Question about Ultrex Crock Pots & Slow Cookers
I have Ultrex model 14037, the insert has 2 cooking compartments and I am looking for the insert that is one whole pot. Does Ultrex sell an insert for this model that is one large pot?
Need a lid for my Ultrex II, model 11771c
Fixya does not sell replacement Ultrex lids. Ultrex is a possible source.
Apr 18, 2018 | Ultrex Crock Pots & Slow Cookers
What temperature does the Ultrex slow cooker cook at on high or low?
Have you used it before or is it new? Slow cookers vary when it comes to cooking on low or high. If you never used it before, I suggest that you find a slow cooker recipe that cooks slow 10-12 hours and see how that works.
Jun 10, 2017 | Ultrex Crock Pots & Slow Cookers
Where can i find a manual for ultrex pressure cooker?
The company had a major recall and went out of business. No manuals appear to be available on the web.
Here are some general instructions you can use:
1 Set up your cooker. Place your Ultrex Pressure Cooker on the stove. Remove the lid and pour in no more than 2 inches of water. Depending on what you are cooking the amount of water will vary. More water will ultimately cook larger amounts of food, but you will need to refer to your specific model's instructions on this matter.
  • 2 Put in the food you wish to cook. Close and lock the lid firm to the pot. Make sure it is locked securely so none of contents boil out of the top.
  • 3 Turn on your burner to high heat for approximately ten minutes. Allow the water to boil.
  • 4 Turn the stove down to a low setting after the water is boiling in the cooker. Flip the pressure valve closed and allow your food to simmer.
  • Set the pressure valve to ten pounds. For vegetables, cook 30 to 45 minutes. For meats, cook 45 to 60 minutes.5
  • 6 Open the pressure valve and allow the pressure to discharge. Unlock and remove the lid to find your fully cooked meal.
  • Aug 25, 2014 | Ultrex Crock Pots & Slow Cookers
    MY INSERT CRACKED ABOUT 15-30 MINUTES INTO COOKING A ROAST
    Addendum to my clarification request: "Are you asking where to buy a spare crock pot for an Ultrex 2-in-1 (9qt) 8-Quart Slow Cooker?"
    Spares are not available. This is an exclusive product to the Home Shopping Network and all you can do is to see if they'll honour any warranty given when you bought the product. If it's outside of the warranty then forget it; my own research and personal experience of HSN supprts my personal opinion that they really are a "fling it and forget it" retailer and as slippery as a handful of eels when it comes to honouring their promises.
    Search on FixYa and you'll see that many other people have also suffered the same fault with your product.
    Oct 06, 2009 | Ultrex 2-in-1 (9qt) 8-Quart
    Auto Cook option on my ultrex crock pot??
    Autoi setting starts the slow cooker on high and the switches to low automatically, you get much better results with this option
    Sep 16, 2008 | Ultrex 2-in-1 (9qt) 8-Quart
    Ultrex pressure cooker model innova 14240
    Pressure cookers are only slightly more complicated than crock pots. In fact, you can think of them as the opposite of Crock pots. Where a crock pot needs 2-3 times as long to cook something, the pressure cooker needs only 1/2 to 1/3 of the time.
    These are not that complicated and haven't changed in the last 50 years. The only real hard part is being sure is doesn't explode; not that hard: don't cook things that would foam, like pasta or potatoes. Just read some recipes on the internet or get a recipe book at a bookstore, used book store (super-cheap)or the library. My best advice is to make sure you use the lowest possible heat that still allows steam to escape at a whisper. That will keep things from burning (or scorching) on the bottom, which can give a harsh taste and make clean-up more work. Just do it.
    Jul 20, 2008 | Ultrex 2-in-1 (9qt) 8-Quart
    Ultrex model 08393
    My inside crock also crackes. Where can I get another?
    thanks,
    May 20, 2008 | Ultrex 2-in-1 (9qt) 8-Quart
    Rival SCC658 Smarl Pot Slow Cooker
    GOOGLE is your best friend!. Entering Rival, Slow cookker parts brought up dozens of authoorized parts sellers...including Rival
    Jan 25, 2008 | Rival SCC658-SS 6.5-Quart
    Ultrex Slow Cooker
    Anwser NO! My Roasting pan craked at 4OO degrees cooking a Chicken!
    Nov 22, 2007 | Ultrex 2-in-1 (9qt) 8-Quart
    Replacement lid for Ultrex
    Please keep in mind that the brand Ultrex was sold by The Home Shopping Network, not QVC.
    Nov 16, 2007 | Rival 38601 Smart Pot 6-Quart
    Crock Pots & Slow Cookers Logo
    105 people viewed this question
    Top Ultrex Crock Pots & Slow Cookers Experts
    Marvin
    Marvin
    Andrew Taylor
    Andrew Taylor
    ray gallant
    ray gallant
    Are you an Ultrex Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
