Question about Cuisinart CB-600 Blender
Does the rubber gasket go next to the glass beaker or next to the plastic bottom?
I have an older Waring blender, model WF1112218. My problem is I took it apart to clean it and now can't figure out how it goes back together. Is it rubber gasket then rotor or the other way around?
Hello, Carla -
For all electric blenders the rubber gasket is placed between the glass or plastic blender container and the rotor with the blades.
The assembly is easy to recall when one realizes the rubber gasket is the seal for keeping liquids leaking out of the blender.
See the image here (it's for a Black and Decker, but the assembly is the same):
http://stainless-steel.us/12-pictures-of-baby-bullet-blender-instructions/black-and-decker-blender-assembly-instructions/
The image here shows the assembly for a Waring blender (different model than yours):
https://www.etundra.com/restaurant-parts/parts-diagrams/waring-bb140-bb150-bb240-bb250-bar-blender-parts/
Best wishes.
Jun 01, 2018 | Waring Blenders
Why doesn't blade spin?
Either the coupling from the motor with the fingers on it is not really attached to the motor shaft or the drive on the blade that engages with it is not attached to the blade shaft. One other thing is that on some models if the rubber jar seal between the beaker and the blade carrier is in the wrong place it can raise the blade drive to not engaging properly with the motor coupling. The gasket goes between the jar and the blade carrier, not under the blade carrier.
Sep 04, 2015 | KitchenAid KSB3 Classic Work Top Blender
I can manually turn the blades inside the glass pitcher and I can turn the piece on the top of the motor base into which the pitcher blade attachment fits.
One of the parts is not being driven properly. Either the clutch on the top of the motor is not really attached to the motor shaft OR the clutch on the bottom of the blade is not engaging with the motor clutch OR the blade clutch is not properly attached to the blade shaft. On some models if you put the rubber sealing ring in the wrong place between the beaker and the blade housing it is enough to lift the clutches apart. The rubber wing goes between the beaker and the blade housing, not between the blade housing and the blade retaining ring.
Jul 14, 2015 | Blenders
Ksb555
If you have the glass jar then purchase either a new rubber seal for the blade to jar fitment or replace the blade assembly, it will be one or the other. If you have plastic beaker then get a new beaker, it is sold as a single assembly.
Nov 29, 2013 | KitchenAid Blenders
Putting glass and washer together
  1. Place glass container upside down on safe working area.
  2. Place rubber gasket/ring on top of opening first.
  3. Place stirring or mixing blade on top of rubber gasket/ring.
  4. Take the plastic retainer and screw it on over everything previously assemble.
  5. Hand tighten only enough that you can reverse the whole operation when comes cleaning and disassemble time.
Feb 13, 2010 | Elite 072-04-1198 Blender
Leaking from the bottom of the glass container through the screw
Check the rubber gasket for damage or hardening and also for chipped glass on the sealing surface. Make sure the ring is not cracked causing loss of compression of the seal.
Also check that the leak is NOT at the shaft seal. Replacement parts should be readily available,
Nov 08, 2009 | Oster 4093-8 Osterizer Classic Blender...
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
RUBBER GASKET ON BOTTOM OF GLASS JAR NEEDS TO BE REPLACED
It looks like their parts are handled by Fox International. here is the contact info:
For parts and accessories for your household appliance, please visit our partner, Fox International, or use the following.
Phone Number: 800-738-0245
(Monday-Friday, 8:30 AM to 8:00 PM, E.T.)
Email: [email protected]
Mar 29, 2009 | George Foreman Blenders
Maximatic EBL-1000 Elite Cuisine 10... Problem:
Brandy,
-the gasket is a flat rubber ring
-it is used to seal the space between the glass carafe and the plastic carafe base that fits into the base unit
-so the order is glass carafe, chopper blade, gasket, plastic ring...turn this on tightly
-place the whole carafe unit onto the base unit
NOTE: it does not fit firmly...suggest that you hold it firmly before you turn the unit on
so I hope that `fix-ya` works....if not...then ask.
...as any rating than this actually lowers my rank...just the way fix-ya works
bearb
Nov 10, 2008 | Maximatic EBL-1000 Elite Cuisine 10 Speed...
Cuisinart sealing gasket
The gasket goes between the cutting assembly and the glass. So you slip it on over the top of the blades and then put the glass jar over top of that. Screw the bottom cap on to tighten everything together.
Aug 15, 2007 | Cuisinart SPB-7 SmartPower Work Top...
Cuisinart CB-600 Blender Logo
1,076 people viewed this question
Top Cuisinart Blenders Experts
eyecam
Gil Shultz
ray gallant
ray gallant
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
