Question about CyberPower 525SL (CPS525SL) UPS System
Power keeps going on and off
When I turn on my UPS (Cyberpower CPS575SL) it turns on and then in a couple of seconds beeps and turns off again, then a second later it beejps again and turns on, then beeps and turns off. It just keeps doing this. There is no power outage, wiring fault light is not on & the cord is plugged in to the wall outlet. I have plugged it into another outlet and it is still the same. Does the battery need to be replaced or what?
Thank you for your help
Lynda
  • 1 more comment
  • Anonymous Jun 19, 2008
    well my power surge is making a beeping sound. i plug it in and in a few seconds turns off then turns back on. what do i need to do to stop this from happening? it ONLY turns off the items that r plugged in the "battery/surge" outlets. so maybe the battery needs to be replaced? pls help. ty.
  • maksa Jul 26, 2008
    I happens exactly the same to me too...can't understand why. Was trying to leave it for up to half hour unplugged, hoping for some kind of reset - but nothing could help.
  • Auntie Lynn Aug 24, 2009
    Thanks for your help guys, I guess I'll have to buy a new UPS since they don't sell replacement batteries where I live.
    Problem Solver:
  • 11 Answers
I have the same problem.
It is most likely the battery.
I tested my battery on a Shumacher trickle charger, and the battery wouldn't hold a charge.
This is a common problem with UPS systems that use sealed lead acid batteries.
The longest life that you can expect with these types of batteries is 5 years MAX.
The battery can be replaced with a Radio Shack 12V/7200mAh Lead-Acid Battery
Model: CNB-GP1270F2 | Catalog #: 23-9030
Here is the link for the UPS users manual.
http://www.cyberpowersystems.com/user-manuals/CP550SL_UM.pdf
To replace battery, (unplug AC cord), turn the UPS upside down on floor or workbench.
Remove the 6 deeply recessed phillips screws, then pull the bottom off.
Remove the wire leads from the old battery (pull on the connectors, not the wires). Install new battery (red wire to red or + sign) and replace the bottom and screws. Careful, tighten the screws finger tight (plastic strips easily).
Plug in UPS and you should be good to go.
Hope this helps
Posted on Oct 27, 2008
  • 3 Answers
Here is a purchase link that is six bucks cheaper with a dollar less shipping. Original equipment battery. http://www.apexbattery.com/b-b-bp7-12-battery-sealed-lead-acid-batteries-b-b-batteries.html
Posted on Mar 09, 2010
  • 26 Answers
Yep, that sounds like a battery that needs to be replaced. Here's the original battery used in that unit: http://www.batteryinternational.com/cyber-power-cps525sl-ups-battery-ups-batteries-f1.html
Posted on Oct 23, 2009
  • 3 Answers
E-MAIL I RECEIVED FROM CYBERPOWER:
There is no other known cause of the cycling on/off behavior aside from a bad battery. IT is possible that some component of the battery relay or inverter has failed. If this is the case it would not be repairable outside of warranty.
Regards,
Joel Gerlach
Cyber Power Systems (USA), Inc.
877-297-6937 x7917
MY PROBLEM: NOT the battery!
Posted on Mar 28, 2009
Cyber power 685 avr won't reset
Hi Marvin,
If the unit took a hit to it you should check to see if the battery is still good. It may not function properly because of a dead battery.
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
Nov 05, 2013 | CyberPower 575SL (CPS575SL) UPS System
My Cyberpower 550VA keeps turning off. I can turn it on, and it will stay on for maybe 2 seconds, and then it turns off again. Any solution?
your ups cannot get enough power from the outletreplace the battery of your ups 12volt 7ampere reset the small breaker. when it still turning off test the continuity of the small breaker and the cord to plug use a multitester.
Aug 25, 2011 | CyberPower 550VA 330W UPS Green S System
I have a CyberPower 725SL UPS. Shortly after turning it on, it will beep as if AC power was lost and the green light goes out. I checked the battery and it's good. I'm assuming something went bad with...
Couple different items to check.
  • Try letting the unit set ideal for overnight charging the battery. Do not even turn the unit on.
  • Replace the battery.
If you turn the unit on when the battery is plugged in and does not keep a charge you can almost be sure it is the battery or the charging circuit not maintaining the battery.
Nov 11, 2010 | CyberPower 725SL UPS System
Continues beeping
did you leave it plugged in to let it charge? ups's will beep continuosly till they are charged, if it has dead battery packs inside, it will continue to beep because there is no battery charge to support its job. leave it plugged in for 2 hours. if it doesnot stop beeping, toss it and get a new ups
Jun 04, 2010 | CyberPower 575SL (CPS575SL) UPS System
Cyberpower 525L, power light blinking, beeping. will not run cpu, runs all other devices plugged to it.
525L series as very matter that cause to emliminte the problem try this matters lst.
step1 the power is 300watts -/+ any power supply that above the usage will be overload maybe thats the problem when your cpu & does't power. what are the devices that u plug it to the ups? it important what the devices u plug in maybe using high watts for eg printer, scanner and fax mechines. the solution unplug out those not important device and plug your cpu to test and see it work? and also the socket you plug it in from th cpu, try to plug one of the device to test and see if the power socket is working.
step2 or could be the battery problem juz change the battery and test it up. here are the below website what are the spec of the battery.
http://www.batteries.com/index.asp?N=4294960483+4294958897+4294957694&Ne=25&Nu=p%5Fprodcode
step3: if all this step 1 and 2 does't work it could be the socket from the ups is faulty, ask for the vedor to check your ups if it need?
Mar 29, 2009 | CyberPower 575SL (CPS575SL) UPS System
Cyberpower 575SL stored unplugged x 5 wks-won't power up
check the battery it could be the battery is dead.. if it is so replace the new batts.. than plug in the power to ups.. n turn on it i suggest doen't turn off the power all the time i might cause the lifespam of the battery to shorting.. normal the ups can be use up to 3 yres time..
Mar 22, 2009 | CyberPower 575SL (CPS575SL) UPS System
Reseting my surge protector
What is the model of your battery back up? When does it beep? What kind of beeps?
Nov 02, 2008 | CyberPower 575SL (CPS575SL) UPS System
Cbyer power 525Sl keeps turning off and on and beeps.
I have the exact same issue with my 525SL.
When you push in the red button - the green power light comes on for about 5 seconds = then the light goes out and the device plays a single long beep for about 5-8 seconds.
Given the dialogue here - I took out the battery and bough a brand new BB replacement battery and returned it into the unit as it should. The device continues to have the same behavior.
So it is NOT always a new battery that will fix the system.
Don't jump into spending $30.00 for a replacement.
Look into this further or you'll wind up wasting your money.
Oct 26, 2008 | CyberPower 525SL (CPS525SL) UPS System
(Cyberpower 525SL) not working properly
Regards,
Joel Gerlach
877-297-6937 x7917
Jul 03, 2008 | CyberPower 525SL (CPS525SL) UPS System
CyberPower 325SL backup system
How old is the unit and have you ever replaced the batteries?
Sep 14, 2007 | CyberPower 325SL (CPS325SL) UPS System
CyberPower 525SL (CPS525SL) UPS System Logo
1,406 people viewed this question
Top CyberPower Computers & Internet Experts
George Nalley
Level 1 Expert
Paul Bade
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
