about 10 seconds). Then, just press the power button again and the camera should turn back on. I had the same problem; when I pressed the red button to stop recording, the camera froze, and the red light remained on. I tried resetting it like this, and it seemed to work.
Jan 19, 2009 | Pure Digital Flip Video Ultra Camcorder
What is a Veiw Finder
It's where you find a view of what the light coming through the lens. Today's consumer camcorders place the viewfinder center-rear usually with a rubbery piece around the end as an eyepiece/cup. Many units shut off the image to the eyepiece if the flip-out LCD screen on the side is used.
Jan 15, 2009 | Sony Handycam CCD-TRV68 Camcorder
My flip mino wont turn off
Easy Fix bro,same thing happened to my mino when I let my friends fool around with it.
Soulution:See the tripod mount,theirs a little hole in it,and thats what your gonna use to fix it.Just get something small I recomend a paperclip,and bend it into an S shape.Put the point of it in that little hole,it triggers a restart for the camera,and boom!Its fixed.Worked for me.Proved by the Flip Company.
Hope this helps
Jan 14, 2009 | Pure Digital Flip Video Ultra Camcorder
Etx cant focus
The LPI camera will HIGHLY magnify the image-- about like a 6mm -8mm eyepiece-- tiny adjustments are needed to focus. You can buy a .5 or .3 focal reducer which will widen the field of view and make it easier to focus--
On my LX90 --- it takes about 20 TURNS of the focus knob to go between the eyepiece view and the camera view!
Jan 11, 2009 | Meade ETX-125EC (500 x 127mm) Telescope
How to reset dvd recorder to ntsc from pal
After checking today to see no one offered any suggestions - I solved the problem the hard way - I went into settings and although the screen rolled, I was finally able to click onto the ntsc setting after about a half hour of tries and once I clicked it, my screen returned to normal -- i was then able to enter the code that made the player an all region player and was happily able to play a pal dvd I received recently. The procedure was simple -- offered by a European Cyberhome user -- the company is in bankruptcy so you cannot gt help from them. Note - my Cyberhome dvr is 1500- not 1600 as you listed it.
Feb 11, 2008 | Cyberhome DVD Recorder - DVR1600
Zr65 question
go to canon website there is a recall for zr65 camcorders, they will fix it for free
Oct 17, 2007 | Canon ZR70MC Mini DV Digital Camcorder
Very unclear picture when in camera mode
This problem has been answered and solved. It's a defect which Sony will fix. Go to their web site and service /support should explain what the problem looks like and that (if your problem really is the same) they will fix it free including shipping. I've done it already on my CCD-TRV318.
Jan 18, 2007 | Sony Handycam CCD-TRV318 Camcorder
Sony Handycam  HDR-HC5 Camcorder Logo
128 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
