Question about Honda Water Pump Honda Engine
How can i adjust the fuel flow on the honda cm-2403 washer
    Scholar:
  • 100 Answers
The engine on this unit uses a gravity feed system, there really shouldn't be a need to regulate the fuel pressure on the unit, if you really needed to you would have to put in a inline fuel valve and regulate it that way.
Posted on Oct 25, 2010
SOURCE:
Have honda gx340 11hp pressure washer and gas keeps going into oil?
Excessive fuel entering the inlet manifold, carby needle and seat not shutting of fuel flow , remove and clean fit new gaskets and needle and seat if worn.
Jul 02, 2015 | Honda Gx340 Gas Engine 11hp Motor Pressure...
2002 Honda CM 125 C only running on one cylinder
Hi, Martin you need "FIVE" things in order for a cylinder to run properly:
1. FUEL: in order to validate your not getting fuel spray some starting fluid into the air cleaner and hit the starter button, if it fires up and runs for a few seconds then you know you have a fuel delivery issue. Multi carb banks should be bench "SYNC"
2. SPARK: remove the spark plug and with it connected to the spark plug cable ground the threads to something metal you should see a bluish white spark if not you have a faulty spark plug, spark plug cable, ignition coil, condenser, CKP, ECM, sensor or the wiring in between.
3. COMPRESSION: you must have at least 80-100 PSI for most bikes, multi-cylinder engines should be within 10-15% of each other if not perform a leak down test you may have a burnt or bent valve or hole in the piston or broken rings.
4. CAM TIMING: confirm your timing marks are aligned to see if the cam chain or adjuster are worn out and the chain has skipped a couple teeth.
5. IGNITION TIMING: on older bikes check to see if your points have not closed up, timing plate has not become loose and confirm with a timing light for proper retard and advance functions, on newer bikes where timing is controlled by an ECM and is nonadjustable check you CKP, TPS, MAP, O2, sensor or its counterpart for integrity.
For more information about your issue and valuable "FREE" downloads that you will need for viewing and printing please click on the blue links below. Good luck and have a wonderful day.
Running on one cylinder
honda cm 125 running intermittently on one cylinder
Honda CB125 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CB Owners Manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 29, 2012 | 2002 Honda CM 125 C
How do I replace pull starter rope?
remove the pulley housing cover.Remove the remaining rope pay attention as how its' threaded.Loop the new rope exactly as the old one.That's it
Oct 21, 2012 | Mi T M Mi-T-M WP-2403-3MHB NA 2400 PSI 5.5...
2000 Honda CM 125 C valve clearance
Hi, Halid_69 for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://hondacg125.awardspace.com/valve_clearance.htm
CG125 HONDA CG 125 VALVE CLEARANCE ADJUSTMENT TUTORIAL
http://www.aabdedah.com/honda_cm_125_c_repair_manual_download.pdf
Please Check First
Nov 01, 2011 | 2000 Honda CM 125 C
Error code ld
This error code indicates that drain times are longer than expected.
Click the following to learn more about proper drain systems for BravosTM washers. The example shown is for an impeller washer but is applicable to washers with agitators.
Is the drain hose kinked or clogged?
Make sure the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. See the Installation Instructions for details.
Is the end of the drain hose more than 96" (244 cm) above the floor?
The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 39" (99 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer. See the Installation Instructions for details
To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, and both of the questions above have been checked, call for service.
Hope this helps.
Jun 29, 2011 | Maytag Washing Machines
What to do when there is an error saying Ld?
Hi, This error code(Ld) indicates that drain times are longer than expected.
1.Make sure the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose
2.The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 39" (99 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer.
If Pause/Cancel does not work:
3. Re-select the cycle and press Start.
Thank You
Sep 04, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a 5.5 Honda pressure washer, no fuel is getting to the spark plug. Cleaned carb, carb is getting fuel just not flowing into combustion chaimber. It has to be a carb problem ! What part of the carb....
The float and the valve it is connected to let fuel into the carburetor. The flow jets meter the fuel into the engine. These jets have very small holes in them and easily plug up. You might want to get a complete overhaul kit for your carburetor so you'll get new gaskets, and other wear parts .
Aug 14, 2010 | Honda Chipper Blower and Vac: 5.5 Hp Gas
Where is the idle screw, air/fuel adjustment screw on a VT750Cd
It just need to be perfect keep trying different air flows
Aug 18, 2009 | 2002 Honda VT 600 CD Shadow
Fuel mix for a excell VR2522
should be a honda gcv 160 5,5 horsepower engine.
do a search for honda engine carburretor adjustment, plenty of pages on the internet detailing how to adjust carbs, mixture etc.
Excell Pressure Washer Model VR2522 Replacement Parts repair kits ...
lok at this site , parts breakdown of engine etc
Jul 18, 2009 | Karcher 2500 PSI Pressure Washer
Honda Water Pump Honda Engine Logo
70 people viewed this question
Top Honda Tools & Hardware - Others Experts
Keith Bowers
John Loiselle
Level 1 Expert
Bill Boyd
Are you a Honda Tool and Hardware - Other Expert? Answer questions, earn points and help others
