Question about Hayward 15 hp Super II InGround Swimming Pool Pump ()
How do i seperate the motor from the pump - Hayward 15 hp Super II InGround Swimming Pool Pump ()
  • 990 Answers
Remove the six bolts that hold it together. Pull the half''s apart then pull the diffuser off the front of the back half that is still connected to the motor. Look in the center of the impeller. If their is a screw there it will be a left hand screw, remove it. Now you need to unscrew the impeller. Open the back of the motor and get to the end of the motor shaft. Their are two kinds of motors so use a wrench that will fit yours to hold the shaft and use water pump pliers (Channel locks) to grab the impeller and unscrew. This will come hard at first once unstuck it will just spin off. Pull the rear seal plate off and the back plate will four bolts to remove. With that your done.
When you first pull the six bolts and open the pump you can pull the wires and bring the whole thing to a motor shop or pool store and they will usually just charge for the motor and parts and do most of it there for you.
Posted on Oct 24, 2010
SOURCE:
I'm trying to remove the motor from the back of my Hayward pump (Northstar). I've loosened the large, round locking housing that secures the motor to the pump. It appears the motor should now just slide...
You didnt mention removing the impeller before trying to "slide it out" Remove the impeller and diffuser first before trying to seperate the two pieces. Lock onto the rear shaft with a 7/16th" wrench while rotating the impeller counter clockwise until remoed. Now you can seperate the two halves.
Apr 21, 2011 | Hayward 1.5 Hp Northstar High Performance...
How does the electric motor couple to the compressor? Is it easy to remove the motor for bearing rplacement?
Some oil lubed compressors as well as oilless types have a bolt on rod journal that can be removed to allow motor to be seperated from pump. Others, however have journal either one piece to motor shaft or journal is pressed on. If you do not see bolt thru journal, most likely it will not seperate. Check with parts manual for more information as some motors have a removable iron core on the shaft (very difficult to remove and re-install). Good luck
Apr 06, 2011 | Air Tools & Compressors
I want to replace all the o rings, i have seperated the moter from the body, but i only see 2 orings that i can replace, there are 4 other bolts i removed but i can not seperate the pump from the impeller...
THERE IS THE TANK GASKET THE DIFFUSER O-RING,LID O-RING AND THE SHAFT SEAL.. ITS A 1000.. ASK YOUR LOCAL POOL SUPPLY FOR A PAC-SEAL 1000 .. CLICK HERE TO SEE HOW 2 REMOVE YOUR PUMP .. PRIME THAT PUMP AFTER A REPAIR ... HOPE I WAS OF HELP.. IF SO .. VOTE .. Jay
Jan 29, 2011 | Pentair 2 hp WhisperFlo InGround Pool Pump...
Trying to replace motor cant figure out how to remove impeller,
Might be a screw in middle of impeller with reverse thread. If so, remove. Remove back cover of motor, hold center shaft with wrench and unscrew impeller from shaft.
May 05, 2010 | Hayward 1.5hp Pool Pump Motor Motor A O...
The windshield fluid pump/motor doesn't work. Is there a fuse for this or does the motor need to be replaced?
Try supplying a seperate 12 volt power supply to the positive lead to the fluid pump motor. If it works, it is the switch, but if it does not work, it is the pump motor.
Apr 26, 2010 | 1991 Honda Accord
Wont go into spin cycle and wont drain but makes a buzzing sound while in the spin cycle
plugged or bad pump or bad drive motor. if it has a seperate pump and motor for drain could have somthing in it if the pump is driven by the main motor pump could have frozen up or motor could be bad in spin mode sometimes the timer won't make the motor run just hums ges are good for this make and model #s help us help you good luck
Dec 08, 2009 | Washing Machines
Water leaks above motor when the machine is turn on.
The seal around the pump / motor assembly may be bad. The seal can be purchased seperate from the pump.
Sep 05, 2009 | Dishwashers
Proline Pump 8D-10-1n11CB. This is for a pool and is leaking from the shaft to the motor
The pump seal is bad on the unit. This requires disassemble of the pump unit. Remove power to the unit, dissasemble pump housing, remove the impeller from the shaft of the motor by removing the allen screw with an allen wrench. Seperate pump housing from motor remove the old seal replace seal. Lube motor shaft with a little clean oil or wd40 to facilitate easy install thru new seal,reassemble in reverse.
Jun 03, 2009 | Hayward 1.5 Hp Northstar High Performance...
Need to replace pump motor i have a new motor but i cant seperate the pump on the motor armitur
i was having the same problem with my pool
motor, and couldn't saparate so i replace it
as unit both pump and motor,
May 08, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Hayward 15 hp Super II InGround Swimming Pool Pump () Logo
119 people viewed this question
Top Hayward Pool & Spa Experts
Bill Jordan
john h
US Parts Center
US Parts Center
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
