Panasonic printer dp4520 error code j40
Getting error code j40 misfed paper, have opened everything the printer lets me open and see no paper...not even were paper might be. Printed something not work related would like to fix quickly.
  • Anonymous Dec 02, 2008
    COD 133
    Problem Solver:
  • 18 Answers
This indicates there is a paper in the fuser area(very Hot section be cautious).1. open the front door.2, open the left side door. look inside for a green plastic handle & lift up he metal guide plate sometimes the paper gets wrapped around the upper heat roller or curled up and around the separator claws. if so be very careful not to scratch the rollers or break the sep claws. there is a green handle/knob located in the machine that can be turned, this turns the fuser rollers and makes it a little easier to remove a fuser paper jam. After you remove the paper jam close all the doors/panels you first opened. the copier should reset itself. I have seen the pj errors change to a new one indicating another pj still exists. if so look again and remove as indicate by the Lcd screen. Please leave positive feedback if this helps
Posted on Nov 27, 2008
What does J40 code indicate?
Error Codes Panasonic Copiers
errorcodepanasonic.blogspot.com/.../error-codes-for-panasonic-copiers.h...Jul 17, 2011 - Error Codes for Panasonic Copiers problems solusions help ... J40-42, Fuser exit jam ... dp 8060 code e-501 plz tell the solution what can i do ... I need a help with my Panasonic DP8045 printer. ... DP 6010 DP 6020 G DP 6020 H DP 6030 DP 6030 G DP 6030 H DP 6530 DP 7000 DP 7240 DP 8016 P DP ...
2015/16 ICD-10-CM Diagnosis Codes J40.* : Bronchitis, not ...
www.icd10data.com/ICD10CM/Codes/J00-J99/J40-J47/J40-
Home > 2015/16 ICD-10-CM Diagnosis Codes > Disability of the respiratory system J00-J99 > Chronic ... Bronchitis, not specified as acute or chronic J40-
Nov 06, 2015 | Office Equipment & Supplies
I have a Panasonic DP180 with an error message J43 but I cannot find any 'misfed paper'. I have just changed the cartridge (only. Thank you and regards, Lynette
It seems that one of the switches under the toner cart is knocked off.Check and let me know, the update.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 09, 2010 | Panasonic Office Equipment & Supplies
I am having an issue with a Panafax uf-8000 printer. It grinds when starting up and says there is misfed paper. Don't see any.
Paper feeder sensor guide is open or displace ,So it said misfed paper.Clean sensor or right position set the sensor guide.
Dec 08, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Panasonic Workio DP-2000 j33 problem
The sensor arm just below the registration roller has dropped the spring to return it to it's home position.
Mar 27, 2009 | Panasonic Workio DP-2000P Copier
Remove misfed paper code J93
J93 means = paper remained in adf . sounds like you have a problem with the reed point sensor in the adf door . little black plastic arm , right side should be dangling
Jan 13, 2009 | Panasonic Workio DP-190 Multifunction...
I have a panasonic workio dp1810p printer/copier. Everytime that I turn it on I am receiving a "Remove Misfed Paper J92" error. I cannot find any paper jams and am having trouble finding out...
You could try the technique Peter, Samir, and Michael did in office space the movie. I find this technique to be quite effective for most problems with electronics in general.
Jun 28, 2008 | Panasonic DP-4510 All-In-One Printer
Panasonic DP-1810P Laser - J41 error code
i think the fuser sensor lever on your machine is damaged.
its the lever that you usually see when you open the cover the fuser unit.
Apr 02, 2008 | Panasonic DP-1810P Laser Printer
Panasonic workio dp-1810p
pls check out the sensor lever below the drum if it is freely moving.
because that is the sensor concerned for j33
Sep 01, 2007 | Panasonic DP-1810P Laser Printer
254 people viewed this question
jasbo
jasbo
