Question about Fisher and Paykel Dryers
Dryer is making loud screaching sounds like a siren takes a longer time to dry. Our model is DGGX1
  • Fisher and P... Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Oct 28, 2010
SOURCE:
The dryer is squeaking/squealing during operation. It is a high-pitched noise that is rather loud. It is also getting very hot. We vacuumed the lint bucket area behind the cover, which fixed the...
I am having a similar issue. I had a tech out to look at it and he recommended replacing the drum bearing and idler jockey pulley. ($419.95) Ouch. I am going to do this on my own. I ordered the part from paykelfisherparts.net. Part # 479332 Drum Bearing Kit $79.91.
Check here for more info. This was exactly what I found on my machine (DGGX1) http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/731-fisher-paykel-dggx1-top-load-dryer.html
I did not totally trust the repair dude. He was wierd and not very thorough. I can tell the bearing is bad, if there are still noises I will order up the jockey pully thing and see if I can figure that out.
Here is a link to the service manual. (https://docs.google.com/fileview?id=0B5If-wTgYWH5OGNkY2RmZDEtMWU4OS00MjgwLTg3OWEtMmRlZjY0N2I5MzYy&hl=en)
Good luck
Jan 17, 2011 | Fisher and Paykel DGGX1 Electric Dryer
Loud squeak in DGGX1 Gas Dryer.
heatman101
Sep 19, 2010 | Fisher and Paykel DGGX1 Electric Dryer
Do the Fisher Paykel Dryers DGGX1 take twice the drying time of a normal (Kenmore) dryer to dry cloths? I put in a load of towels and after an hour and a half they still weren't dry. My other dryer would...
make sure there is no lint build up inside the round housing where your lint trap goes. the holes in the housing sometimes plug up and you can't see it. one screw at the bottom and rotae slightly to remove. also make sure vent is clear
Jun 26, 2010 | Fisher and Paykel DGGX1 Electric Dryer
Gas dryer screaching noise
take the front off if it has belts take them off as well remember how the belt assembly is. grab the drum on top front and back and pull upward there it is.
Apr 16, 2010 | Dryers
My dryer is making loud screaching noises. Everytime I turn it on to dry clothes is makes very loud screaching noises.
Sounds like it needs what are called glides or felt. This is what keeps the metal drum from contacting the metal housing. If this is let go too long the drum can be ruined
Dec 01, 2009 | Dryers
Need blower wheel replaCDED?
If it was your blower wheel it would not make that noise first cheak and see if thewheel has play on the shaft if so then it will need to be replace second turn blower wheel by hand back and forht if there is a screaching sounds if is a dry bearing on the motor .If so if you can live with the sound it will not go right away if not remove motor and replace.If there is play on the wheel you will need clip pliers and normal pliers and remove both clip[ on shaft and clip on shaft revers after install new blower wheel good luck:)
May 07, 2009 | Maytag PYE2300AY Electric Dryer
Gas Dryer LDG7304AAE making horribly loud noise while drying
Solution for the Maytag model is most likely to replace the blower wheel. Remove the two screws on the front panel (just a couple inches off the floor) and swing the front panel up to allow you to unhook the top side of the panel from the clips at the very top of the front panel. You do not have to remove the wires, just set the front panel to the side. Blower wheel is at the lower left. The old wheel most likely no longer has a D shaped hole to match the motor shaft, and spins freely. Remove cover. Replace the wheel part number Y303836 for a LDG7304AAE which is held on the shaft with a spring type clamp. Reassemble. Not really very hard to do. On a difficulty scale or 1 - 10, I'd rate it a 3.
Dec 06, 2008 | Dryers
Kenmore 90 plus series dryer won't work
Sounds like the belt has broken. You could probably also use new drum support rollers. Check out this site which shows how to change a dryer belt:
http://repair2000.com/wpoolbelt.htm
It's not a difficult job if you're comfortable working with hand tools.
Oct 17, 2008 | Kenmore 62872 Electric Dryer
Dryers Logo
227 people viewed this question
Top Fisher and Paykel Dryers Experts
Nathan Van Boven
Nathan Van Boven
Bill Eager
jimorris77
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
