Question about HP Photosmart R725 Digital Camera
Charging flash I cannot take a phot with my flash on as it keeps stating charging flash... please help!
I get the same problem!
i take a picture and the flash is too bright, the picture turns out white.. then it takes a while to take another one because it says charging flash..
Posted on Jul 14, 2008
How do I transfer photos from my computer to my Hudl 2?
Hi. To transfer your photos from your computer to your Hudl 2, connect you charging cable to your computer. Make sure that your Hudl 2 is show under the 'My Computer' page of your folder section. Then select your phots and drag the into the Photos folder of you Hudl 2. This can be found by double tapping the Hudl 2 icon on your pc.
I hope this helped.
Aug 23, 2015 | Tablets & eReaders
My Samsung galaxy 10.1 tablet will not charge. It keep flashing between an empty battery symbol to a flashing yellow battery symbol. going Off and On. I can not get it to turn on at all. Im pretty sure...
Hi my Samsung galaxy tablet is flashing icon on and off signal but not charging? I have tried turning off for 30seconds still dead what should I do?
Jul 30, 2013 | Samsung Galaxy Tab Tablet PC
We have bought a battery charger HB 1206S DC6V - 12V 6AMP, but it does not state what is the state of charge do the lightes go out when it has reached changed state or light up please help
Product Detail Model No.: HB-1206S
The item is used for charging 6V-12V lead-acid batteries
Max Charging Current: 6A
AC Power Input: 64W
Output: 6/12V DC 3. 52A
Batteries Capacities: 15AHR-80AHR
Unit Packing: Colorful box
Dimension: 18cm x 10cm x 20cm
G. W. / N. W.: 1. 85KG/1. 75KG
Certifications: GS, CE, BS, ROHS, SAA
Main functions:
(1) The HB-1206S battery charger has the features of convenient operations, reliable safety and high performance.
(2) During charging, if turn up overload, the battery charger will keep itself at normal current and normal voltage with its self-automatic protecting function.
(3) If being short circuit, the battery charger will switch off itself, and turn normal after one or two minutes.
(4) The output current of the battery charger is very stationary, so it can protect the battery charger very well. It only costs 3 or 4 hours to fully charge the batteries.
(5) Indication of charging: the battery charger has 6 pilot lamps. The more pilot lamps shining, the less electric quantity is. The charging process finishes when all the pilot lamps go out.
(6) The battery charger can be switched between 6V and 12V, so it can charge for 6V and 12V accumulators. You can select 6V or 12V according to your own needs.
(7)The operations are very convenient: Put the red clip to the positive pole of the accumulator which indicated "+", and put the black clip to the negative pole of the accumulator which indicated "-", then plug in power source, the accumulator will be charged.
Aug 02, 2011 | GPS
I recently puchased an EGET MO-H04CD portable oxygen concentrator and I am having problems charging the Lithium batteries that were supplied with the unit. There are no instructions on how long you have to...
Red light normally means that the battery needs charging. The green flashing light can mean the battery is charging or has charged, and the same with the solid green light. Green in this case is good.
Charge the unit overnight and see what the indicator state is. It should not take more than 8 hours of charging for a Li-ion battery. Once you know what the full state light looks at, then you can tell what the charging indicator looks like.
In all cases, ensure you are using the proper charger with the unit.
May 14, 2011 | Health & Beauty
What does charging flash on photosmart m537 mean?
The flash gun needs to have a high charge available before it can flash - this can take a few seconds to charge fully ready to give off a full flash "flash" As batteries get older and uncharged - it takes longer to reach the correct charge on the flash
Hope that helps
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | HP Photosmart R707 Digital Camera
Every time I try to take a picture with a flash, camera just states "charging flash" but will not take the picture. Camera is a HP photosmart R927
IF your holding down firmly on the button and it just keeps saying that it is charging then you may have a serious problem. This sounds like it is defective. I hope it is still under warranty. If not you may want to consider a new camera. Sorry but no easy solution to that one.
Allen
Sep 11, 2009 | HP Photosmart R927 Digital Camera
Charging is Disabled
i have tried different chargers, but my phone keeps saying abnormal state charging disabled.
Apr 07, 2009 | Samsung Cell Phones
Phone keeps turning on while charging
its not a problem to charge your phone in "on" state.... you will get "charging full" notification even in "on" state
Sep 26, 2008 | LG KU990 Viewty
HELP! I have a JVC Camcorder,power is flashing and its not charging!
This seems to be some sort of model problem as I have the same problem. I have bought two new batries and both of them are now in same state " simply they won't charge"!!! :(
Oct 12, 2007 | JVC Video Cameras
HP Photosmart R725 Digital Camera Logo
91 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
