Question about Kenmore 63032 Electric Dryer
Dryer will not start
I have a kenmore 800 i dried 2 loads and went to put the third in and nothing i have change fuses and check my circut box please help
  • 525 Answers
Your dryer may have stopped itself if the motor overheated. Try it again, if still dead, recheck your fuses, (should be 2-30amp), replace both. Door switch may have failed or door is not making contact with switch.
For more help, locate your model no. and follow this link, it may provide you with some adiitional info. that I am unable to provide without the model no.
http://www.repairclinic.com/0088_8_1.asp#Level1_1
Thank you,
Dave E. (Illeagle)
Posted on Jun 08, 2008
I have a kenmore dryer 80 series it only makes a lite sound when I push the start button. I won't come on. The power is good.
The Kenmore 80 Series of dryers are consumer grade dryers for home use. As with most home appliances, the Kenmore 80 series dryers will occasionally not work as intended. If a problem occurs with your dryer, however, you do not necessarily need it serviced by a technician. You can attempt to troubleshoot and fix any problems with your dryer before contacting a technician.
  1. Kenmore 80 Series dryers may not run for several reasons. First, make sure that the power cord is plugged into a working power outlet. You may need to plug a different device into the outlet to check that it is receiving power. If the second device does not run on the power outlet, you may have blown a fuse or tripped a circuit breaker. Check your fuse box or circuit breaker box and make the change as needed.
    Next, make sure that the dryer door is fully shut. The dryer will not run with the door ajar.
    Finally, check that the "Start" button was fully pressed and that a cycle was chosen on the machine. If you do not choose a cycle for the dryer, it will not run.
  2. If your Kenmore 80 Series dryer does not heat up during use, check that a heat cycle has been chosen for the load. There are several different dryer cycles you can choose, some of which do not use heat. Make sure that you have chosen a heated cycle.
    As above, check that you have not blown a fuse or tripped a circuit breaker. The dryer may use more than one fuse or breaker: one is used to power the drum, and the other for the heating element. Make sure that both fuses or breakers are in working order.
  3. There may be times when Kenmore Series 80 dryers do not fully dry your clothes. When this occurs, check the lint screen and clear out any lint. The air may not flow as well if the lint screen is clogged.
    Next, check to see if the exhaust vent is clogged. Lint and other particles may clog the exhaust vent over time, restricting air flow and making it more difficult to dry your clothes. To check the vent, run the dryer and hold your hand under the vent. If you do not feel any air flow, clean or replace the vent.
    If you used cold water to rinse the clothes it may take longer than normal to dry. The same is true if the load of laundry is very wet or is filled with items that are very absorbent.
    Finally, check the load size. The more clothes in the load the longer it will take to dry. If you want to reduce drying time, separate the clothes into piles of light and heavy items and dry them separately.
  4. please comment on these solution by saying how helpful.
Dec 22, 2010 | Kenmore Dryers
Kenmore Dryer Model No. 110.64632300
If it is 6 years of age or older and have a lot of use in the past you will be better off replacing it. The cost to repair it will outweigh its age and cost to repair
May 20, 2010 | Magic Chef CYE4000AWW Electric Dryer
Still more of the same
The exhaust is clogged or restricted holding too much heat in the exhaust housing or the limit t-stat has gone bad. This is the t-stat sitting next to the thermal fuse. Good luck.
Feb 11, 2010 | Kenmore 400 6942 Dryer
Kenmore Dryer won't turn on
Hi...
This are the tipe on how to Troubleshot dryer follow the steps below
IF the dryer is noisy
Level the dryer
Check the drum belt
Check the drum support rollers
Check the idler pulley
Check the glides
Check drum bearings
Check the blower
Check the baffles
If the dryer tumbles, but there is no heat
Check for proper air flow
Test the safety fuse
Test the thermostats
Test the centrifugal switch
Test the timer motor
Test the heating element
Good luck !!!!
Regards
PCmania
Jul 03, 2009 | Kenmore 63942 Dryer
Kenmore dryer does not turon on
CHECK THE FOLLOWING---
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer/control
Replace if defective (note: uncommon problem).
May 31, 2009 | Kenmore Dryers
My whirlpool heavy duty dryer just quit working all of a sudden
make sure you are getting power first then check to see if the belt is broken
Apr 21, 2009 | Dryers
My dryer doesnt work
check the door swich to be sure made up properly
Dec 29, 2008 | Kenmore 659 Electric Dryer
Kenmore electric dryer series 90 model 66904691 will not start. Dryed a load of clothes went to start again will not do anything , checked fuse box, fuse not blown what could be the problem
Check the automatic door shut off switch and wiring. When the door closes it actuates a switch (completes and electrical circuit) which allows the dryer to operate.
Aug 23, 2008 | Kenmore Dryers
Dryer f51 error
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Nov 04, 2007 | Kenmore 67082 Electric Dryer
Kenmore 63032 Electric Dryer Logo
81 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
