Question about Cameras
Using battery charger overseas
Can I use this battery charger with my Embark voltage converter and adapters. the specs on the voltage converter are as follows:Model MW165OR-25A
input"220/240V, 7.5A 50/60Hz
output 11/120, 15A 50/60Hz
selectable power Output 50W/1875W for use with class II electronic devices
the canon charger -input-100V-240VAC 50/60 Hz 0.085A (100V) -0.05A(240V)
output4.2V-----0.70A
    New Friend:
May be I have used a wrong charger and hence this problem. My battery is tested for full charge. But the camera does not operate on battery. I feel there is problem in the area of switching circuit between battery and external school power input. Clarify please.
Posted on Jul 08, 2016
    Champion:
  • 203 Answers
It's alway suggested that you simply use plug adaptors to change shape of plugs for overseas-do not reduce voltage since most all chargers including yours support 220 or 110
Posted on Jun 07, 2008
My transcend external hdd power unit is 5vdc .it has two usb one for power .i hv adapter that converts ac to 5vdc which is charger of my tablet.can i use it to power up hdd externally and connect another...
Without seeing the specs of the adapter it's hard to tell the voltage is correct but what you need to be concerned about is the amperage(mA) USB ports on computers only put out a max of 500mA per port the tablet charger could put out more than that.
Dec 04, 2013 | Computers & Internet
Tip
How to convert 220 volts to 110 volts for the iPod Touch
<p> <p>The battery of an iPod Touch prepared for use in the United States is designed to be reloaded from the current supplied by a 110-volt electrical system. Power is transmitted to the battery charger with an iPod battery, which are connected via a USB cable and then connected to a 110 volt outlet. To use the power of a 220 volt outlet with an iPod Touch, set the current 220 volts to 110 volts. A conversion adapter voltage, also known as "Step Down Transformer," it is necessary and can be obtained from an electronics store, a hardware store and even some drug stores. <br /> <p><br /> <p>1. Place the 220-110 voltage converter card (aka, "Step Down Transformer") next to a 220 volt outlet. Plug the adapter into the outlet. <br /> <p><br /> <p>2. Connect the end of a USB cable to the USB connector USB iPod charger iPod. Connect the other end of USB cable into your iPod's own socket on the bottom of the iPod Touch. <br /> <p><br /> <p>3. Plug the iPod into the 110 volt outlet in the battery adapter for the iPod Touch. <br /> <p><br /> <p>4. Unplug the charger from the iPod adapter and the adapter from the outlet when the battery is charged. Unplug the USB cable from the iPod charger and iPod Touch. <br />
on Aug 09, 2011 | Apple iPod touch
Hi, i have svoa labtop and now my charger adapter got burnt due to electrict short. Now my charger is not working and i cannot use it.
OK. But I don't understand what the problem is.
AC adapter (Charger) is burnt out, by a new one.
Look at the old 'charger'.
Look at the label.
Input: 100 ~ 240VAC/50 ~60HZ.
100 to 240 Volts AC, at 50 to 60 Hertz. (Cycles per Second)
Output:
This is what you need to know.
What is the output voltage of the original charger?
Example;
Output: 19VDC @ 4.63A
19 Volts DC at 4.63 Amps. (Amperes)
Your charger MUST put out 19 Volts. (For the example)
It WILL be DC electricity, so don't worry about that. (Direct Current)
[Your 'charger' is more than that. More than a charger for the laptop battery.
It is also a Converter. It converts the 100 to 240 Volts of Alternating Current, (AC), into a low DC Voltage.
Plus it charges the Battery, WHEN needed ]
Post back in a Comment as to what the exact query is.
Regards,
joecoolvette
Jan 25, 2013 | Computers & Internet
Toshiba c655d-s5133 plugged in not charging
Dead battery? Try another cord/charger with the EXACT same power specs.
Jan 25, 2013 | Toshiba Satellite Computers & Internet
How I can convert 110volts to 220 voltage in Craftsman charger 145301 because in the Peru country we use 220 v. thanks.
_Some_ chargers will allow a range of input voltages. This will probably be "Input: 100-240V" or something like that written on the charger. __You need to be sure__. Others may have a switch from one voltage to the other. The trick here is to make sure the switch is in the right position. In both cases you may also need a plug pin adapter. If the charger you have has neither of those abilities then you either need to get a different charger from Craftsman, or get a voltage converter, which will give both the right plug for your wall sockets and convert from 220V (from your wall) to 110V (to the charger). Unless the charger has voltage range or a switch, you can't just use a simple plug pin adapter.
Feb 20, 2011 | Craftsman Drills
I can't find the series # of my note book---- where can i get a replacement charger?
Any charger which fits the following conditions will be a good fit to your laptop:
1. Charger has a jack which fits in the laptop's power socket.
2. Charger can provide enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the charger. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery.
Alternatively, you can look for a universal laptop charger which is suitable for your laptop's model.
Aug 28, 2010 | Acer Aspire One PC Notebook
Voltage on Acer Aspire One -110 - 220?
It is 100 - 240 V.
All you needs is the Votage adapter, no converter needed.
Acer Aspire one rating 11.1V laptop battery. Charger Specs: Input Voltage: 100 ~ 240V AC 0.24~0.60A 50/60Hz Output Voltage: +12.6V DC Output...
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 14, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Can I use my battery charget for my camara in Greece?
According to this link, it says that the charger is 110-220 volts. You can look on the label and it should say "110-220", and if so, you should be good with only an adaptor vs. having to use a voltage convertor.
Mar 20, 2009 | Panasonic Cameras
MAKITACHARGER 220v to 110v problem after using of right converter
hi all,
I added another HowTo page for moding the DC18RA from 110V to 220V , you can find it here
Have fun and good luck
Jan 07, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Battery Charger for Trutech Portabel DVD player
As have been posted in a post of similar concern...
You can try calling Target Customer Service 1.800.440.0680 and inquire cost & availability of the charger for the TruTech PVS12701.
Additionally, you may want to contact the manufacturer direct.
ALCO Electronics, Inc.
8392 Six Forks Rd., Suite 104, Raleigh, NC 27615,
(800) 252-6123)
Should you need direct Customer Support, please try here.
Alternately, you can just look for an AC adapter/charger that has the following specs:
Input Voltage - your country's standard AC mains;
Output Voltage - 12VDC
Output Current - at least 1.5 Amp (the higher the better)
Connector - one that will fit and match the polarity of the TruTech PVS12701. (am guessing crown type center positive, pls confirm with the store. It may also help to bring along the unit when doing the purchase over the counter).
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Dec 19, 2007 | TruTech PVS12701 Portable DVD Player
Cameras Logo
233 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
