Question about Xerox Office Equipment & Supplies
Xerox Work Centre XD120f - J2 error message. Lost manual need new one.
    President:
  • 2,072 Answers
J2 means the drum unit has reached the end of its life. You need to replace it.
Staples . office max etc normally has them in stock.
If not google a company called The Parts Drop.
They will have what you need also.
Posted on Oct 25, 2010
SOURCE:
I needed a new drum (j2 error) so I bought one, installed it correctly, but the machine still shows the j2 error and will not clear itself or let me make copies. What can I do? I really need it to be...
Found old post for diffrent printer see if this info helps.
Drums may worj the same even though diffrent models.
Problem with the Xerox Printers Xerox XD130DF J2 error replace
By lgrey on Jun 20, 2008
Xerox XD130DF J2 error replace drum Best Solution posted 3 years ago
cbb7438.jpg rytech uk
  • Rank: Wiz computers_small.png
  • Rating: 80%, 98 Votes
Im presuming that your have replaced the drum??
if so :
Remove the new drum.
On the front of that drum, there is a green cover. Take it off and what has happened is the flag on the gear had dropped in shipping.
You will see a flag like piece of plastic on one of the gears, reset it to up and somewhat to the right.
Then put the green cover back on
That flag has to be in the up position when new. It passes down and actuates a drum reset switch on the machine.
When that is back in the up position. re insert the drum and on the first revolution it will turn on the switch.
Jul 06, 2011 | Xerox WorkCentre XL2140df Laser Printer
I just got a new computer with Windows 7 OS. I can't find a driver for my Xerox WorkCentre xd120f printer. Any suggestions?
Xerox discontinued support services of the xd120f as of December 29, 2006. There are no plans to develop Vista or win 7 drivers for these products.
You could use a program like virtual box - http://www.virtualbox.org to create a virtual Windows XP machine; install Windows XP on a seperate partition or install the printer on another PC in your house with XP and share the printer resource across the network.
Aug 07, 2010 | Xerox WorkCentre XD120F Laser Printer
J2, toner low, but powder in toner cartg. Remove
All this means is that your toner is getting low and advising you before it is out completly the it needs replacing.
Dec 15, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox xd120f showing error code E7 and not copying
I had E7 and the unit required a new laser unit. Precision Roller had the replacement laser, which did correct the error. Apparently, during a move to a new location, something jarred the machine and caused the failure.
Oct 06, 2008 | Xerox Office Equipment & Supplies
Xerox workcentre Xl2130f copier printer error j1
that is the message for low or out of toner. What you are doing by tapping it is just lostening the reemaining ink in the cartridge. If the cartridge is new, have it replaced where ever you purchased it because most likely its defective.
Oct 02, 2008 | Xerox WorkCentre XD120f Copier
J2 Error ? Xerox Pro 215
J2 means your drum needs to be replaced. The life of the drum is expired.
Mar 13, 2008 | Xerox WorkCentre PRO-215 All-In-One Laser...
J2 Error
check for a paper jam in the machine and in the paper tray, if no paper is found take out toner cartridge shake it slightly and reinstall. Also turn machine off & unplug. Let me know if you need more help.
Oct 26, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
Drivers to windows vista no are in plans to devenlopment in xerox
Drivers for this printer can be found HERE: --> http://www.support.xerox.com/go/SOHO.asp?Xtype=download&prodID=XD120f&Xlang=en_US&Xcntry=USA ...or HERE: --> http://drivers.softpedia.com/get/PRINTER/XEROX/XEROX-Printer-WorkCentre-XD120f-501230001.shtml
Aug 03, 2007 | Xerox WorkCentre XD120F Laser Printer
Open Questions:
158 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
