Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Oven's digital temp display too dim to read
The oven & controls work but the digital display (temp, broil level, preheat) has faded away completely. Do I need a new fuse?
  • 1 more comment
  • Anonymous Jul 06, 2008
    Digital clock and timer are fine, but oven temp. and setting almost impossible to read. Thermostat works OK. Frigidaire Gallery free-standing range.
  • bakrislin Sep 08, 2008
    preheat cannot read temp anymore but when reaches the temp. it stills bongs.
  • Anonymous Mar 17, 2014
    how do i find the model number on this type of oven. i need a manual since i cant figure out what any of the buttons or knobs do, even though its probably useless anyway since the electronic display has just about melted away and is completely illegable.
  • 413 Answers
The electronic control board will have to be replaced
Posted on Jun 08, 2008
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
General Electric oven how to reset thermostat
First of all, most oven thermometers move very slowly compared to the electronic sensors and controls on the oven. To make sure you are getting an accurate reading, the thermometer should be in the center of the oven, the oven should be preheated, then wait another 20 minutes after the preheat beep. If the temperature is less than 35 degrees higher or lower at this point, it can be adjusted via the controls. Usually on GE ovens you press and hold bake and broil at the same time until SF comes up in the display. Then press bake, then use the arrow keys to raise or lower the temperature setting. If the temperature is more than 35 degrees off, you may have a bad sensor, bad control board, or other problem.
Aug 08, 2014 | GE Profile JTP18 Electric Single Oven
Model RBS275PDB12. I had a recent Power Failure. Since the oven has malfunctioned. When placed on bake the preheat timer does not display. At 350, the baking element gets warm. At higher temps the...
Good Afternoon! If your Whirlpool oven isn't heating to temperature, and your temperature sensor is reading good, the control board may be the issue. Fixyourboard.com can test and if necessary repair the control board in your oven. We back all control board rebuilds with an industry leading two year warranty. Contact us for more information- info@fixyourboard.com
Thank you!
Mar 30, 2017 | Whirlpool RBS275PD Electric Single Oven
Our Whrlpool Super capacity 465 oven will only let you preheat to 260 degrees. After 260 the display showing rhe temp. will not advance any higher. It will still broil when you push the broil setting but...
Hello, welcome to FixYa.
I'll start by saying your post indicates it is a Whirlpool oven, however if you could post the complete model number I can speak directly about possible remedies instead of generalizing...
**Though it may not be necessary as I believe your disply may be set to Celsius (centigrade, like Canada and Europe) instead of Fahrenheit since 260C equals 500F thus it tops out at 260...most ovens will not exceed this temp unless in a self clean cycle.**
I suspect if you refer to your operator/owners manual it likely will instruct you how to change it back to display the temperature in Fahrenheit.
Thank you for choosing FixYa. I'll need to watch for your reply before moving forward.
Regards,
Macmarkus :)
Apr 28, 2011 | Ovens
My Kenmore Elite oven will take over an hour to preheat to 350 degrees and never does get done preheating.
There's a few things that can cause this.
1. Check to see if the both that Bake and Broil elements (burners) are heating up. Check the Broil element in Broil mode.
- during pre-heat the Broil element gets cycled on and off for short time durations to speed up the heating. If the Bake element is not working, then the oven will heat, but very slowly and never reach high temperature.
2. If the elements are both working, then it's possible that you have a bad temperature sensor.
- this is a temperature dependent resistance device that should measure 1080 ohms at 70 deg F (room temp).
3. If #1 and #2 are ok, then the problem is with your oven clock/control unit. We rebuild these at fixyourboard.com.
Aug 14, 2010 | Kenmore Ovens
Temp/clock display faded
its the display that is going out on the ovenlike everything else things just fad away. Actually I have had LED meter displays do the same thing.
Dec 23, 2008 | Thermador SC302T Electric Double Oven
Temp/clock display faided
its the display theat is fading away. I've haad meter's do the same thing after awhile and there's nothing you or I can do. Thanks for using Fixya
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
620 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
