Question about Hoover 24 in. HD97E Free-standing Dishwasher
Takes on water ok, heats and drains but spray arms dont move
  • 4 Answers
You will probably find that this is because there is not enough water pressure going through the jets.
1. Take off the top rotery arm by unscrewing the nut and then it can be released from the basket by giving a twist and pushing backwards. once off check that all the jets are clear and that the small plastic washer is OK re assemble and ensure that is spins freely.
2. if this does not help then the problem may be with the recirculating pump underneath. Replace the capacitor that is attached to it. This drastically improved my dishwasher and now works better than when it was new.
3. if this does not work then you are on your own as I have no orther suggestions.
Posted on Jan 23, 2011
SOURCE:
Spray arms not working
Hi frustrated in Raleigh,
I understand that the spray arms are not moving or spraying water, even after you have cleaned the screens and arms. What might be happening is you are not getting enough water pressure to the dishwasher.
The hot water line to your dishwasher must provide water pressure between 20 and 120 psi.
Low water pressure may occur when laundry or showers are in operation.
Wait until water use is reduced before starting dishwasher.
If you are still noticing that the spray arms are not moving or spraying water, I would have a local Authorized Technician come out to see what exactly is going on with the spray arms of your dishwasher.
-Best Regards-
Jan 06, 2014 | Frigidaire FPHD2491KF Dishwasher
Diplomat dishwasher recirculating problems
I live in an area with hard water. My spray arms get clogged with hard water deposits. Are you sure the spray arms are clear? Here's a map showing hard water areas in USA http://www.citriclean.net/why-citriclean/
Dec 29, 2013 | Dishwashers
Maytag quiet series 200 dishwasher spray arms won't turn
Have you tried tighten the spray arms? They may have come lose at the fittings so need to be tightened up. You can normally tighten them with your hand. Take any traps/filters out of the dishwasher and clean them.
You may find answers here: https://www.maytag.com
Jan 15, 2013 | Maytag 24 in. MDB4000 Built-in Dishwasher
Dishes are always dirty, maybe even dirtier after running dishwasher. has hot water, lower arm moves.
Check the outlet holes on both spray arms for clogs. If necessary, remove the spray arms, clean out the holes and empty out any debris inside the spray arms. Verify that the upper arm is turning also.
If the machine does not drain completely at the end of the cycle, the pump drain outlet is partially blocked and you are retaining dirty water for the next load.
You may have a chemistry problem - inferior soap, empty rinse agent dispenser, or extremely hard water.
Improper arrangement of the dishes can prevent some from being washed. Make sure no dish blocks the spray to another.
Jul 23, 2011 | Dishwashers
Dishwasher drains OK ,heats water OK I can select programmes OK but the washer arms don't spin.....help please
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 08, 2011 | Whirlpool 24 in. ADG7540 Built-in...
Water squirts out but spin bars don't move
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jun 18, 2010 | Maytag 24 in. DWD1500A Built-in Dishwasher
Arms not rotating
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
tter
Mar 22, 2010 | Tappan 18 in. MDR251RE Built-in Dishwasher
Water not pumping out spray arms.
clog in the arm. It should spin due to water flow.
Remove the arm. Usually a tow part arm (top and bottom). Or a central screw with cover plate.
Look for a clog and remove.
If a central arm in the middle of the machine the clog can be in the pipe supplying the water. Again take apart and look for a clog.
They are not belt or gear driven. Simple water driven parts only. If the water is flowing and not leaking under the machine you should be OK with a simple clog somewhere.
Mar 07, 2010 | Kenmore 24 in. 17283 Built-in Dishwasher
Dishwasher
Plugged filter or spray arms .
Sep 30, 2017 | Dishwashers
Wash cycle
Check first that the filter located inside the machine (on bottom) is clean. In case it clean - The problem is with the pump. It could be a blockage between pump and the tub, or just a defective pump (The pump takes suction from the tub and forces water up through the spray arms, which spray the dishes. The water then simply drops back into the tub for recirculation). Good luck !!
Jul 01, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Hoover 24 in. HD97E Free-standing Dishwasher Logo
204 people viewed this question
Top Hoover Dishwashers Experts
Philip Postlethwaite
Vitally Alcher
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
