Question about Microsoft Zune JS8-00001 Digital Media Player
30 gig zune (white)
I´ve had a 30gig zune for almost 2 years now and i just recently dropped it and the screen cracked. now the left side of my zune is black and i cant see my menu. can i fix it?
  • Matt Gal Jun 09, 2008
    Same problem here, i had it in my pocket while i was lieing down and i slept on it now my screen is all messed up.
    Problem Solver:
  • 8 Answers
Yes, it can be fixed. rapidrepair.com offers replacement screens for 89.99 and will even replace it themselves if you decide to send it in to them. at this point in time, you might be better off buying a new zune 30 (considering i got a brown one for my sister for about 60 off amazon over Christmas) or just saving up for an 80.
Posted on Jul 11, 2008
My 30gig zune is froze and unresponsive. Please help
there is a "lock" button on the top on the left side make sure this switch is turned to off.
Try one or more of these solutions to resolve this problem:
  • The Zune may be locked. Move the hold switch to the unlocked position. It may help to move the switch back and forth. Then press the play/pause button for a second.
  • The battery may be drained.try recharging it
  • To reset your Zune, press and hold the back button while pressing up on the Zune pad. Resetting turns Zune off and on again.
May 27, 2009 | Microsoft Zune JS8-00001 Digital Media...
Tip
Reset 30 gig zune
if your zune locks up it is more than likely a bad music or sound file. the best way to unfreeze your 30 gig zune don't laugh it works by putting your zune in the freezer to clear memory and batery.
step1. put it in the freezer for 1 hr
step 2. remove from freezer and allow to come to room temp
step3. plug in and recharge fully
step 5. reload music on zune
on Feb 18, 2010 | Audio Players & Recorders
Zune pad 120 Gig
After researching several blogs and forums on problems with previous versions of Zune
the general concensus was to allow the batteries to drain away and die completely,
and then try reconnecting.
This took about a day and a half, and when we connected the device to the PC
it must have "re-initialized" the controls as it booted up, all the features now worked.
Happy 18 year old, more importantly, Happy parent.
Hope that this helps......................
The Ladd
Jan 08, 2009 | Microsoft Zune JS8-00001 Digital Media...
My Zune 30GB is frozen on the start up thing!
Disassemble and disconnect the battery for about 10 seconds. All Zune 30's apparently siezed this AM. MS is working on their solution, not sure when it will come out. The battery disconnect is at least a temp fix. Mine works fine after doing it.
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
Freezing
See teh Zun.net site The 30 Gig Zunes have a bug in how it processes the date. Per MS it will fix its self 1 Jan 2009
http://forums.zune.net/ShowPost.aspx?PostID=408989
My 30 gb zune is frozen
There's a fix:
Your zune will need a "hard reset."
To do this, use a small screwdriver to pop off the plastic shielding where the zune cable plugs into and remove the two screws on either side of the plug. Next pop the cover off and locate the battery plug at the top left corner of the zune, using your screw driver, pop the cable connection half way off, and do this to the other plug on the right side. Wait 3 seconds, then push down the right connector and then the left battery connecter. Your zune should start up immediately. Press the backing of the zune down (make sure headphone jack is aligned) and put the screws and cover back in place.
It's an easy process but if you're unsure don't attempt it.
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
30 gig Zune is froze up
Mine is locked up also. I tried the back and up keys simultaneously and nothing happened. The screen is stuck on the zune logo with the white bar on the bottom.
30 gig zune frozen on "ZUne screen"
Theres a note on the zune website about this issue today... Looks like its microsofts fault! At least I feel better knowing I didn't break my zune!
Dec 31, 2008 | Microsoft Zune 2nd Generation Digital...
Says all 30 gigs are full, but no songs on Zune
you should try calling a product hotline and hopefully get it fixed but if that doesn't work then your computer probobly has something wrong with it. otherwise, you zune is busted. hope this helps.
Jun 24, 2008 | Microsoft Zune JS8-00001 Digital Media...
Rello 30gig zune need help
you can try and reset it by holding on the back button, and up on the d-pad. that should work it did for my 30 GB
Jun 20, 2008 | Microsoft Zune JS8-00001 Digital Media...
Microsoft Zune JS8-00001 Digital Media Player Logo
209 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
