Manual required for behringer cx 2300 crossover
2 Suggested Answers
SOURCE:
  • 1140 Answers
SOURCE: i need to get step by step direction to set up a behringer cx 340
You will need to carefully read all your manuals and proceed step by step Here is the first one to look at:http://www.behringer.com/EN/Products/CX3400.aspx This crossover goes between the output of your board and the input of whatever power amps you are using. It has sections describing each setup and by what you have said, if you have enough amps you would probably need to run stereo 3 way which is described on pages 9,10 and 11. This would allow you to run a mono sub out setup. The grey areas are the connections and controls you use. Make absolutely sure your cables match the ones in the diagrams and read and heed carefully all the warnings. As far as your E.Q. and your Compressor they are separate topics as they are signal processors and are hooked up in the signal chain of your mixing board. They condition the input signals. Your crossover belongs in the output stage which as mentioned before is from the output of your board to the input of the crossover then from the outputs of your crossover to the inputs of your amplifiers and then on to your speaker systems. Try to find a friendly person on your end who does sound on a regular basis and has experience setting up and troubleshooting connection problems who wouldn't mind trading some advice for whatever help you could offer them. You have some good gear there and although there are people who will give Behringer gear a bad rap, I have never experienced any problems with mine. You absolutely have to understand all your gear inside out and not try to make it do something it is not designed to do. You also have to make sure you understand the differences between balanced and unbalanced cable connections and only use good quality cables designed for each application. If you're good at soldering and understand all the theory and want to do the work you can probably buy in bulk and customize everything to your own purpose. Enjoy your new equipment.
Posted on Aug 28, 2009
Testimonial: "good advice, will used them "
Behringer super x pro connection diagram
go to behringer.com and download the manual
Aug 26, 2014 | Behringer Audio Players & Recorders
Manual behringer fbq 1502
you can download a manual at this link (it's a link direct to the manual, so you only to save or print it, it will appear on your screen)
http://www.behringer.com/assets/FBQ6200_FBQ3102_FBQ1502_M_EN.pdf
There is a quickstart guide also, on the page where I got the manual download from
http://www.behringer.com/EN/Products/FBQ1502.aspx
24.August.2014
Aug 24, 2014 | Behringer Audio Players & Recorders
Behringer q802usb manual
just on the behringer site
Aug 06, 2014 | Behringer Q802USB Mixer
How do I connect my behringer fbq1502 to my behringer professional mixer dx750.?
You have a sent and return http://www.behringer.com/assets/DJX750_M_EN.pdf
They explain it in the manual but the output from the mixer and between that the equalizer and the equalizer output to the speakers works great, not the tape..... they have a way lower S/n ratio and i've never heard of this solotion
Jun 19, 2014 | Behringer FBQ6200 Home Equalizer
Behringer dcx2496
you need to calibrate the unit to your amplifiers, read the manual to learn how to do this
Mar 03, 2014 | Behringer Ultra-drive Pro Dcx2496...
Behringer cx2300
follow this instructions and fix it. God bless you
Instructions
    • 1
      Plug one end of a shielded input cable into the mixer's main output, and the other end into the crossover's input. The cable connectors will be dictated by your particular mixer and crossover, and will be either standard 1/4" or 3-pin XLR connectors. Consult the owner's manual of all components for specific details and recommendations.
    • 2
      Plug another shielded input cable into the crossover "high" frequency output, and the other into the crossover's "low" frequency output.
    • 3
      Plug the cable coming from the crossover "high" output into the channel one input on the stereo power amp, and the cable from the crossover "low" output into the channel two input of the power amplifier.
    • 4
      Plug one end of the unshielded speaker cable into the power amp channel one speaker output, and the other end into the horn tweeter.
    • 5
      Plug one end of the second unshielded speaker cable into the power amp channel two speaker output, and the other end into the woofer. The connections are now complete.
Jul 13, 2013 | Behringer cx2310 super-x pro crossover...
Owners manual for Behringer xenyx 1204 USB
Behringer has the documentation for the Xenyx X1204 USB Mixer on the product page: http://www.behringer.com/EN/Products/X1204USB.aspx . See the drop-down menu labeled Documentation on the left side of the page; it's below the list of stores that sell the unit. The owner's manual is at the bottom of the list in that menu.
The file is a PDF so you will need Adobe Reader or a similar program to display the 3.1 MB file.
I hope this helps.
Oct 24, 2012 | Behringer XENYX X1204USB/1204 USB...
I need to get step by step direction to set up a behringer cx 340
Aug 27, 2009 | Music
Behringer ex 3100 manual
manual can search in a web site ,,just type GOOGLE when you are in googles type behringer ex 3100 manual
Jun 18, 2008 | Audio Players & Recorders
504 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
