WD-65833 and SC-PT750 DVD has sound no picture
WD-65833 and SC-PT750 system - DVD has sound no picture, it is connected to HDMI 2.
  • 19,396 Answers
Check cable connections first, it is common cause for this problem.
Posted on Jun 07, 2008
  • 13,433 Answers
Double check connections, try another input / output.
Would like to have a owner user manualand a product manualfor a panasonic universal remote control EUR7662YWO
You are likely to find the instructions for the EUR7662YWO remote in the manual for the home theater system. The main unit is the SA-PT750. The entire home theater system is SC-PT750, see the support page: http://shop.panasonic.com/support-only/SC-PT750.html . The direct link to the manual is ftp://ftp.panasonic.com/hometheater/om/sc-pt750_en_om.pdf . The code list for the remote is on page 10. Page 15 has more on using the remote control.
I hope this helps.
Sep 06, 2016 | Panasonic Audio Players & Recorders
White vertical lines after changing dlp chip and lamp on Mitsubishi WD-65833. good picture in background.
had white dots on mine as well i changed the dlp chip and put it back together and got the white vertical lines i decided to check all connections and make sure the chip was locked in correctly
it was not locked in securely i reassembled and now problem solved picture looks brand new so always check connections before assuming its the dmd board
Aug 25, 2012 | Mitsubishi WD-65833 65" HDTV
I cannot get a picture from my sc-bt100 on my screen the sound is working no problem checked all leads and connections
How are you hooking it up? To what kind of TV? Best connection for SC-BT100 is via HDMI out on SC-BT100 to HDMI in on TV, otherwise you aren't getting full HD output. Make sure your TV is set to correct input source.....
Dec 27, 2009 | Panasonic SC-BT100 Theater System
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
Hdmi 2 wont work on mitsubishi wd-y65
It sounds similiar to a problem we've had with ours, all components would work in hdmi 1, but hdmi 2 would only work intermitently. They ended up replacing the digital board (fortunately we have the extended warrenty, I'm sure it's not cheap). Sorry hope this helps.
Feb 14, 2009 | Mitsubishi WD-Y65 65" HDTV
I just bought a dvd home theater system sc-pt760 and i have a 42 inch LG flat screen and the sound wount work on AUX for the TV
Are you using the HDMI connection on both units, the SC-PT760 does have a HDMI input Yes/NO ? If not then it has HDMI output to the LG for HD Picture. What I would do if no HDMI INPUT to the SC-PT760 is available, run out of the TV with the Digital connection into the SC-PT760 Digital Audio in, assign the input as tv and you shoild get TV audio out of your home theatre, you could also use the analog connection audio out of the tv to the home theatre but this would not yield a dolby digital sound.
Feb 02, 2009 | Panasonic Home Theater System System
Panasonic DVD Player stuck in Wait
I had the same problem. I had to take it in and have the caruousel realined.
Jul 09, 2008 | Panasonic SC-PT1050 System
Sc-pt750
As far as I know there isn't any composite IN ports on the back of the SC-pt750 so that would mean you would have to directly hook it up to the TV. I have an SA-pt750, which has an S/PDIF port on the receiver so I would run a cable from the TV to the receiver, from there if the SC-pt750 is set to AUX then it should output the sound from the TV to the speakers. Hope that helps, if you don't have that S/PDIF port I think you might be out of luck!!
Nov 12, 2007 | Panasonic Home Theater System System
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
