Question about Jenn-Air JMC7000 Microwave Oven
JMC7000 No turntable, interior light or microwave function. Just the clock, timer and keypad functions...
  • Jenn-Air Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Oct 26, 2010
SOURCE:
The control panel of my sharp grill 2 convection microwave oven is very dim
Dimmed light might be caused by a slight contact between the panel's connector and the mainboard. Or, there is a dimmer option (feature) in the menu. Depends on model. Some of Panasonic microwave ovens are equipped with such a feature.
Regards,
Dan
Oct 12, 2016 | Sharp R-820JS 900 W 0.9 cu ft Countertop...
Ge microwave je2160sf03
From the description one of the door switches is defective, or a more serious problem has developed.
Jun 02, 2012 | GE Spacemaker Over-the-Range Microwave
Microwave has power, but nothing works.
The door switches are more than likely the problem, one or two will need to be replaced, I recommend a professional.
Mar 18, 2012 | Panasonic Microwave Ovens
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Clock works, timer works-but turntable and other functions stoppe
you have a bad control board . this board had 2 relays one for the magntron and one for the turntable and the cooling fan together . when the turntable goes out so does the cooling fanm and the microwave overheats ...... there is no good fix for this , the control will cost more than a new microwave . please do not use with this happening . i have see them start on fire when it overheats . please be carefull good luck
Jan 15, 2009 | Emerson MW8108P Microwave Oven
JVM1190 wont cook
You have a blown actuator. This is the device that creates the microwaves that cook the food. The cost of one of these will be as much as a new unit.
Nov 09, 2008 | GE JVM1190 Microwave Oven
The door of my Kitchen Aid Microwave YKCMS1555RSS wouldn't open because the plastic prods that push open the latch had worn down. The oven was otherwise functional. I inserted some plastic knobs to extend...
The door latch heads (prods) are not making proper contact with the door switches, so it will not work right.
The latch heads need to be replaced.
You can order parts for this Canadian model here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 02, 2008 | Microwave Ovens
Microwave was installed yesterday by "handyman"
Sounds like you have a defective door switch, door switch mount, or (worse) possible damage to the "hooks" which go into the holes in the chassis to activate the switches. Be sure to unplug it first. If this is an over the range model, you should not have to remove it from the wall to fix it. Generally speaking, you remove the grille across the front, then you'll see a screw holding the control panel frame on. Once that's removed, you lift the control panel assembly up and out. Then you can see the door switches and lathces, etc. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
Mar 12, 2007 | Frigidaire PLMV169DC Microwave Oven
Jenn-Air JMC7000 Microwave Oven Logo
121 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Ekse
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
