Question about Belkin N Wireless Modem-Router F5D8633au4A
Can only get internet access on main computer. Cannot get access on wireless or second computer. This worked until 2 days ago. I have checked all the connections and have tried to reset the router (I think). HELP--cannot do my business work without this working!!!
  • 2,277 Answers
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Posted on Oct 24, 2010
6ya staff
SOURCE:
Hi, I have a Linksys WRT56G2 V1 Wireless Router that worked just fine until 2-3 days ago... Now when I plug it in the power light is off, the internet light is on, the wireless light is off, and the 4...
1. the power supply to the unit has a malfunction.
the power light should be green to say that the unit is getting proper voltage if you see no light then the power supply is probably not working
If router is under warranty has manufacturer send a new one to you.
2. Try unplugging the router first for 30 second to a minute to see if your unit will restore if not a new unit is needed.
Oct 18, 2010 | Linksys WRT54G2 Wireless Router
Cannot find wireless network on Secondary computer
Try this, unplug the power from your modem, wait 25 seconds and plug it back in. Unplug the power cord from your router and wait 10 seconds.. plug it back in. Wait for the Wan/Ready/Internet light on your modem to stop flashing or go to its default position. Reboot your 2ndary computer. Try the internet again. If this does not help please post again and we will dig deeper! Good Luck!
Aug 30, 2009 | Computers & Internet
Problems with internet connection linksys wireless WRT54GS
hello i'd change it to belkin router good luck
shaun
Aug 24, 2009 | Computers & Internet
No internet connection
ok
check on back side of router then u see reset button press it for 10 seconds then it restart and also reset all settigns to defaults.then u have to reconfigure it,
u cna access your router with one of the following lionk
http://192.168.1.1
or http://192.168.0.1
type useranme as "admin" and pasword as "admin" or blank
May 09, 2009 | Linksys Wireless-N WRT150N Router
Linksys wrt160N router inconsistant internet connection
Check on your cables makes sure they are inserted properly and the cord should be free of kinks, scrapes or loose connections......Also check the back of your computer make sure your ethernet card (the one that has the green lights/LED's) is seated properly (not loose)....
Good Luck.....hope this helps...if not let us know....cheers
Apr 13, 2009 | Linksys WRT160N Wireless Router
Wireless network access: 1 laptop fine, other not so much
Check the wireless card on the PC first. Go to "My Computer" then "Device Manager" and check to se if all the hardware is ok.
Use Control panel/netconnections to check to see if you still have a wireless connection and if it works. Also check "My Network Places." Try re-installing the drivers.
As a last resort....try System Restore if it's an XP or Vista system. Remember - using system restore will return the PC to an earlier time but you could lose some stuff so decide first.
Mar 21, 2009 | Acer Computers & Internet
Tough issues with my Dynex wireless router. Please help!
Try to reset it to the factory specs and start all over again with install CD.
Mar 15, 2009 | Dynex Enhanced-G Wireless Broadband Router
Problem with ''long range'' connection...
problem is for the firewall enable dis able it
Mar 03, 2009 | NetGear WGX102 54 Mbps Wall-Plugged...
Network Cable Unplugged
mairelina, if all was well 2 days ago then resetting the router should fix your problem. usually a small button on the back of the router.
chelliepooh, you need to check that the router's wireless function is on. connect using the ethernet and go to the config page (usually 192.168.1.1) make sure wireless is on and security is set to wpa-psk.
May 19, 2008 | NetGear WGR614 Wireless Router
My router doesnt seem to be Broadcasting the wireless connecition!
it may be that the router is not assigning ip addreses properly, and is duplicating the ip address on all pc's. or you have done the windows diagnose and repair or detect problems. Go to the properties of each wireless card in control panel>network connections and on the TCP/IP line click propertes again and ensure obtain ip address automatically is checked. Also go into the routers settings and ensure DHCP is enabled to give all pc's an automatic ip address. Restart all pc's and your router (not Reset) and you should get renewed ip addresses and be able to connect.
Sep 13, 2007 | SMC Barricade g SMC2804WBRP-G Wireless...
Belkin N Wireless Modem-Router F5D8633au4A Logo
37 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
